Old 03-19-2006, 09:38 PM   #796
choisan's Avatar
Originally Posted by Motorman
yes it does. I tried that diff and it was so heavy I decided to use the gear diff. But thats just me.
Other than being heavy, is the rear diff better off in handling? How is it different in G4s compared to original?
choisan is offline   Reply With Quote
Old 03-20-2006, 12:19 AM   #797
Helix70's Avatar
Hi all,
I was wondering if someone would be so kind as to slip a digital vernier caliper around their G4 shock tower and tell me how many millimetres it is? I am trying to determine if they are the same as my Reflex Trinity shock, which is about 12.04mm in diameter. I need some new caps, and can get the G4 caps/bladders, but not the Trinity ones.
Josh
Helix70 is offline   Reply With Quote
Old 03-20-2006, 12:35 AM   #798
Car Breaker's Avatar
Originally Posted by Helix70
Hi all,
Josh
which part you refer to?
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 03-20-2006, 12:40 AM   #799
Helix70's Avatar
The diameter of the barrel, the part with the thread that the adjuster ring and top caps screw on to.
Thanks,
Josh
Old 03-20-2006, 08:36 AM   #800
Thanks,
Josh
Contact Trinity for those shock caps/parts... They have them in stock and can get them to you in no time... Or go with the Mugen MTX3/4 caps and bladders... They should fit the Reflex shock body... They work on the G4's and they don't leak.
RC_Alan
rc_alan is offline   Reply With Quote
Old 03-20-2006, 09:21 AM   #801
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default caps
just get the mugen shock caps thats what i used they worked well
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 03-20-2006, 04:02 PM   #802
Helix70's Avatar
RC_Alan
I did contact Trinity a week ago, still not heard a reply. I can't fnd the Mugen ones at rcmart, so I will try the G4 ones.
Thanks,
Josh
Old 03-21-2006, 10:28 AM   #803
blanks596's Avatar
Trader Rating: 14 (100%+)
Cool
what is going on with the G4. Trinity has the G4 c-class, Evo, and now there's an S-class. On top of that RD Logics has the mongoose and K-factory is involved in thee after market parts. I currently have a G4 evo with a kfactory 4mm chassis, the new rear carbon shock tower by kfactory, carbon brake bracket w/belt tensioner, kfactory alum brake lever, real racing brake pads with the new vent. disc brake by kfactory, new steering system, and the UFO clutch. I guess you could say that I'm trying to make this into an S-class as much as possible. Does trinity use Kfactory parts on this S-class is it their own brand of upgrades? Also are the front and rear bulkheads the same on all cars or is the S-class different?
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 03-21-2006, 10:51 AM   #804
NiMo's Avatar
This is the link for the conversion kit
Conversion Kit
Going by the photos the bulk heads are the same
NiMo is offline   Reply With Quote
Old 03-21-2006, 11:12 AM   #805
G4 is no longer under trinity. G4 Evo is packed as Mongoose and distribute by RDLogic. G4S is now under phenix Distribution.
Since you car has almost sll teh upgrade that come with G4S, all you need is the comvertion set, because anything that is not in teh convertion set are interchangable amoung all G4 series (G4 C,E,Evo,Mongoose,LeMan,S)
Xray X12 2015
ARC R10 ATS
Old 03-21-2006, 11:46 AM   #806
blanks596's Avatar
it's kind of hard to see but how different is the chassis? I have the Kfactory 4mm chassis. Will the new kfactory special chassis be the same as the G4s?
Max S
Old 03-21-2006, 01:18 PM   #807
I don't know the differences between the conventional Alu. chassis and the carbon reenforced chassis beside the price, but I know that the carbon reenforced chassis can be use in all G4 except that you cannot use the single bellcranck steering on G4S when using that carbon re-enforce chassis
Xray X12 2015
ARC R10 ATS
Old 03-21-2006, 01:39 PM   #808
BimmerDriver's Avatar
Default Brakes
When properly set up, are the brakes supposed to lock up solid? When I apply full brake with my radio I can still rotate the shaft, but with very stiff resistance.
BimmerDriver is offline   Reply With Quote
Old 03-21-2006, 02:56 PM   #809
4F1Racing's Avatar
It sounds to me you would need more brake. However you should base this on your drag brake, meaning when the throttle goes to closed position on the carb, what amount of brake you have to slow the car down. Course this amount would depend on driving style, but I think once you get your drag brake in line, at full brake it would be solid. If not, your servo saver was not correctly positioned on your servo. Must make sure your servo is set at neutral point ( equal distant to R & L turning end points ) then put your servo saver on with rods and start setting your brake and throttle points.
Without seeing your servo movement, this is a starting base. Others may be able to give more ideas.
Sam
4F1Racing is offline   Reply With Quote
Old 03-21-2006, 03:20 PM   #810
NiMo's Avatar
Drag Brake?
Do some racers still use this?
Guess coming from a shaft car I find the G4s slows quickly off power, I even had to reduce brake power as I was stopping too quickly.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
