Old 12-14-2007, 12:32 PM   #8686
cheesewhip's Avatar
Trader Rating: 15 (100%+)
Default update kit please??? pretty please?
can team magic please put out an update kit?
do i really have to drop another 300-400 for a new kit when my existing car (G4S) works fine?
pretty please?
TM G4S, AE NTC3 FT, FLM Savage, TRX REVO, Serpent Veteq, Kyosho MP777 SP2 WC, HPI Hellfire, Losi 8ight, Losi 8ight T
cheesewhip is offline   Reply With Quote
Old 12-14-2007, 01:08 PM   #8687
ALG
Originally Posted by gansei View Post
korea weather is also too bad..
i run E4 on the ice in last week (sub-zero temperature)
But i will try G4RS in this weekend!!
pls wait for G4RS FeedBack!!
Here on Lima is HOT!!!!
waiting for your report and keep tune!!!!
ALG is offline   Reply With Quote
Old 12-15-2007, 06:49 AM   #8688
gansei's Avatar
korea fall rain and snow in today
so i could'nt race the G4RS...
i made a handle in G4RS Box For carrying Box
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 12-16-2007, 06:44 AM   #8689
gansei's Avatar
Default G4RS Virgin Race..
G4RS virgin Race
i run G4RS in today..
korea weather temperature was about -2C ~ 5C.
i did race G4RS with almost normal setup.
But it did not good for me.
so i changed downstop, shock spring, shock postion, rear knuckle arm upper shim.
and i found good setup(about 80%~90%)
i will try other diff setup in next run
(normal diff front 30000, rear 10000 made feel push understeer)
i found several difference against to G4S
1) G4RS had more roll, fast roll speed
2) G4RS had more stability
3) TM spring was good at G4RS
i tried this setup in today.
front diff 30000 rear diff 10000
front spring TM 1.6, rear spring TM 1.7 (600wt oil, 2 X 1.1 hole)
front/rear downstop: 1/3
rear knuckle-arm upper shim: 4mm
wheel base: max shorten
rear toe-in: 2.5 front toe-out: 1
front camber: 2.5 rear camber: 4
front width:198 rear width:200
front stebil: 0, rear stebil: 45
tire: front/rear all 37
front shock positon: the first from the bottom
rear shock positon: the third from the bottom
Body: Sturatus 3.1
MY SPONSORS:
Old 12-16-2007, 03:02 PM   #8690
muppet racing's Avatar
Hi gansei,
Good work Our weather is too bad to do anything !
If you dont have too much track grip I would suggest having bigger holes in your shock pistons, or maybe thinner oil.
Also on the rear camber link, maybe you could try 2 shims on the hub, with the inside in the middle inside hole. I think you will be able to run less rear camber to get the tyre wearing nice. Putting more weight on more of the tyre.
Do you mean having the wheelbase short front and rear ? If so I think this is very short, maybe a little more tricky to get the car balanced with the shortest wheelbase ?
Good luck
muppet racing is offline   Reply With Quote
Old 12-16-2007, 07:22 PM   #8691
gansei's Avatar
Originally Posted by muppet racing View Post
Hi gansei,
Good luck
thanks for your advices
i will try some other setting.
i have a question about wheelbase.
i tried all short front/rear wheelbase.
i want to know what difference of front only short wheelbase and
rear only short wheelbase.
MY SPONSORS:
Old 12-17-2007, 07:05 AM   #8692
keavze's Avatar
Default rear loose?
hi,
i'm not driving the RS but would like to to ask:
whenever i turn my steering for a bend during high speed, the rear would slide alittle (abit too much for my liking ); any suggestions to get the rears grip more?
my setup: (low-medium traction big track)
37 tires frt and rear
600wt frt shocks, 500 rear; with same tension springs
frt solid, rear 20k diff (how to counter understeer for frt solid during off power?)
frt shocks more inclined than rear (more upright)
cheers
p.s. what does it mean when someone said his car is 'pushing'?
keavze is offline   Reply With Quote
Old 12-18-2007, 09:33 AM   #8693
Hi gansei,
Short fr wheelbase, I found that gave more steering/rotation on corner exit (after apex) I dont think our car needs any more of this !, with shorter rear more steering/rotation for the turn in to the apex. For me I just try to use use the rear at its shortest.
keavze,
You could try the rear shocks layed down more, this should give the car a safer feel.
Pushing, means understeer, the car does not have enough steering so the rear 'pushes' the front. Usually nice and easy to drive though
Good Luck.
Old 12-18-2007, 05:49 PM   #8694
Greywolf's Avatar
Default .
Hi all
Can anybody tell me if the Eagle Racing G4 Team Kit was the original G4 or a later model run.
Tamiya M03/M03L/3 Racing TA05
HPI Blitz
Growing Old Disgracefully
Greywolf is offline   Reply With Quote
Old 12-18-2007, 05:56 PM   #8695
YLLIB's Avatar
Hello Gansei or anybody knowledgeable builder on the g4rs. Have you experience the rear camber links pivot balls fitting to way tight on the plastic ball ends? What to do?
Please help.
YLLIB is offline   Reply With Quote
Old 12-18-2007, 11:26 PM   #8696
Company Representative
OLD 69's Avatar
Trader Rating: 44 (100%+)
Please help.
Yes i have built one and yes the rear links were a little tight on mine. Grab a pair of pliers and squeeze the ball ends gently. Works a treat.
...Ari
OLD 69 is offline   Reply With Quote
Old 12-19-2007, 12:13 AM   #8697
YLLIB's Avatar
old 69 Thank you very much, I was going to tell my customer that but I wanted to make sure that he had the correct parts that matched first. I still don't think you should have to do that, but you never know... He had called on the phone so I did not see the parts in hand. He had called one of the new US distributor and they told him to but oil on it. WRONG ANSWER I told him, it will not work.
thanks again
Old 12-19-2007, 08:04 PM   #8698
keavze's Avatar
keavze,
Good Luck.
how can i reduce 'pushing'? my car is understeering abit too much for my liking...
Old 12-19-2007, 11:32 PM   #8699
gansei's Avatar
Default G4RS Movie
this is G4RS Drive Movie taken in yesterday.
kyosho CRF engine..
and some setup was changed after my first G4RS setup.
front/rear all 1.7 TM Spring.
Front Diff: 40000, Rear Diff: 30000
front Droop: 1, rear Droop: 3
G4RS Battle!!!!
http://www.youtube.com/watch?v=AGSd0EIZfco
MY SPONSORS:
Old 12-20-2007, 12:28 AM   #8700
aussies1129's Avatar
Trader Rating: 74 (100%+)
nice video gansei your car is really taking off when it hits 2nd gear on that back straight!!!
thanks
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
