Old 08-16-2007, 08:07 AM   #7966
gansei's Avatar
Originally Posted by razzor View Post
good to see you sorted out gansei
What regulater are you using ??
it is much-more regulater (7.4V 5A for 1/10 engine touring)..
but i found LRP regulter is more smaller and chiper than Much-more..
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 08-16-2007, 08:10 AM   #7967
gansei's Avatar
Originally Posted by Kodak Hodak View Post
you amaze me al the time, thou id like to know why you screw your shock adjustmets so far compressed?
are those Knack shocks shorter than normal g4s?
cool light in battery pack this for fun or indication that its alive?
i am using mugen spring..
mugen spring is more shorter than G4S.. so shock adjustment must be more compressed than G4S's
i did same Knack Shock length setup with G4S Shock length.
i expect the light will be changed to Red when Battery is low..
But it is only my Quess
MY SPONSORS:
Old 08-16-2007, 08:40 AM   #7968
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Gansei, quick rebuild there , glad to see.
now the li-po setup, i have concerns about the whole thing. last meet i ran the new G4+ and i encountered a problem that will always be in my mind. steering was tight and drained the battery quickly. now i am using the VXR reg 5amp, yes when the battery is low the red light comes on. at which point it is like cutting the battery wires off. i doesnt keep a supply of power to allow the failsafe to come in. it just plain cutts off all power to the reciever. now i was lucky enough to just be past idle, but if i was full throttle , then you know the end result
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-16-2007, 08:41 AM   #7969
Gansei, Who makes the wire handle that you have on your car? I can't stand the floppy plastic one that comes with the kit & want to change it.
GBagRacing is offline   Reply With Quote
Old 08-16-2007, 08:53 AM   #7970
gansei's Avatar
do you mean the metal roll-bar?
it is Kawahara RRR roll-bar..
i modified it to fit G4S.
MY SPONSORS:
Old 08-16-2007, 08:57 AM   #7971
gansei's Avatar
and you need this parts: Serpent 902115 (Thank Support Alu-Rubber Sleeve)
MY SPONSORS:
Old 08-16-2007, 09:59 AM   #7972
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Hey Gansei, let me know how ya go with the New Battery, now lets hope for your sake you dont get another run-away.... its not a good thing for poor G4S/G4+ to get so bruised
got part number on LIPO battery and from where you buy? link
cheers champ -
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 08-16-2007, 10:27 AM   #7973
charlesd's Avatar
GBagRacing , you can also use the 3racing g4 roll bar. It's almost the same.
That is what i have in mine and it works well.
http://www.3racing.com.hk/x_descript...oducts_key=372
charlesd is offline   Reply With Quote
Old 08-16-2007, 10:38 AM   #7974
casimirsa's Avatar
cheers champ -
That battery look a lot like the one I'm going to install tonight!
I'm using the the battery that fits into my E-Flite LAMA heli! it the only battery that fits decent! least amount of cutting of the radio tray!
"Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
TM G4S (ED), TM G4S,SERPENT M2+835+960FD, MUGEN SEIKI MRX4-X, MUGEN SEIKI MRX4 (WORLDS CHASSIS), MUGEN SEIKI MTX4, MUGEN SEIKI MBX5T, HPI PRO4, TAMIYA, PALMARIS, RB C5+C5 RODY+V12 RODY, NOVAROSSI, JP, AXE ROSSI, MEGA, NOVAMEGA KHM, KO PROPO, HITEC, GRP, UFRA, ROBITRONICS, SJ, LRP
casimirsa is offline   Reply With Quote
Old 08-16-2007, 10:56 AM   #7975
gansei's Avatar
this is my Li-Po Battery... E-SKY.. it maybe Chinese product.
and you must cut off upper-dect to put Li-Po Battery
and... i fixed the battery by shoe-goo
MY SPONSORS:
Old 08-16-2007, 11:09 AM   #7976
razzor's Avatar
Thats why the batts i got seem a bit big.
I have 1800mah lipo want to rather have some capacity in reserve.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-16-2007, 11:10 AM   #7977
duneland's Avatar
Regarding LiPo; When fully charged a 2 cell pack will measure 8.2 volts +.
It will not drop much under the loads applied. Most receivers will handle that no problem. Many servos will not. Many get by without the reg. But you are gambling. Highly recomend the use of a regulator.
Another thing to consider is heat. LiPo packs will fail if they get over 140 degrees F. I lost one this season after making up a brass holder. Brass holder was attached directly to chassis and conducted heat from the engine. In a long race, chassis gets pretty warm (especially when track temps reach over 140 degrees). Keep it insulated from the chassis and you will be OK.
duneland is offline   Reply With Quote
Old 08-16-2007, 11:54 AM   #7978
Rawz's Avatar
You use the mugen front spring ? Using the rear springs would not be better ?
Or are the rear shorter than TM, also ?
Rawz is offline   Reply With Quote
Old 08-16-2007, 12:28 PM   #7979
gansei's Avatar
i tested mugen rear spring on G4S Front Shock..
But i did not like it.. i felt front shock was fall down
mugen rear(long) spring is longer than TM's
i am using mugen spring in front shock..
and serpent spring in rear shock.
MY SPONSORS:
Old 08-16-2007, 12:45 PM   #7980
Sow&Steady's Avatar
you are right!!!!
i checked my NIMH battery Volt after big crash in yesterday..
the battery volt was 6.2V.
when battery volt was under 6.0V, maybe my throttle servo was stopped.
i tested US Specktrum in long time ago.
heavy servo activity(about 30-40 secs).. i could see steering servo did bad working.
so i can quess this..
when battery is under 6VOLT.
1. US specktrum: steering servo do bad working.(random work)
2. sanwa(airtronic) specktrum: stopped Throttle servo activity.
One other thing I'd recommend is that when you bind the system, always set the throttle and steering on the Tx to your failsafe position. I notice that not everyone is doing this and even the recent article on RC Car Action magazine did not show this.
This is something I do without fail and twice it has saved my car. I've been using the Spektrum on my M8 Airtronics/Sanwa system since the very first spetrum unit was available for it and never had glitches (maybe I'm lucky) other than the battery running below 6v ... interestingly, both time with my VXR LiPo set. Maybe I need to get a better charger with balancer for it.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
