Old 01-19-2008, 04:58 PM   #8836
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Originally Posted by Pattojnr View Post
the weight of the G4RS im not sure on std kit form, i would imagine around the min weight 1725grams ready to race. parts , well i like to have gearing options available, so i would get a couiple of each spur and 1 of every pinion, work out the best option for your track then stock up on those. id keep arms and bulkheads and a couple of clutch shoes and a set of belts. really depends on how much you will be driving it, and if you have good parts support. i go over the top at times, i think i carry on me at all times 3 of every bulkhead, 5 each of my prefered spurs, and 4 of every arm. 3 clutchshoes, and many odds and ends. ill run my parts down till i have one left of most things then reorder them. it really is an easy car to work on, very well thaught out to get to most things easily. and it handles great also
thanks for the information Pattojnr. I really appcreciate it. I was wondering how does the car feel in its stock form is it well balanced? Also where can I find the manual for the G4RS, I looked on the TM site but all that I found was the exploded views of parts and the parts list.
Thanks Jason.
jscamry is offline   Reply With Quote
Old 01-19-2008, 05:54 PM   #8837
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Thanks Jason.
firstly there is a manual at wolfhobbies.com
i am yet to run the car (next weekend), but all reports are good so far.
there wouldnt be any hopups needed for this car, maybe just rear universals if you want to. problem being is many guys were adding parts to stiffen the car, the G4+ came with all the stiff stuff apart from the alloy radio tray supports. this i fell made the car hard to get rear grip. now things have changed a bit with the car now, i cant wait to run it. it will be good in stock kit form. might have to play around with diff oils , or maybe get a spool for the car if you prefer it.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-19-2008, 06:50 PM   #8838
aussies1129's Avatar
Trader Rating: 74 (100%+)
Hi Paul mate if I want to go lipo and a regulator etc in the rs what do you suggest in regards to what size/brand battery,charger ,regulator, etc and fitting it to the car?
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 01-19-2008, 07:34 PM   #8839
Pattojnr's Avatar
cheers
i use a LRP 1500mah (79910) LiPo dimensions are 52x31x22, its quite small for a 1500mah size. there are mods youhave to do to the radio tray. like remove the section of the carbon between the normal battery and the fuel tank. i made up a small shield out of plastic to sit on the battery and glued it to the radio tray, plastic protects the belt side of the battery and use double sided tape on the chassis. make sure no carbon or alloy is close to the battery. vibration for wires and casing of the battery isnt good, i also used some heat shrink around the whole battery and this holds the plastic also to the battery. a bit of silicone around the carbon surround where the battery sits is also effective for insulation and vibration. let it cure then put the battery in . this is just precationary measures. hate to have a wire rub through or the casing.
the reg i use is a VRX 5 amp reg. there are smaller ones around, but again 5 amp is more than enough. LVR-5000. you can fit this ontop of the transponder mount. again double sided tape and a zip tie for this. also recommend a y harness here to plug the battery into the reg and the transponder before the reg.
a swallow 2 charger works perfectly fine to charge the battery. there is no balance plug on these batteries. most 3 cells i would use a balance charger. 2 cells seems ok to use with out balance charging. keep an eye on your charge between heats, as the reg has a low voltage cut out. when it hits 6V it will cut all power to reciever. this battery lasts all day. i have run over 1.5 hours on this battery and it still had 6.8 V. so again precaution here to keep an eye on your charge. i hope to post some pics soon of my car. once i get the reg and all out of the buggy.
Serpent - Walter RC
Old 01-19-2008, 08:11 PM   #8840
sounds good look forward to pics of your car and lipo is a bit of a mystery to me at the moment no one uses it at my track so I will being going in blind folded but if I can get the weight down and good run time it will be all worth it!
thanks mate!
michael
H.E.I AUSTRALIA
Old 01-19-2008, 11:20 PM   #8841
jscamry's Avatar
Is it possible is some you could please post some pics of your G4RS's?
Thanks Jason.
Old 01-20-2008, 08:02 AM   #8842
gansei's Avatar
this is my G4RS!!
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 01-20-2008, 01:35 PM   #8843
Sp Racer's Avatar
Thanks Jason.
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 01-20-2008, 04:19 PM   #8844
LAKIA's Avatar
sp racer........u never change yr colour scheme ...........
LAKIA is offline   Reply With Quote
Old 01-20-2008, 10:00 PM   #8845
jscamry's Avatar
Nice cars guys!! Thanks gansei and Sp Racer for the pics, I was just trying to get some more ideas as how to car looks aside from the pics on the TM site. I tried to search the net but I did not find too many picures
Thanks ~J.
Old 01-20-2008, 10:08 PM   #8846
dnitro's Avatar
Originally Posted by gansei View Post
this is my G4RS!!
Thats a nice pipe Gansei. Does the polish ever wear out??? Its seams like everytime you show us a picture, your pipe is very shiny. You can always check if your hair is in its place.
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 01-20-2008, 10:28 PM   #8847
gansei's Avatar
the pipe is only demo purpose.. i did not use it!!
MY SPONSORS:
Old 01-20-2008, 11:04 PM   #8848
hi....
top ramen is offline   Reply With Quote
Old 01-20-2008, 11:17 PM   #8849
nice pics gansei,just got my g4rs from wolfhobbies.com wow that was fast shipping. g4rs in progress.......................................... ......
Old 01-21-2008, 05:59 AM   #8850
Pattojnr's Avatar
Default my G4+/RS
Gee Gansei, i had to bring out a new pipe for these pics. anyhow here is my car , still in progress. will be ready for this weekends racing.
Team Magic G4-100_2979.jpg   Team Magic G4-100_2981.jpg   Team Magic G4-100_2984.jpg   Team Magic G4-100_2985.jpg
Serpent - Walter RC
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
