Old 08-21-2007, 06:00 PM   #8041
grub's Avatar
Originally Posted by JanisK View Post
Finally found what seems to be a reason for spectrum problems i was having lately.
Gansei, suggest you to check your antenna as well : )
i had the same problem.........
i replaced the wire havnt had a problem since ............
hope you have a steady hand for the soldering.
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 08-21-2007, 06:05 PM   #8042
grub's Avatar
Originally Posted by Pattojnr View Post
while im sure everyone is after a setup from the Euros, it sounds like it was a very hard week of racing, im sure they will post something soon, but lets give a bit of time for the recovery after such an event.
just on a different subject now, i had the smallest kiss of a wall on sunday, it resulted in a snapped front upper arm and cracked rear hub. now im not sure on the hub being done at the same time, but the arm just clean snapped. i know of another having trouble with the new arms breaking. seems the plastic is very brittle, where it has broken, the plastic looks grainy almost too hardened. this would have to be the first things i have broken in 6 months of racing. it was really the smallest of touches , just concerns me. anyone else had breakage issues ?
patto ive had a probem with frount lower pillow balls pulling out on the lightest impacked......
theres just no enough meat on the lower fly arms its happened twice to me once to edd and there low impact crashes,no problems with the top arms yet but the way i drive wont be long.......
Old 08-21-2007, 07:03 PM   #8043
TM Sean's Avatar
Hey Razzor did you get my PM?
Please let me know.
TM Sean is offline   Reply With Quote
Old 08-21-2007, 11:14 PM   #8044
asil's Avatar
Send a message via MSN to asil
Originally Posted by rcrevolution View Post
Hi guys, i took my car to its first professional track last week and I was doing great, only thing was my rear of the car bounces way too much, like around turns I get hundreds of tiny hops and I start to lose traction.
also my first lap after a cool down I could always grip 100% after that first lap I always started slipping more and more.
anyways my question is how do I fix this?
I was running completely stock out of the manual except for the height I was at 5.5mm rear 5mm front, and I was running 37 shore all around but kawahara fronts and GRP devil tires rear.
Please check diff outdrives.. box stock outdrives wear very fast and driveshaft pins make big grooves there.. when pins stuck in these grooves, car starts to wobble.. I installed K-factory hardened ones and no problems for 5 rounds of championship..
Asil
asil is offline   Reply With Quote
Old 08-22-2007, 12:05 AM   #8045
razzor's Avatar
rcrevolution the boucing on the back end could be a few things.
You could could go a bit thicker on the shock oil for more dampening or lighter spring.
Id suggest trying the spprings first.
Also have you built the shocks as per manual setup ??
If yes the thicker shock oil would help.
I use GS oil and 40/45wt is whats working best for me.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-22-2007, 03:56 AM   #8046
gansei's Avatar
Default lightweight G4S!
lightweight my G4S!!!
this is my the best lightweight in G4S.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 08-22-2007, 09:10 AM   #8047
rcrevolution's Avatar
Send a message via AIM to rcrevolution
whats stock on our cars again? 30wt all around?
and which color should I go to on the springs ? I have the stock silver ones on there.
Someone told me to add a bit more droop, would that help any?
and finally, I have been getting my spektrum to act strangely too, at the track in NY when I reved the car and tried doing tot eh stand the car would sometimes rev up hgiher than I pulled the trigger and out of the pit lane, kinda weird.
rcrevolution is offline   Reply With Quote
Old 08-22-2007, 09:12 AM   #8048
British Menace's Avatar
You may also have too much rebound when you built the shocks.
When checking, you need minimum rebound. This helps the shock use the oil viscosity to dampen the spring. With too much rebound, the air pressure above the bladder acts as another spring. Making the car bouncy.
When re-building the shocks. Have the shaft into the body about 1/4 to 1/3 in before you place the cap on.
Ensure all the shocks re-bound and compress the same when complete.
Hope this helps. It's just an idea but it sounds as though it could well be your shocks. Razzor's suggestions are also good and maybe what you need.
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 08-22-2007, 09:55 AM   #8049
gtrmx's Avatar
Wow!!! Could you tell us how you got to that low weight??? Or is it in a previous post??
Thanks!
gtrmx is offline   Reply With Quote
Old 08-22-2007, 10:03 AM   #8050
gansei's Avatar
Thanks!
titanum kingpin replacement -> about 20g weightlight
titanum boly replacement -> about 20g weightlight
LI-PO battery replacement -> about 20g-30g weightlight
i am using front diff.. if i change front one-way.. the total weight will be under 1600g
MY SPONSORS:
Old 08-22-2007, 11:38 AM   #8051
Jorge G's Avatar
Try this blue ones in front, stock ones in the rear. Droop 0 in front 4 rear
TC6
XRAY NT1/ Novarossi 353 Race Engine
F1 F104 Pro V2
Jorge G is offline   Reply With Quote
Old 08-22-2007, 11:42 AM   #8052
razzor's Avatar
Bud Bm is right it might be a pssoble cause of your problem.
I build my shocks and bleed the air out then when i place the cap on i push the shaft 1/2 to 3/4 way up and tighten down the cap.When tight i then release the shaft and see that it rebounds slowly to about 1/2 way.
Redo each shock till all feel the same.
Spend some time at the track with a selection of 30/35/40/45wt oil to try out.
I found GS 40/45wt very similar to associated 60wt
its a pity there is no standard to oils
Its one of those things that adds a ??? to trying other guys setups.
Casterracing ZX1.5R
Old 08-22-2007, 01:36 PM   #8053
Hello from France,
my #170 is ready to run now...
Maybe this Week-End, I will test the beauty.
http://www.yome3000.com/forums-lire.php?id=6684&f=4
Au revoir.
romuald31 is offline   Reply With Quote
Old 08-22-2007, 02:09 PM   #8054
Sow&Steady's Avatar
Surely you can go lighter than that my friend!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-22-2007, 02:43 PM   #8055
razzor's Avatar
Originally Posted by romuald31 View Post
Hello from France,
Au revoir.
Looking good there
Only one gripe i have is that you dont have Kfactory tyres on the car !!
Casterracing ZX1.5R
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
