Old 08-28-2007, 05:31 PM   #8101
s10dude's Avatar
sorry to see and hear about the misshap....i use small rubber band on throttle to help in that kind of disaster..or TX w/failsafe...but i feel ya...been there done that...
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 08-28-2007, 11:14 PM   #8102
movingparts's Avatar
Hi Guys! Anybody interested with my g4s for sale? The kit is in Manila, Philippines.
http://rctech.net/forum/showthread.php?t=178355
movingparts is offline   Reply With Quote
Old 08-29-2007, 12:32 AM   #8103
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
wow can hijack selling here. i also letting go my G4S with Wasp Rev for only USD230, but item in malaysia.
uniquexme is offline   Reply With Quote
Old 08-29-2007, 12:45 AM   #8104
Lokanas's Avatar
Yeah, i know the trick. I just had to replace dead CRF (which has nice spring in carb) with this borrowed Mega and noone around had that rubber band
Anyway - the biggest mistake was leaving batteries as they were.
And actually after looking at the car i could say it's really durable. At full throttle head-on i expected something worse
Lokanas is offline   Reply With Quote
Old 08-30-2007, 04:47 PM   #8105
Default GLC setup
Sorry it took me so long to get it on here.. I have been sick lately .. If there are anymore questions please do not hesitate to ask...
it is in pdf format,,
Mike Blackstock
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 08-30-2007, 05:01 PM   #8106
s10dude's Avatar
thank's Mike for the file...hope you feel better...good to see ya on the forum...
Old 08-30-2007, 05:16 PM   #8107
rcrevolution's Avatar
Send a message via AIM to rcrevolution
I just picked up some twister tires, but I was looking into buying more pairs, I am ordering from raceday soon so I was wondering how good are the Kfactory tires?
also if I get the new style anti-roll bar off the g4+ do I remove the old one inbetween the a-arms ?
rcrevolution is offline   Reply With Quote
Old 08-30-2007, 05:47 PM   #8108
Wink
Well i guess the pdf did not work... So here it is typed out ...
2007 great lakes challenge setup
Front End...
Width 199 mm
Shocks... 60 wt oil 1.2 mm pistons
Spring.....1.7 mm
Shock position on the tower.... One hole in from the top
Shock position on the arm...... Outer hole.
Sway bar... Flat
Tire Shore/Diameter 40 / 58mm
Camber link speedshot front end ... middle setting
Camber .... LF 2.7 Rf 2.5
Ride height.. 5mm
Droop.... 2.0mm
Wheel base front... shims to the front
Rear of the car .......
Width..... 200mm
Shocks oil...... 40 wt 1.2mm piston
Shock Spring.....1.4mm
Shock location tower.. 2 hole in from outside...
Shock location on arm... outside hole..
Toe.... 3.5 per side
Camber link down on the bulkhead and 5mm spacers on the rear hub
Ride height 5.5 mm
Droop 3mm
Sway bar ... None..
Tires/Size..... 42 shore/60mm
Rear Diff lube.... 30000
Clutch...
Weights Red
Shoe Red
Spring mugen silver
Body protoform stratus
Wheel base 257mm shortend from the rear
if there are any more questions do not Hesitate to ask....or if i forgot something simple sorry...
Mike Blackstock
Old 09-01-2007, 10:15 AM   #8109
Default Tools Required
I don't have any metric tools so I was wondering if somebody could tell me what size hex wrenches and nut drivers I will need for the 4GS. Thanks.
Stroker Ace is offline   Reply With Quote
Old 09-01-2007, 03:22 PM   #8110
casimirsa's Avatar
1.5mm Allen
2mm Allen - I use a .078 instead as it fits more snug into the cap and grub
screws than a 2mm
2.5mm Allen and maybe 3mm Allen if you decide to change one or to of the screw to a larger size
"Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
TM G4S (ED), TM G4S,SERPENT M2+835+960FD, MUGEN SEIKI MRX4-X, MUGEN SEIKI MRX4 (WORLDS CHASSIS), MUGEN SEIKI MTX4, MUGEN SEIKI MBX5T, HPI PRO4, TAMIYA, PALMARIS, RB C5+C5 RODY+V12 RODY, NOVAROSSI, JP, AXE ROSSI, MEGA, NOVAMEGA KHM, KO PROPO, HITEC, GRP, UFRA, ROBITRONICS, SJ, LRP
casimirsa is offline   Reply With Quote
Old 09-01-2007, 10:58 PM   #8111
CaseyP's Avatar
Hello Mike
I have a shop in AZ and we are planning to add nitro sedan on to our race program soon. The track will be on a smooth parking lot which is 180 x 75
my question to you is..what extras will needed to build this car into super duper race car.
or is it race ready set out of the box.
