Old 01-02-2008, 07:22 PM   #8776
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by nitrobeast View Post
Hey guys
Nice to see lots of new faces and some of the old. As you all know getting parts in the US is gonna be hard. Does anyone have a good source for online buying that will ship into the US?
ok you have a few options here
go to wolfhobbies.com , look at the list of dealers, depending where your are situated, there should be one near you. you can also go to rcshopping.com, (TM shopping site) but im not sure how this is going to work now the US has a distributor ? or you can try the usual suspects in Dinball, and Mushroom. hope this sorted your delema.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-02-2008, 07:28 PM   #8777
Pattojnr's Avatar
Originally Posted by British Menace View Post
Hello Paul,
Good to hear from you.
Thanks for the info' about the RS pulleys, that's helpful info' to have.
I didn't read back that thoroughly on previous post's and hence, missed your post. Sorry.
If you were to add weight to the G4 Paul, where and how would you put it on the car? I want to carry on with making the car very light and having "fixable weights" that I can use to bring the weight of the car up to speck. Different weights could then be used to alter weight biase front to rear as a tuning option or whatever.
What do you think?
British Menace
Havent forgotten about this post Tony, just havin a really good think about it its starting to hurt
first off, if the car is so light, how durable will it be ?
second, obviously the chassis is a point where you want to add the weight (low CG) but how ? last thing you want to do is use led stick on weights, i would hate to see one come off in an accident in a long main, then be underweight when scrutineered. so i would think something bolt on, and some where around the ends of the chassis, more weight infront could give you a little more rear weight transfer, and some more off power grip up front, and vise versa for the rear, so i guess once lightened to where your happy, run the car and see what it is the car needs, as to where to add the weight. but let me keep thinking about it for a bit
Serpent - Walter RC
Old 01-02-2008, 08:02 PM   #8778
qcrc's Avatar
Originally Posted by Darkseid View Post
Wow, 4 pages of post, and I'm just now finding out about the G4RS. I guess I need to visit the nitro forum more often.
The car looks good. My G4S is seriously worn out after years of racing (it started life as a Mongoose), and I was considering making the switch to the Mugen for next summer, but this has given me reason for pause. Couple questions...
-How much is it going for?
-Where can I get one?
So far, the only thing I don't like is the switch to a front gear diff. Short track or long, high grip or not, my G4S always worked well with the front one-way. So I don't see why the switch was made to a front diff.
The one way from you car will work in the RS. The diff gives better turn in over the spool and brakes that the one way lacks. Some drivers like the diff on small and technical tracks. I'm am going to try it out next year.
Wolfhobbies.com sells them for $439.
qcrc is offline   Reply With Quote
Old 01-02-2008, 08:25 PM   #8779
YLLIB's Avatar
Speedworld selling them for $419.00 g4rs
www.speedworldraceway.com
YLLIB is offline   Reply With Quote
Old 01-03-2008, 03:37 AM   #8780
razzor's Avatar
Originally Posted by NitroWD View Post
so... can ufo2 clutch shoe and shoe plate be fitted in a ufo1 and vise versa?
btw, isn't the std g4s already running with 19T brake pulley?
pardon me if u find my qns stupid...
Sorry that is correct.
Ive been swapping the brake pulley's to see the difference and between the 18T/19T/20T the 19T ran best with the Mega DSII where as with the Axial and Palmaris the 20T felt better but again the clutch setup could also be a contributing factor.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-03-2008, 04:43 AM   #8781
aussies1129's Avatar
Trader Rating: 74 (100%+)
hey Razzor/Paul so is there an upgrade kit to the g4rs available now? I take it if any one wanted to upgrade to ed trans then the g4rs plastic is now a better option than the original metal ed trans?
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 01-03-2008, 05:35 AM   #8782
Pattojnr's Avatar
cheers
i dont think there is an update kit at the moment.
i am starting with the chassis, and the new rear braket and the shock tower mount and the tower. the new shock tower is becuase i needed a spare, but the pullies being plastic now, just as the original G4s makes it a cheaper option to keep spares for sure. also opens up new options to play with internal gearing for certain tracks. plastic is lighter, but also have to be carefull where you run the car, the littlest stone can ruin a plastic pulley in seconds. but they are cheaper to replace and easier on the belts.
anyone tried the ZF belts yet ? i have a few sets of belts to go through before i head for the ZF belts, thanks.
Serpent - Walter RC
Old 01-03-2008, 06:02 AM   #8783
I havent tried the belts yet but will get after I have gone thru my spares, I have the new white clutch shoes coming in a week or two which TM are claiming higher grip so will wait and see and will let you know how they wear.
cheers
H.E.I AUSTRALIA
Old 01-04-2008, 09:46 AM   #8784
gansei's Avatar
i heard that TanaKa take G4!!!
is it true?
Tanaka is a MotonicA Driver.
japan Motonica distributor import TM G4.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 01-04-2008, 04:31 PM   #8785
British Menace's Avatar
is it true?
That will be interesting if it turns out to be true.
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is online now   Reply With Quote
Old 01-04-2008, 05:44 PM   #8786
I find that G4S is easy to drive. I have collided a number of times at high speed. Yet, it still remain intact. It says a lot about this car. It is very tough, almost like an armour vehicle. But local shops cease to stock up TM products.
I am having difficulty getting spare parts. Many hobbyist are giving up their
G4S for cars of other makes like NT1, V1rrr etc. Anything wrong with the distributorship? We have to order from oversea for some parts. It takes time & can be expensive for some items. I hope that something can be done. Or i may join the ranks of the others.
Kiowa is offline   Reply With Quote
Old 01-04-2008, 08:27 PM   #8787
Pattojnr's Avatar
Where abouts are you situated ?
also most places are finding it hard at the moment getting parts for most manufacturers. just a bad time of the year for postal services.
Serpent - Walter RC
Old 01-05-2008, 08:22 PM   #8788
qcrc's Avatar
Has anyone tried out the new UFO 2 clutch shoes yet? Also would they work in the original UFO? Thanks.
Old 01-06-2008, 08:04 PM   #8789
Nice avatar!
watwasdat is offline   Reply With Quote
Old 01-06-2008, 08:21 PM   #8790
Did you see the Midwest Series schedule yet? No St. Louis race. Does that help make up any minds? Haven't seen the Heart of America schedule yet but me thinks it will be roughly the same as 07'.
May 3 & 4 --Cinci
May 31 & June 1--Chicago
June 21 & 22 --Mentor
July 19 & 20 --Racine
Aug 23 & 24 --Joliet/Leisure Hours
Sept 20 & 21-- Toledo
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
