Old 11-10-2007, 06:32 AM   #8536
keavze's Avatar
Default tensioner: top or bottom?
hi,
something to enquire about belt tensioner (rear); it can be mounted either on the bottom (stock) or top (carbon plate)...
so...which one is better? or is there any difference at all?
keavze is offline   Reply With Quote
Old 11-10-2007, 06:51 AM   #8537
razzor's Avatar
On the G4S the tensioner mounts on teh chassis and on the older G4/Mongoose it mounts on the carbon brace.
The tensioner on the chassis is a better option as its not on the load side so takes up the flack on the belt.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 11-10-2007, 09:22 AM   #8538
British Menace's Avatar
Originally Posted by emankov View Post
Hi guys
i need to ask 2 questions regarding a new build of a g4s (stock).
1) How come my nomadio tranceiver v2, doesnt quite fit in the receiver housing of the car? A hasty mod by me, puts the transeiver 1-2 mm below the chassis
Cannot figure an easy way out.
2) How come the pre-build steering blocks have so much endplay??
Rest of the assembly is ok but endplay of steering system screams "low quality"
Ppl that face same problems plz stand up and help.
Pre-building of the steering blocks is a new feature of the G4 kit. They are pre-assembled but are not in "Ready-to-run" condition when you get them. They do this so as driver's/builders can tighten down the pivot ball nut to apply as much, or as little play in the pivot ball joint as they like. Some top drivers have a fare amount of play in this are so as to have as little friction as possible. (Enhances very quick steering and used by drivers with quick reflexes and those that drive aggresively!!)
Others like myself and a fare few others I know, like to have very little or no play in this area! But has been said, try to keep the friction down to a minimum. It will really "sap" the power from your steering servo and hence your battery pack!
Usually, tight pivot ball assembly is used by top drivers who tend to be very smooth drivers. It allows more sensativity from the car to the driver.
It is NOT a quality problem as was suggested! It's done to help us when assembling the car !!
British Menace.
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 11-10-2007, 03:44 PM   #8539
emankov's Avatar
Of course its not.
I recognized my mistake 1 page up.
And yes it is exactly as u said.
Also the tranceiver problem is related to nomadio tranceiver size and its not something TM is responsible of. I have a spectrum receiver on the way...
Bottom line is, if u have to drink during the assembly of your kit, choose the drink wisely....
emankov is offline   Reply With Quote
Old 11-10-2007, 09:42 PM   #8540
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Of course its not.
hahaha, i like it, my motto is drink as much as possible, even in the big races. makes for more fun
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-11-2007, 02:04 PM   #8541
Of course its not.
lol...... funny. Sorry I didn't see your other post recognizing the mystake. Have fun with the car.
British Menace
Old 11-11-2007, 06:33 PM   #8542
aussies1129's Avatar
Trader Rating: 74 (100%+)
ok I need a few suggestions I am running on the tightest track you could imagine with a short straight and I am running my g4s with ed trans front solid axle what would be a good gearing to run on this type of track? also this track has limited grip as I am running 37 front and rear grps.thanks.
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 11-11-2007, 11:47 PM   #8543
Pattojnr's Avatar
the shortest possible gearing is 15/52 and 20/47, then work on your clutch settings from there to be able to get the power down.
Serpent - Walter RC
Old 11-12-2007, 02:39 AM   #8544
thanks Paul thats what I am running now to get the power down would that be tightning the spring or loosening at the moment I am running the blue spring with thread about a mm inside the nut thanks for your help.
H.E.I AUSTRALIA
Old 11-12-2007, 02:21 PM   #8545
razzor's Avatar
If you using the blue spring then id suggest getting a black 1.8mm spring or better yet the Mugen hard spring and remove one of the weights in the flyweight shoes.
When setup right this como works well.
To help the car accelerate better you could also run smaller tyres around 62-60mm but be careful of wear.
Casterracing ZX1.5R
Old 11-12-2007, 04:12 PM   #8546
I got the black spring there so I will swap it with the round nut screwed down whats a good start point/how far screwed down?keep in mind I need quick ecceleration
cheers!
H.E.I AUSTRALIA
Old 11-13-2007, 01:24 AM   #8547
razzor's Avatar
id say .5 - 1mm max to start with or better yet go flush and adjust a quater turn at a time but make sure it doesnt slip.
Casterracing ZX1.5R
Old 11-13-2007, 03:03 AM   #8548
TM Sean's Avatar
<Click on the picture to see the feature detail>
TM Sean is offline   Reply With Quote
Old 11-14-2007, 11:12 AM   #8549
Local racer's Avatar
I here that Tm might have found a mainstream distributor for there onroad products in the Us I will no more soon.
Local racer is offline   Reply With Quote
Old 11-15-2007, 12:42 PM   #8550
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
raceday hobbies still around (ie) SAM FELISH
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