CaseyP is offline   Reply With Quote
Old 09-02-2007, 06:48 AM   #8112
British Menace's Avatar
Originally Posted by CaseyP View Post
Hello Mike
Hi Casey,
Mike is unable to get on the forum as much as he would like.
I would say one of the essential upgrades for this car is the ED Transmission system, this really does make a difference to the car!
I would also ensure the gearing options are also available. These involve pinion and spur options.
There are improved gearboxes out now which are lighter and are also an improvement. Also many other options available.
Check out the G4+ Limited Edition. On the
www.teammagic.com.tw
site. As this car comes/came with 95% of all the option parts fitted.
Other then these, the G4s comes race ready straight out of the box with many 'race' options already on the car. In this guise the car has done very well time and time again.
What is a bonus is that any of the G4 line, be it RTR or the G4s, can be upgraded into a full race machine!
There are many other option which help to give extra tuning options, improve accessability and chassis stiffness.
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 09-02-2007, 07:46 AM   #8113
Z00M's Avatar
Trader Rating: 15 (100%+)
We had round 10 today of our club championship. Finally the weather was good to us, even if it was a little cool, it was much better than the rain we have been seeing lately.
I started out pretty poorly, still having radio issues even though I had changed to a lipo battery and changed the steering servo that I thought was the issue. Turns out, the throttle servo was no good as well, and this had me in the fence at the end of the main straight twice at full speed and a barrel roll across the infield that was pretty spectacular. The only damage was a chunked tire, a shock ball stud pulled out of the arm and the body is looking very second hand.
So by the third round of qualifying, I had a complete 5 min run and I was pleased and could start thinking about tyres and setup. In the fourth round with new tyres, the rear of the car was still very loose on turn in. Best lap up until that point for me was a low 17 sec lap.
I made some changes to the setup and redid my shocks as I think I may have used the wrong oil last time I built them. The car was instantly better from the start of the 10 min main. I was actually able to drive the car with some confidence which I haven't had for a while.
I had qualified 5th and I was 3rd behind Patto at the end of the first lap. I managed to get up on the tail of Paul but I didn't have enough in reserve to get by him. He was driving really well, even though he was down on engine power for the final. Since Paul was on all my apexes, I had to wait close behind him and see how things went.
Paul made the smallest mistake going on to the back straight and I got past before the next corner. I was able to make a small gap and we both seemed to gain a little ground on the leader but he had made good his escape by this time. At the end of the final, I was 3 sec behind the leader and Paul was only another 6 sec further back. So it was a good tight final with the first 3 cars covered by only 10 seconds.
I really enjoyed the second half of my day once I had gotten my radio issues under control finally. It has been a long time coming (probably 2 months since I had a clean run), and now I am looking forward to getting back to developing the setup (Paul had some interesting things on his car as well ) instead of dicking around with the radio gear.
Sorry for the long post, it just feels good to get back on the track.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 09-02-2007, 09:55 AM   #8114
Great. Excelent post Zoom!!
Congratulations to both you and Paul for both getting on the podium!! Just great.
I'm pleased you had a good day, in the end. It's so hard when you get a bad start like that to re-group and pull it together for the end.
Well done Zoom.
G4s (+) ? ----lol. Getting 2nd and 3rd ! That is a good day.
Congratulations!!
British Menace
Old 09-02-2007, 10:03 AM   #8115
gansei's Avatar
Congratulations Zoom and Paul !!
i had a great longing for the Race.
korea 1/10 engine race did not opened in 2-3 months.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
