Old 09-19-2007, 06:24 AM   #8191
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by aussies1129 View Post
hi guys I am just putting the ed trans on my g4s and wanted to know is there a special way that the brake disc goes on its got a spiral pattern on it and when i spin it seems to catch just slightly on the pads should I back off on the hex screws abit?? I also notice there is no diff as such for the front when u put the ed on? whats the best grease for the rear diff?
thanks
the front axle is a one way, or solid spool. there are pins to lock the front outdrives. there is also a small grub screw inside those diff cups to lock the pins in hard. if you run a solid spool up front , be sure to make use of the grub screws or you could loose a pin. as for the rear diff, 10 000 fliud is a good start. depending onthe traction available at your track. the K Factory special bonded brake pads are a good thing to have as well, they have 2 small springs to keep the pads away from the disc. prevents any binding or drag. they work well.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-19-2007, 06:35 AM   #8192
Z00M's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Pattojnr View Post
i think you may have got an email from rc tech today Mike (ZOOM).
the big four 0. Happy Birthday man
I must have lied on the details Not 'till next year dude, and not in this month either.
Thanks though! Any birthday money would be welcomed!!! Do you think my wife will buy me something if I tell her that rctech says it's my birthday? Gotta be worth a try.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 09-19-2007, 06:50 AM   #8193
aussies1129's Avatar
Trader Rating: 74 (100%+)
HI Paul I have got the k pads so I will adjust out abit that should free them up thanks for your help!
Michael
aussies1129 is offline   Reply With Quote
Old 09-19-2007, 07:01 AM   #8194
Pattojnr's Avatar
thats where a wish list and reality list comes to work, just title them differently works for me. not that i get anything on either list. birthdays are a good way of buying that deserved present for yourself
pitty mine has been and gone. the M1B has just made the top of the new lists.
Serpent - Walter RC
Old 09-19-2007, 07:03 AM   #8195
RC-ProSpeed's Avatar
The 7T split is probably a bit much and will usually lead to stripping second gear. We run on a large track(60 metre front straight) and when we were using the standard trans, we ran 18/52 and 23/47 and sometimes the 51/46 spurs.
The Turbo II pipe will be holding you back for sure. It is not usually used as a full on race pipe. I would suggest you try a Novarossi 2630 or 2601 pipe with the 5 fin short manifold. This will give you much better performance and will increase your top end significantly. With the turbo II you are probably running out of RPM rather than running out of gearing.
Originally Posted by British Menace View Post
I would say this is right on the nose Pro-speed.
As Zoom says,
The pipe I think is restricting full breathing of your motor.
I would suggest the same, 2601 with either the medium (6 fin) or short (5 Fin) header.
Then see what you have on the track.
I would also say try to keep the gearing to 5 or 6 teeth....no more.
I would also get the ED Transmission. It's less arduous on the motor.
Regards,
British Menace
Thanks, I'll try with the 2601 with 5 fin header, and see if it gets better.
RC-ProSpeed is offline   Reply With Quote
Old 09-19-2007, 09:11 PM   #8196
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
can anyone recommed a good site to purchase a G4S? and whats a good engine to start with?
badKarma is offline   Reply With Quote
Old 09-19-2007, 09:34 PM   #8197
rudeboy's Avatar
www.racedayhobbies.com
rudeboy is offline   Reply With Quote
Old 09-19-2007, 09:42 PM   #8198
rudeboy's Avatar
JL Red Dot:cheap an runs like any order.
Old 09-20-2007, 05:49 AM   #8199
h guys I installed the kfactory transmission on my g4s and found that I have a bit to much play in the rear belt can this be adjusted somewhere?
thanks
Old 09-20-2007, 06:07 AM   #8200
Z00M's Avatar
There is a belt tensioner attached to the lower chassis. Use a 1.5mm hex driver to adjust the tension.
thanks
XRAY XB4
Old 09-20-2007, 06:21 AM   #8201
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
need help, what part number is the rear hub carrier flash style? is it this?
K14123-3
G4 Flash Pit Rear Hub Carrier
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 09-20-2007, 07:09 AM   #8202
I have looked all over the rear of the chassis and I cant find anything that may help to tighten the rear belt can someone help?
thanks
Old 09-20-2007, 07:22 AM   #8203
Z00M's Avatar
Dude, the attached pic is the belt tensioner. If you don't have it then you don't have a G4S or something else is wrong.
XRAY XB4
Old 09-20-2007, 07:26 AM   #8204
Pattojnr's Avatar
K14123-3
thats the one Frankie
thanks
im sure the RTR version of the G4S doesnt have the rear belt tentioner on it. you will need to add this on to the car. 502266-1 thats the part number for it
Serpent - Walter RC
Old 09-20-2007, 07:32 AM   #8205
hey Paul thats right no tensioner on the rtr if I could go back in time now I would not of bought this car in the rtr to many parts to upgrade??
thanks for your help guys! if I run it this weekend without it will that be a problem????cheers
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
