Old 07-01-2007, 10:39 PM   #7441
gansei's Avatar
Originally Posted by SalvadoriRacing View Post
hello guys.......
could anybody please tell me the G4 belts sizes?????
teeth number or lenght, it doesn't matter.....
thanks!
rear width 5.5mm 64T
front width 5.5mm 70 T
side width 4.5mm 126T
tooth gap: 3mm
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 07-01-2007, 10:43 PM   #7442
gansei's Avatar
Originally Posted by British Menace View Post
The lack of rear grip could be from setting the rear arms to the longer length.
Set threar arms to the stock (outer) hinge pin location. This may make the difference.
Menace
as i know.. rear sus arm is shorter.. then activity is very quick...
and rear sus arm is longer.. then activity is very stable
is my thought wrong?
and.. after change sus arm posion... the activity of my g4s is very nice.. except small tire size..
so i want find other setup(not changing sus arm length) to fix the probelm.
MY SPONSORS:
Old 07-01-2007, 10:51 PM   #7443
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
Originally Posted by Z00M View Post
You can not transfer settings from some other brand as the geometry is not the same. I know Serpent drivers that use +8mm. There is no way this is going to work on a G4.
Set your droop to +2mm and you will see you instantly have enough ride height. Even if the shock length was 100mm you will still have the same ride height the way you have the car setup. A down stop (droop setting) is exactly that - stopping the suspension arm dropping beyond a certain point. If you limit this too much (like with +6mm droop setting) you won't get the ride height you want.
To see the difference, put you car on the droop blocks without wheels or shocks and start unwinding the droop screws and you will see the arm start to drop. Set it at +2mm and reattach the wheels and shocks and you will have whatever ride height you want(within reason of course). If you don't have setup blocks do the same thing but sit the car flat on a board or bench, you will see the same results just not as easily measured.
To use a setup item correctly, you need to first understand what it does and how it works and how it will affect the car.
i know wat u mean, i have setup block. just that my mind somehow seems stop working on this shock. haha. ok, so may i know for large low traction track, wats the droop that u guys use?
uniquexme is offline   Reply With Quote
Old 07-01-2007, 10:52 PM   #7444
British Menace's Avatar
Ok. Remember with longer suspension arm, camber gain will be higher. Maybe too high on a medium grip track. This could unsettle the car mid corner or corner exit.
This is because the top link is shorter relative to the longer (lower) suspension arm.
If you want to keep with the longer lower suspension arm, You could try taking some spacers out from the top link (hub side).
How is your tire wear? Adjusting your rear static camber to 3 Degrees instead of 4. (You may have too much camber as you are mid corner or corner exit due to the higher camber rise)
Just something to try.
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 07-01-2007, 10:58 PM   #7445
I would go as advised. 2mm at rear and maybe 0 at the front.
Daz has a good starting set up where he measures the droop from ride hight.
So, with car in ready to race condition, gently raise the front of the car. If your front ride hight is 5mm. As you raise the car look at the tires, they should leave the ground when your chassis is 7mm off the ground. Do you see what I meen? This is 2mm of "droop" !
Likewise at the rear. Only this time set it at 4 - 5mm of droop.
IE: If ride hight set to 5mm. Raising the car, rear wheels should leave the ground at 9 - 10mm ride hight.
This way. It does not matter what tire sizes you run. Your droop will always be set the same.
Hope this helps.
Menace
Old 07-01-2007, 11:12 PM   #7446
gansei's Avatar
Menace
thanks...
i will try it.. i used 2mm spacers on rear hub top link
i will try 0mm or 1mm later..
and i compared my G4+ rear sus arm length with NT1.
G4+(long position) is longer than NT1 by 1-2mm
MY SPONSORS:
Old 07-02-2007, 03:51 AM   #7447
vc05hdt's Avatar
Originally Posted by vc05hdt View Post
I have also 95% finished G4S build and car is looking good; post pics in couple of days with motor installed and hopefully new body. Thanks Patto for helping out with dud part sent with kit.
