Old 08-15-2007, 04:56 PM   #7951
British Menace's Avatar
Hi All,
I installed a Li-Po 800mAh pack in my car just two or three weeks ago and I haven't had a single glitch or any cause for worry since.
Until then, I had the odd time the servo's, usually just the throttle servo not work, or stay open.
This really made me nervous and I came out of one or two qualifiers because of this.
But since the Li-Po has been in..........No isues at all.
I do not believe you need to run a regulator as there is no chance of the Li-Po going above 7.4V. And the servo's can handle that Voltage.
Although, in retrospect, it's probably safer to have one installed. I just don't believe its mandatory.
We ran at the GLC without any regulators on our cars.
British Menace
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 08-15-2007, 05:13 PM   #7952
razzor's Avatar
BM you can run with out a regulator but the problem is when you charge the pack you have to let its sit a whilefor voltage to settle but before a main you dont have that luxury.I ran with out on my buggy for almost 6 months and it was cool till during a nat i had to peak before a main and when i plugged it in i fried the throttle servo, when i changed the radio tray from a buddy quickly i fried another.Since then i use a regulater and have never had any issues.The VRX regulater also has a LED indicator that turns red from green when battery is low.Cuts off at 6.2v.
Lipo for the TX is awesome aswell and would highly recommend it too.
BM how about a pic of how you mounted your lipo batt.
1800mah pack i have seems too big.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-15-2007, 06:12 PM   #7953
Rawz's Avatar
Look this at 3Hobby.net.
3Hobby.net G4S+LiPo
Hope there is no rule about links :-)
Rawz is offline   Reply With Quote
Old 08-15-2007, 08:38 PM   #7954
bucknuts's Avatar
Originally Posted by Rawz View Post
I have glitches with my 3PK+Spektrum too. But it cost me only a rear A-arm and tires, till now ...
I changed batteries, checked antenna, nothing. I have a telemetry, I forgot to unplug that to check.
I use two Futaba 9350.
For me it seams that there is, some times, a big current draw, thus making the Spektrum go into voltage fail-save.
My control stops for a moment, and then comes back.
If thats the case(current draw bigger than the Ni-MH can handle), the Li-Pos should cure that, right ?
To use a Li-po pack I need a regulator. I saw one used some post back ? Was Razzor's ?
That is the problem with the 2.4 systems. The solution is an 800mah lipo pack, preferably with regulator so it doesn't go below 6V. Or fabricate an 2/3A pack and bracket. Runtime should also increase with the regulator since the battery is rated at 7.4V. The bonus is losing 40g or so of weight and not having to cycle the pack.
bucknuts is offline   Reply With Quote
Old 08-15-2007, 11:30 PM   #7955
gansei's Avatar
you are right!!!!
i checked my NIMH battery Volt after big crash in yesterday..
the battery volt was 6.2V.
when battery volt was under 6.0V, maybe my throttle servo was stopped.
i tested US Specktrum in long time ago.
heavy servo activity(about 30-40 secs).. i could see steering servo did bad working.
so i can quess this..
when battery is under 6VOLT.
1. US specktrum: steering servo do bad working.(random work)
2. sanwa(airtronic) specktrum: stopped Throttle servo activity.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 08-16-2007, 12:55 AM   #7956
grub's Avatar
Originally Posted by gansei View Post
you are right!!!!
i have the helios with spektrum i have radio problems as well on one part of the track the throtle servo goes dead and normal flat into the poly pipe....
i have canged batterys servos still every now an then it goes ....
usely into my 3 heat its starts playing up then if i top my battery up no problems........my battery 6.8 volts and 6.2 under load is that normal??
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 08-16-2007, 02:55 AM   #7957
razzor's Avatar
current delivery with a AAA cell is the limitation especially with higher end servos and digital.I havent had any glitches though (touch wood ) maybe because i made a new pack up for my car with 1000mah Sanyo cells and thicker gauge wire.
Lipo is teh way to go though, its better in every aspect only downside is the regulater and a lipo charger really but well worth it.
Thanks RAwz for the link, pictures speak a thousand words
Casterracing ZX1.5R
Old 08-16-2007, 05:00 AM   #7958
Pattojnr's Avatar
Trader Rating: 19 (100%+)
well all airfares are booked and payed for, accomodation booked and a hire car sorted. ill catch up Frankie at the Aussie Nationals in October. we can exchange a few ales then
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-16-2007, 05:36 AM   #7959
aussies1129's Avatar
Trader Rating: 74 (100%+)
Default hex key sizes for g4s?
Hi Guys,
would anyone know of the sizes that I need for my g4s in regards to hex keys?imperial or metric?
thanks
Mick
aussies1129 is offline   Reply With Quote
Old 08-16-2007, 05:46 AM   #7960
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by asw7576 View Post
Yo gansei, Drill 4mm hole for antenna wire, cover it with gas tank rubber o ring, and let the antenna wire pass through that gas tank rubber o ring. For antenna holder, you can get it from tamiya or yokomo antenna holder. I think xray t1 or t2 car also use plastic antenna holder.
Secondly, Cover the receiver with ballon and use two extension cables ; 1 for battery power, and 1 for transponder connection.
I had the same problems like him and when i did the mod with tubing the problem was gone. I then did it with a plastic spacer which holds the antenna tube on better. I also noticed that you cant let the antenna touch anything...I mean anything. Its gotta come out the receiver and into the tube without touching anything..I too did the extension so i wouldnt have to touch the receiver alot.
I always looked at gansei car and couldnt believe he didnt have problems using the aluminum antenna holder.
As for the battery draw i dont think its that. I have been using spektrum for 2 years on my offroad stuff with nicd and nimh packs and never had 1 glitch. The pack on my buggy was a cheap ofna 800 pack.
nitrobeast is offline   Reply With Quote
Old 08-16-2007, 05:50 AM   #7961
razzor's Avatar
Originally Posted by aussies1129 View Post
Hi Guys,
thanks
Mick
You can double check in the manual, it has a list.
1.5mm
2mm
2.5mm
3mm
4mm
5mm
is the most popular hexes to have in your tool box/bag
Good to have some nut drivers too
5mm
5.5mm
7mm
is teh popular sizes
Casterracing ZX1.5R
Old 08-16-2007, 07:31 AM   #7962
gansei's Avatar
thanks for your advice..
i already did antenna tip about 6 months ago.
i will change Li-Fo battery!!
MY SPONSORS:
Old 08-16-2007, 07:33 AM   #7963
gansei's Avatar
Default my G4S is back!!!
i changed Li-Fo battery.. (800ma, 7.4V + regulrator)
i will test my G4S in tomorrow
my G4S was re-born!!!
MY SPONSORS:
Old 08-16-2007, 07:40 AM   #7964
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
you amaze me al the time, thou id like to know why you screw your shock adjustmets so far compressed?
are those Knack shocks shorter than normal g4s?
cool light in battery pack this for fun or indication that its alive?
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 08-16-2007, 07:54 AM   #7965
razzor's Avatar
good to see you sorted out gansei
What regulater are you using ??
Casterracing ZX1.5R
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
