Old 03-15-2006, 09:56 AM   #781
g4-racing.de's Avatar
Default build the g4s
Hello from germany
i have build my g4s ready and he is waiting for the set up.
Some things i found by building the car......
Can you tell me something about this???
The side belt is scratch the batterie Pack and the chassie plate!!!!!
This is not ok and negativ by race...... the car.
What have you do???
Sorry for my bad english but it was a long time ago i went to school
Marc
g4-racing.de is offline   Reply With Quote
Old 03-15-2006, 10:08 AM   #782
yes the belt can get up against the side of the battery pack just slightly but we have not seen any issue with the belt wearing or the belt wearing on the battery pack. the belt tends to run to the outside of the pulley and so far we have had no issues of any kind nor have I had anyone tell me or show me a belt wear or pack wear problem. If it becomes an issue for you let us know.
One thing you need to do is push inward on the battery then tighten the screws to the top deck so it is sitting inboard. Once the mount takes a set it will stay that way.
Motorman2 is offline   Reply With Quote
Old 03-16-2006, 12:15 AM   #783
Default g4s
Hello
Ok i will do this for the problem with the Battery,but whta can i do by the problem with the chassie??????
I mean that the belt blow up by driving the car and then touch the Plate....
yes the belt tends to run to the outside of the pulley but it looks so that it is not enough .........
I will see when i run the car next week because the weather in germany is a little to bad...
MaRC
Old 03-16-2006, 01:11 AM   #784
NiMo's Avatar
Belt does run very close and sometimes touches, same with the front belt on the upper chassis frame, but this is only light touching.
The RRR I had the side belt was always rubbing on the exhaust manifold, but even that did no damage to the belt (put a hole in the manifold though after 5 meetings).
NiMo is offline   Reply With Quote
Old 03-16-2006, 08:15 AM   #785
Marc
I assure you will have no belt issues. The chassis on the side has not changed in its outside profile and the belt location has not either. In 5 years it has never been an issue with the chassis wearing on the side belt. However you will se a small line that develops in the center of the belt. (relax its not the belt) Its caused by rubber from the tires being squeezed through the space between the two belt tensioner bearings. It creates a line of rubber on the belt. If you wipe it down with some alcohol you will see it comes right off. LOL
Old 03-16-2006, 09:21 AM   #786
Default quiting the hobbie, 2 g4 for sale with rex, os, max pipe, all hop ups
Originally Posted by Motorman2
Marc
getting out,for sale 2 g4, running cars, box load of tires, parts, 2 chassis, remote, s box i can email pics, thanks guys 600usd everything
jrfocker is offline   Reply With Quote
Old 03-17-2006, 11:02 PM   #787
XTREMERCHOBBIES's Avatar
Hi! Do you guys have a good set up for one way? Pls. post some of your set up sheets in the thread. Thanks!
XTREMERCHOBBIES is offline   Reply With Quote
Old 03-18-2006, 06:45 AM   #788
choisan's Avatar
has anyone tried to run with the rear ball diff in the 4S? I just onder how it is different in 4S?
choisan is offline   Reply With Quote
Old 03-18-2006, 08:23 AM   #789
4F1Racing's Avatar
For the lastest setup which is with a one way and a solid axle, just a change of springs it seems was the difference. I have this on my website... www.racedayhobbies.com and click on the setup page.
Hope this helps you.
Sam
4F1Racing is offline   Reply With Quote
Old 03-19-2006, 03:19 AM   #790
i got 3 questions regarding the g4s:
1 are those new shocks or just the old ones anodised silver???
2 how would it rate handling wise against the rrr and the mtx-4???
3 how much is it in $aud ????
ae_ntc3 is offline   Reply With Quote
Old 03-19-2006, 06:41 AM   #791
maskedrider's Avatar
wondering if it's cheaper to get G4s in Singapore??
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 03-19-2006, 08:17 PM   #792
Motorman's Avatar
Same shocks
That depends on who you ask
You will need to check with the AUS distributor.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 03-19-2006, 08:18 PM   #793
Motorman's Avatar
3 weeks and us northern guys get to start playing again.
Old 03-19-2006, 08:51 PM   #794
choisan's Avatar
Hi Motorman,
May I know if the rear ball diff fits the G4S?
Thanks!
Old 03-19-2006, 09:26 PM   #795
Motorman's Avatar
yes it does. I tried that diff and it was so heavy I decided to use the gear diff. But thats just me.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
