Team Magic G4
#8372
Tony you have a PM.
#8373
Its the new Axe Cobra .12.
Its not modded and from what i have been told the factory modded evolutions motors will be available from next month.
Ill be doing some track time next week before the nats and definately will give some feedback.
#8375
2 grub screws in the bulkheads, there are 2 small holes inthe plastic top bumper to get to them. they touch and adjust how far upward the movement of the alloy housing for the front swaybars towards the middle of the chassis. this affects the amount of downward movement the arms have.
#8379
check out my blog http://kodakhodak.blogspot.com - something i put together when i just go into rc
#8380
Thats correct Perez.
Gansei is using Knack cnc'd diff gears for the V1RRR
#8381
#8382
Yo g4s racers,
Since i finish building my g4s (stock)
please propose me a decent race .12 engine (stock, not modded not fancy).No need to justify your proposal, just name the engine.
Much Appreciated
Much Appreciated
#8383
Picco JRL RED DOT 12 .......or OS 12 TZ.....
#8384
#8385
anntena
i changed antenna Bracket By NT1's
i guess glitch fault caused by carbon contact with antenna line or
aluminum(metal) contact with antenna line
NT1 336040 Graphite Receiver Bracket Set
i drilled 4.5mm and 3.00mm hole (expansion of preexistence hole)
i can not use Specktrum in Korea National
Because 2.4GHZ is illegl in korea RC law.
