Old 03-13-2006, 01:04 PM   #766
NiMo's Avatar
CarBreaker
How do you get on with the pipe?
I had to use another make as I couldn't get my motor to rev with it.
NiMo is offline   Reply With Quote
Old 03-13-2006, 01:21 PM   #767
I measured my G4S tank at 80ml... I'm hoping its my beaker that was inaccurate.
Lycan is offline   Reply With Quote
Old 03-13-2006, 02:23 PM   #768
Car Breaker's Avatar
Originally Posted by NiMo
CarBreaker
well, I don't know the full potential yet, My engine is relatively new and most of time I have it on the rich side. my engine is cold (never exceed 200F with 20% nitro and O.S. P3 plug) so I really can't tell the full performance of it
I will lean it up I have chance to run it next time. and give you a report on it
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 03-13-2006, 03:18 PM   #769
Motorman's Avatar
lycan we've been teched a zillion times at big events and I can assure you they are 75 cc. However it can depend on the temp of the fuel to.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 03-13-2006, 03:21 PM   #770
NiMo's Avatar
I found that I could not lean the motor properley as it appeared to run hot and lean, I put an old dented Max Power pipe on it and was able to lean the top by half a turn and the bottom by a quarter, the motor now revs more but runs much cooler.
Old 03-13-2006, 07:10 PM   #771
XTREMERCHOBBIES's Avatar
Hi Guys! Just want to share with you that we placed 3rd in our club race last week against pack of Mugen Mtx4's. We found the right set up for the car, finally
For those running 1way here's our set up:
Front
Shock oil - 45wt
Shock piston - 2 holes
Springs - Orange 1.8
Shock Tower - 2nd hole from bottom
Camber - 2deg
Toe out - 1
caster - 3mm in front
Stabilizer - 0 deg
Rear
Shock oil - 45wt
shock piston - 3 holes
Shock tower - 2nd hole from bottom
Camber - 4 deg
Toe in - 2 deg
stabilizer - 90 deg
diff oil - 10k
rear hub - bottom hole
alum stiffener - bottom hole
Hope this helps
http://www.rctech.net/forum/showthread.php?t=30425
XTREMERCHOBBIES is offline   Reply With Quote
Old 03-13-2006, 10:10 PM   #772
jihernandez's Avatar
Default My New G4S
Just got my new G4S from ExtremeRCHobbies and started building it out last night. Have finished building the front portion of the car and I am very pleased with the quality of the parts. Can't wait to finish it and try it out in the track.
Though have yet to put it up in a set-up board, twas pretty wierd that the 68.5mm length of the steering turnbuckles was supposed to be the stock set-up which was coupled with 4mm distance from steering hub and upper steering arm and 3mm for the bottom yielded a huge toe-out. Well, I guess will just have to finish the car and "Hudy" it.
Another thing that I noticed is the drivertrain quality. Everything seems to be very flush and not too loose which should result in a very efficient drive train. My R40's drivetrain was very loose in such a way that if you push the car without the motor, it will glide all the way. The G4S seems not to be the case - or probably it needs to be run-in first.
Overall, I am very very happy with the car and can't wait to run it in the track.
Looks like I will be retiring my R40 for good
jihernandez is offline   Reply With Quote
Old 03-13-2006, 10:30 PM   #773
well, my friend has a 12tz 5pwith the same missile pipe, his engine is much hotter like 240F, we both run it with the shortest setup and it seem that 18tz
have better luck with it
btw, have you try making it longer and see the difference?
Xray X12 2015
ARC R10 ATS
Old 03-14-2006, 06:55 AM   #774
NiMo's Avatar
Worked best in longest length, but was down on top end (see video)
Old 03-14-2006, 07:12 AM   #775
Local racer's Avatar
Default Quality
This kit builds incredible I think evryone will be suprised by the quality of this car.
http://www.tqracing.net
Local racer is offline   Reply With Quote
Old 03-14-2006, 04:26 PM   #776
RayJ's Avatar
Default Steering Knuckle Ackerman Position
One huge tool for steering adjustments is the ackerman position on the steering knuckle. These set-ups that people are posting are really good for al of us. Please also include the ackerman used on the steering knuckles. I guess for most it will be the stock position.
RayJ is offline   Reply With Quote
Old 03-14-2006, 04:42 PM   #777
Originally Posted by Motorman
Rumor has it Ted the toledo Hammer bought a G4S Uh OH!
This does not surprize me While in FLA.Ted was telling myself and some other Morr guys that he really like the new car look and was going to get one!!!
rc racing dude is offline   Reply With Quote
Old 03-14-2006, 06:04 PM   #778
Default nice looking g4s
custom made g4s...looking nice!!!
more info:
http://www.hodamotorsport.net/forums...hp?p=53#post53
formosa008 is offline   Reply With Quote
Old 03-14-2006, 08:17 PM   #779
that is the top speed?!, I thought you just don't have your 2nd gear engage
ok, it seem ,ike a new pipe is better chioce
Xray X12 2015
ARC R10 ATS
Old 03-14-2006, 08:28 PM   #780
British Menace's Avatar
Default Brian Berry
I would just like to welcome you Brian to Team Magic and the G4.
We are all very pleased you have decided to come on board, I'm sure you'll have a huge input to the development of the G4.
Have you had a chance to run the G4s yet? What do you think?
Tony
British Menace is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
