Old 08-22-2007, 09:10 PM   #8056
dnitro's Avatar
Originally Posted by gansei View Post
lightweight my G4S!!!
this is my the best lightweight in G4S.
Gansei,
I thought you were gonna take a short break due to your big crash a couple weeks ago. Nice to know that you got everything sorted out and got your car back in race condition.
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 08-23-2007, 02:50 AM   #8057
razzor's Avatar
G4S drivers never say die
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-23-2007, 05:41 AM   #8058
Hello from France,
I was a little bit scared with the weight of this massive car design.
It's really a good car!!!
In Europ, the mini is 1700g without transponder, or 1720g with personnal transponder.
Some titanium screws, and the is good!!!
Bye
romuald31 is offline   Reply With Quote
Old 08-23-2007, 08:28 AM   #8059
gansei's Avatar
Default LIPO
LIPO Cell Balance..
is it required? or not?
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 08-23-2007, 08:35 AM   #8060
Pattojnr's Avatar
Trader Rating: 19 (100%+)
LIPO Cell Balance..
hey Gansei, i run the LRP 1500mah Li-Po, there is no balace charge plug on it, so i guess not. but i do suggest to use one if the battery has the plug to do so .
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-23-2007, 09:14 AM   #8061
gansei's Avatar
is 1500ma LIPO adapt on G4S?
i quess it is too big size to adapt on G4S
MY SPONSORS:
Old 08-23-2007, 09:16 AM   #8062
asil's Avatar
Send a message via MSN to asil
As far as I know, balancing is for li-po packs with 2 or more cells to equalize cells... So logic says no need for balancing for a single cell.. please correct me if I'm wrong...
Asil
asil is offline   Reply With Quote
Old 08-23-2007, 09:22 AM   #8063
otraver's Avatar
Send a message via MSN to otraver
Here are inclosed two pdf files.
- editable pdf with a blank G4+ setup sheet.
- editable pdf with the Juanito Hidalgo Euro 07 setup
Best regards
Octavio Traver
otraver is offline   Reply With Quote
Old 08-23-2007, 10:04 AM   #8064
razzor's Avatar
Thanks Otraver
On the lipo balance question ive been told that its not necessary for 2 cell but more so for 3 or more cells.
Then again if your pack comes with the balance plug then you can iether get a lipo balancer or charge each cell individually as the wiring on the balance plug is actually the individual cell wiring.
Casterracing ZX1.5R
Old 08-23-2007, 06:06 PM   #8065
Rawz's Avatar
What Razzor said. I use a 3S on my transmiter. And every time it goes under 10V, I the 3PK starts to scream, I check the voltage on each cell, and yes, they are unbalanced.
So I charge each one individually.
I think its a good idea to do so on a 2S too, if it does have the wires.
Rawz is offline   Reply With Quote
Old 08-23-2007, 06:25 PM   #8066
gansei's Avatar
yes.. you are right..
lipo charger cut the charging when voltage 8.4V (2cell base)
if two cell are unbalanced.... it could be one cell 4.4V + other cell 4V..
then 4.4V cell will be died!!! (expanded cell body)
MY SPONSORS:
Old 08-23-2007, 07:28 PM   #8067
bucknuts's Avatar
Originally Posted by romuald31 View Post
H
Bye
Or a lipo receiver pack should save 45+ grams
bucknuts is offline   Reply With Quote
Old 08-24-2007, 09:11 AM   #8068
Hey guys I'm new to Nitro and the G4 and I have a gearing question. My car is a G4S with the ED tranny. The track I'll be running on mostly is a fairly small track for nitro, 120'x60'. Will the stock gear ratio pinons/spur be fine for this size of track or should I be looking at different gearing? 1 straight the length of the track and mostly tight corners. Any help would be appreciated.
schurcr is offline   Reply With Quote
Old 08-24-2007, 09:21 AM   #8069
British Menace's Avatar
Depends on your motor but by the sound of it you need to come down a little on the gearing.
I would start at 15/20 Pinions and leave the spures stock 51/46.
You may find you need to go to 52 on first to get the quick darts out of the corners.
If the traction is high enough you can get some of that (acceleration) from a more aggressive clutch.
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 08-24-2007, 09:25 AM   #8070
British Menace
Are the 15/20 pinions the stock ED tranny pinions? I'm trying to order some parts from Texracer but want to make sure I order the gears that I need.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
