Old 08-11-2007, 07:30 AM   #7906
British Menace's Avatar
Good info' on the + (plus) rear end of the car guys.
I also noticed this about the CVD length.
I have not yet tried the short (Old stock) setting for the bottom hinge pins.
I understand Ben (Bucknuts) ran the car using this shorter rear arm setting at the recent GLC to good effect.
He had to cut down the length of the arm though to get to legal width. But it can be done.
Just a little theory for you guys concerning these new lower pin positions.
Inner pin hole (longer arm) will give the arm a wider arc, hence, --helping-- to keep the suspension movement more vertical.
There is no difference in "swing-axle-lengths" when choosing one or the other. In other words, roll centre hights are not effected when changing from one to the other.
With the different arms though there is some difference to stock concerning leverageon the spring.
Checking length from hinge pin hole to shock mounting position you will see the two options are now either side of the stock length/ shock mounting position.
You can see leverage for yourself on this as follows:
"A" = hinge pin hole to shock mounting position on arm
"B" = Hinge pin hole to centre of pivot ball when mounted in the arm and at the correct position for correct wheel track (width)
Then simply leverage on the spring is B divided byA
You can then see the difference in leverage of the positions we now have.
Some simple theory for you. As I've said before interesting to some, not to others.
Try doing this at home though, leave track time for the practical stuff.........use what works there. Understand why at home
Best of luck
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 08-12-2007, 03:15 AM   #7907
aussies1129's Avatar
Trader Rating: 74 (100%+)
Default telemetry for g4s
hi
would anyone know if spektrum telemetry fits in a g4s somewhere??
thanks
Michael
aussies1129 is offline   Reply With Quote
Old 08-12-2007, 03:59 AM   #7908
grub's Avatar
Originally Posted by aussies1129 View Post
hi
thanks
Michael
yes you can make it fit
first you will need to make a y wiring harness if you are using your own transponder .........
i took my 5th post off and mounted it there,if your not using a transponder you can mount it there ........
hiding the wiring is a pain thou.......
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 08-12-2007, 06:48 AM   #7909
Z00M's Avatar
Trader Rating: 15 (100%+)
I use the spektrum in my car. I use the 4mm chassis, and made up my own top cover from lexan and use the standard lower cage and it all fits neatly in the standard position.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 08-12-2007, 07:57 AM   #7910
hey zoom any chance on getting a photo to see how and where you put it all?
thanks mate
aussies1129
Old 08-12-2007, 05:22 PM   #7911
Z00M's Avatar
I'll see what I can do.
XRAY XB4
Old 08-13-2007, 09:14 AM   #7912
Jorge G's Avatar
Default Spektrum telemetry position
hi
thanks
Michael
I used to place mine in the spot left in front of the receiver battery
TC6
XRAY NT1/ Novarossi 353 Race Engine
F1 F104 Pro V2
Jorge G is offline   Reply With Quote
Old 08-13-2007, 10:31 AM   #7913
razzor's Avatar
OK guys to clarify, the following is the difference between the UFO clutch and the new UFO2 clutch as well as parts for std and ED transmission.
K1497-5 clutch shoe is changed to the K14133-2 clutch shoe
K1497-4 clutch shoe mount is changed to K14133-1
This is only difference between the UFO and UFO2 clutch setup and is a easy upgrade.
UFO2 clutch kits are available for std transmission and ED transmission.
The part numbers are :
K14133 ED UFO2 clutch set
K14137 Std type transmission
For the Std transmission the following clutch bell and pinions are needed :
K1497-8 Clutch bell/housing
K1497-12 ally clutch bell/housing
K1491 20t 1st gear pinion
K1490 19t 1st gear pinion (std)
K1489 18t 1st gear pinion
K14113 25t 2nd gear pinion
K14112 24t 2nd gear pinion (std)
K14111 23t 2nd gear pinion
For the ED transmission the following clutch bells and pinions are needed:
K14122-15 ED 15t 1st gear pinion
K14122-16 ED 16t 1st gear pinion (std)
K14122-17 ED 17t 1st gear pinion
K14122-20 ED 20t 2st gear pinion
K14122-21 ED 21t 2st gear pinion (std)
K14122-22 ED 22t 2st gear pinion
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-13-2007, 05:17 PM   #7914
Z00M's Avatar
hi
thanks
Michael
Sorry about the confusion with my post - I thought you meant the normal spektrum receiver.
I have not tried to fit the telemetry option to my car.
XRAY XB4
Old 08-13-2007, 06:30 PM   #7915
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Great Car.
I had to get out of Nitro Sedan Racing and have ALOT of parts new in the package for this car.
I even have alot of K Factory Parts.
If you need anything let me know.
50% off new still in the package.
Les
TexRacer is offline   Reply With Quote
Old 08-13-2007, 11:04 PM   #7916
asw7576's Avatar
Two pages went by...... where is Gansei ??
Hey Gansei.... where r u ?
Old 08-14-2007, 01:39 AM   #7917
razzor's Avatar
You read my mind
Saw him briefly on 3hobby yesterday.
Casterracing ZX1.5R
Old 08-14-2007, 04:00 AM   #7918
Hello from France,
Little update...
http://www.yome3000.com/forums-lire.php?id=6633&f=4
romuald31 is offline   Reply With Quote
Old 08-14-2007, 05:28 AM   #7919
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Maybe Gansei has a break just like us from our racing down under..... damn almost 6 weeks and no racing its killing me... but wait this weekend we all back into it full steam ahead....
Shall be interesting to test the new added fly arms up front....
Oi yeah HELLO EVERYONE
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 08-14-2007, 05:49 AM   #7920
casimirsa's Avatar
DUDE, six weeks of rc racing! Try six weeks of rain so much so that not even the rc boats goes out!
Not so far south thow! but semi down under
"Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
TM G4S (ED), TM G4S,SERPENT M2+835+960FD, MUGEN SEIKI MRX4-X, MUGEN SEIKI MRX4 (WORLDS CHASSIS), MUGEN SEIKI MTX4, MUGEN SEIKI MBX5T, HPI PRO4, TAMIYA, PALMARIS, RB C5+C5 RODY+V12 RODY, NOVAROSSI, JP, AXE ROSSI, MEGA, NOVAMEGA KHM, KO PROPO, HITEC, GRP, UFRA, ROBITRONICS, SJ, LRP
casimirsa is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
