Team Magic G4
#8341
Hi mike. I drive my g4s at the track. I haven't been able to make it to the track since the resurface and resealer. Let me know if I can help.
Hi all....
Getting ready for the nationals and was wondering if there is anyone out there that has run on this track at all with the G4s or the G4+?? Just want to see what they like with there car for that track , since i get there pretty late in the week and practice will be at a premium....
Mike Blackstock
Mike Blackstock
#8342
Aussies id recommend starting with 30000wt oil in the rear and 50000wt up front if using a diff up front.
#8343
Krafcik... Sounds good... Get there and run hehe....
Thanks for the info on the track... sounds like it is going to be fun lol...
Mike
Mike
#8344
korea kyosho cup win!
i participated korea kyosho cup in today.
i tried diff setup like darren, dario in Euro 2007
(front 100000, rear 40000)
But my G4S's rear Traction is some unstable in corner-in and corner-out when rear tire diameter was under 62-63mm..
i changed various setup to fix low rear traction.. But i could not find good setup.
after the race.. i quess front diff 100000 setup was not good at my finger..
i got 2nd position in Heat ( 1 sec difference with TQ guy)
i used kyosho CRF engine in this race..
it was very good in high speed.. and acceleration was also good..
But fuel efficiency was very Bad...
so i worry about fuel efficiency.. are there good tip for good fuel efficiency?
TQ quy(RRR) also used kyosho Orion CRF engine..
(he was very fast)
he also had trouble with bad fuel efficiency.
so TQ guy lost fuel time by bad fuel efficiency.
(i could get fuel time closely)
and i also had rear low traction problem after middle of the A-main Race
so i was passed by some racer..
But i tried extreme mind-control.. for no fault..
so i could win the race!!!
Winner: gansei(G4S) 99lap
2nd: Ki-youl Kim(NT1) 99lap (8 secs difference with me)
3nd: ki-yong Hong(720) 98lap
are there good tip for good fuel efficiency when use CRF?
(he was very fast)
#8345
Good going Gansei !!!
The CRF is a bit touch and go on efficiency from what i have been told by guys running them.
I believe the key is to run them a bit leaner than usual around 120dec/c very similar to how i run my Palmaris PR12 and Axial 12RR.
A high clutch engagment also contributes to fuel consumption as well as a 2nd gear changing early.
#8348
i run with total 0.3mm head shim(25% nitro fuel) in kyosho cup.
i used Ninja #6 plug. and pipe was CRF Orion Pipe.
i will test pipe MIELKE and novarossi pipe(EFRA-2630).
#8349
kyosho cup photo
kyosho cup data
#8350
hey gansei, you got pm
#8352
Hey guys, I know this question has been posted before but can someone post all the parts needed for the front differential using the ED transmission. Thanks a bunch
#8354
(he was very fast)
(he was very fast)
On the fuel consumption question.
Try this,
If motor is still prety new, put head shim to 0.35, 0.36 or so. Also the hotter plug, No:5 should also help.
Try putting a little 'Negative expo' on the throttle. Say 10%. (It all helps)
What can also help is setting the pressure line 3 times the length of the fuel line. Aswell as getting a more even pressure at the tank it can also help with fuel fuel efficiency.
Also, as pointed out. Make sure your car is not changing up to second too early as this makes the clutch slip and wastes fuel !
Hope this helps you and congratulation Gansei on your win sir !!
British Menace
#8355
congrat's Gansei....great job.....
