Team Magic G4
#7846
Mikes qualified in 6th place at the GLC..... go Mike
Anyone else running a G4S/+ ???
#7847
the rain stayed away today, and i got to run the G4+ today. i started basically kit setup, and worked on it from there. i played with springs and shock positions today. the rear end was taily early ended with the 1.2 spring on the rear and 1.7 on the front. i managed my fastest times today, both 5 in heat and fastest lap i have done. unfortunately, my Li-Po didnt with stand the heat today, the reg cut out 4 laps into the final where i had a very good chance for a win. will work on maintaining this battery setup a bit better in the future. ended 10th overall . but very pleased with the G4+ so far.
#7854
rather leave the std one and have reliability.
If you want to play with front end traction then try the speed shot front end.
It is more expensive but well worth the effort for access to teh diffs and fron roll centre.
The std roll center setting though i find is best.
#7855
Mains for the GLC were rained out. Too bad b/c my final two qualifiers ended early while I was on 15 5:10 or better pace, due to broken engine to manifold springs. Car was really running well and I was looking forward to a possible bump -up. Apparently the picco engines require a longer spring here?
#7856
Hey guys
I had a great day today. Qualified 3rd in the A-main and finished in 2nd!!
I was having a hard to keeping the back end together at the exit of the last turn into the straight.
In our 8 week point series im in 2nd with one week to go..
I wanna thank everyone who has help me make this G4S a great driver.
But i still have some questions. Can someone explain front and rear camber to me and the pros and cons?
#7857
Bud dont bother with the ally arm the plastic inserts strip.
#7858
the speedshot front end has front roll centers to change. there are 2 different settings to try other than the stock setting. they both do make a difference, thats for sure. i have tried all 3 settings and i prefer the middle setting. if you were to update to the new arms as well, you can have a shorter wheelbase and more caster settings to try out as well. the smallest adjustment can sometimes make the biggest differences.
#7859
#7860
roll centers change the way the car reacts to directional changes. there are inserts for the top hinge pins on the speedshot front end. there are 3 settings to choose from. one gives a bit more mid corner on power steering, and one gives a faster steering response. the other is stock setting for the G4S. as far as wheelbase changes, this shortens the distance from the front and rear wheels. therefore changes the way the car is balanced over the front or rear wheels. this also gives you more tuning ability to get more front or rear end grip. the new style rear hubs are also good for easy rear roll center adjustments. so many choices i know, but all add up to a better setup car in the end. one thing id do is run down your spares you have now, and start replacing them with the new parts available, so it wont really cost anymore, just means your slowly updating your car when you feel comfortable doing so.
