Old 08-16-2007, 03:02 PM   #7981
Hello from France,
I continue my report...
http://www.yome3000.com/forums-lire.php?id=6660&f=4
The engine is break-in, the body wait the paint.... If the rain don't come, I test this beauty sunday..
Au revoir.
romuald31 is offline   Reply With Quote
Old 08-16-2007, 03:35 PM   #7982
charlesd's Avatar
Question for lippo packs.
Does anyone have a part # or a pack that fits the g4s? I want to see what the cost is to transfer over to lipo. I know nothing about batteries by the way so sorry for looking like a complete idiot on the subject.
I saw a venom pack on tower hobbies but not sure if this is the right thing:
http://www2.towerhobbies.com/cgi-bin...?&I=LXSFS7&P=7
charlesd is offline   Reply With Quote
Old 08-16-2007, 04:24 PM   #7983
British Menace's Avatar
Try these,
http://www2.towerhobbies.com/cgi-bin...&I=LXPCR8&P=SM
http://www2.towerhobbies.com/cgi-bin...?&I=LXJJF6&P=7
Regulator and 800mAh Li-Po.
Fits nicely into the arear where the stock battery fits.
You wont be able to use the stock battery mount and you will also have to dremel a little from the top deck. (I would dremel towards the front of the deck to make it fit.
Where you put the regulator is a personal choice. I put mine on the transponder mount. Run the connecting wires to the battery along the top of the top-deck. Have the wires from the battery come out from the top of the deck. Then they fit nicely to the reg'.
You may have to cut down the reg' wires as they are a little long and fit a connector to fit the battery connector.
Don't make the mystake I made...!... one day, in a rush I plugged the Li-Po charger in to the battery and started to charge, only to realize I was charging it through the regulator!!!
That ruined the regulator in a rush.!!
Hope this helps
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 08-16-2007, 06:31 PM   #7984
vc05hdt's Avatar
Originally Posted by grub View Post
i have the helios with spektrum i have radio problems as well on one part of the track the throtle servo goes dead and normal flat into the poly pipe....
i have canged batterys servos still every now an then it goes ....
usely into my 3 heat its starts playing up then if i top my battery up no problems........my battery 6.8 volts and 6.2 under load is that normal??
The voltage you are measuring is this measured bench test or ??? Getting the servos into fail safe position with Spektrum has been a pain once set. I would like a little adjustment getting it just right . Does anyone know easier way? Or else throttle return spring on order.
vc05hdt is offline   Reply With Quote
Old 08-16-2007, 07:04 PM   #7985
charlesd's Avatar
For a charger, is using something like this ok for charging a receiver pack?
http://www2.towerhobbies.com/cgi-bin...?&I=LXHNW5&P=7
Old 08-16-2007, 07:55 PM   #7986
That's fine. Made for the job
Old 08-16-2007, 07:57 PM   #7987
gansei's Avatar
no.. i suggest cell balance enabled LI-PO Charger..
http://www.all4rc.co.kr/shopimages/a...6009000002.jpg
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 08-16-2007, 08:05 PM   #7988
Ideally, I would also get a balncer. But you don't really need one.
Old 08-16-2007, 09:36 PM   #7989
bucknuts's Avatar
Default lipo
Here's what I use
bucknuts is offline   Reply With Quote
Old 08-16-2007, 09:41 PM   #7990
bucknuts's Avatar
Originally Posted by Pattojnr View Post
Gansei, quick rebuild there , glad to see.
now the li-po setup, i have concerns about the whole thing. last meet i ran the new G4+ and i encountered a problem that will always be in my mind. steering was tight and drained the battery quickly. now i am using the VXR reg 5amp, yes when the battery is low the red light comes on. at which point it is like cutting the battery wires off. i doesnt keep a supply of power to allow the failsafe to come in. it just plain cutts off all power to the reciever. now i was lucky enough to just be past idle, but if i was full throttle , then you know the end result
That's what a throttle return spring is for. (mechanical fail-safe) I also experienced the no power regulator cut, but only after running a discharged battery I forgot to charge for 5+ minutes!
Old 08-16-2007, 09:46 PM   #7991
bucknuts's Avatar
[QUOTE= Keep it insulated from the chassis and you will be OK.[/QUOTE]
Mounting it on its side like gansei or in the receiver location is good in this regard, I've raced some hella hot days this year and haven't had any issues.
Old 08-17-2007, 03:16 AM   #7992
TM Sean's Avatar
Any G4S RTR / G4S Lola/GTP RTR driver here??
TM Sean is offline   Reply With Quote
Old 08-17-2007, 04:02 AM   #7993
razzor's Avatar
Hey sean i have a Lemans for my son.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-17-2007, 06:40 AM   #7994
gansei's Avatar
Default G4S runing Video
i run my G4S in today.
i found front shock was broken.. so i fixed it..
you can see my renewal G4S run video in this URL:
http://www.mgoon.com/mulpi/Mov/Commo...spx?VID=923852
the end of backstraight (right wall).. is my G4S broken place!!
i tested Li-Po with Sanwa Specktrum.. and there are no problem!!
MY SPONSORS:
Old 08-18-2007, 12:49 AM   #7995
Hello from France,
I update a little my G4+ report (a time for fun, a time for work!! I just want fun....).
http://www.yome3000.com/forums-lire.php?id=6633&f=4
And I add another rewiew because I test a new low cost engine by JP Racing.
http://www.yome3000.com/forums-lire.php?id=2642&f=5
If you want discussing about the engine, go to JP Racing thread.
Au revoir.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