Thanks Patto for the rear upper link mate! Pt Number 502193, Do you have any more coming? Prick to thread properly!
vc05hdt is offline   Reply With Quote
Old 07-02-2007, 04:02 AM   #7448
Pattojnr's Avatar
Trader Rating: 19 (100%+)
have plenty of the old ones for you as spares, no probs.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-02-2007, 04:03 AM   #7449
vc05hdt's Avatar
You are the Best
Old 07-02-2007, 04:26 AM   #7450
gansei's Avatar
Default the conclusion of clutch shoe problem..
i had a clutch shoe wear out problem and the fast meet of 2nd shoe.
i always used GR modified engine. (GR is a korea hadcore modified engine maker)
i asked korean GR Team about shoe wear out problem.. and 2nd timing.
they also agreed my opinion.. they are composited by mugen,kyosho,TM
driver.
they said 2-speed timing is fast and shoe wear out or melt out problem in
black shoe.
so they used yellow shoe or red shoe instead of black shoe.
this problem was occurred by much torque of GR modified engine.
But TM did not released yellow shoe..
and when i use red shoe.. the aluminum bell scratched(as attached photo)
then.. clutch setting was changed during race.
In conclusion, i must use red shoe with non-aluminum bell or i must use
yellow shoe.
but i can't use yellow shoe.. TM did not release it.
other G4 Driver tested 2-speed timing in last weekend.
he tested JP-engine and 353 novarossi engine.
But he could get proper 2-speed timing without spaces use.
so i think.. because my GR engine is too much torque.. G4's normal 2-speed
shoe could not have proper 2-speed timing. (must use spacers!!)
i suggest TM that yellow shoe must be released for modified engine user(like me)
how about you think about my opinion Daz?
MY SPONSORS:
Old 07-02-2007, 08:30 AM   #7451
gansei's Avatar
Originally Posted by gansei View Post
i run My G4+ conversion kit in korea circuit.
my G4 was very aggressive in cornering.
(my g4 show nice activity in low traction(some dusty ground))
car go well in big size rear tire(61mm~65mm)
But car's rear was flowed or slip in small size rear tire(60mm below)
my g4 width setup was front 197mm, rear 199mm
so i will test front 198mm, rear 200mm to solve rear slip probelm in next week.
i found the rear slip problem.
Y type v-one RRR rear stebil ball stud + ball end was too thick.
so it disturbed sus arm activity.. and feel rear shock harden.
i fixed the problem..
sorry for my mistake
MY SPONSORS:
Old 07-02-2007, 08:43 AM   #7452
Pattojnr's Avatar
glad you got it sorted Gansei.
now to work on the clutch
Serpent - Walter RC
Old 07-02-2007, 09:51 AM   #7453
Regional Moderator
daniz24's Avatar
I always cut the screw around 1.5mm to get the prefered shifting point. When in WC Brisbane, we even have to use harder spring than the original and lightening the 2speed shoe because its still too early
daniz24 is offline   Reply With Quote
Old 07-02-2007, 09:54 AM   #7454
gansei's Avatar
oh my friend 'Travel Hotel!'
thanks for your info..
i always call you as 'Travel Hotel!'
MY SPONSORS:
Old 07-02-2007, 12:36 PM   #7455
muppet racing's Avatar
Hi gansei,
I really dont understand why you have so much trouble with the clutch, from your picture you have not cleaned out the holes inside the clutch bell, which results in a small contact patch of the clutch shoe (as the sharpness of the edge of the holes cuts the shoe) this is VERY important.
Dont worry about the inside of the bell being scratched, its not an issue.
If you smooth the edges of the holes, then you will have a greater contact area and a far better clutch. I have posted good clutch settings before, which I run with Factory Nova Rossi engines, which have plenty of torque
I think maybe you were wearing clutch shoes, because the clutch is slipping too much because the contact patch is too small......
If you need to shorten the 2 speed screws, then thats an easy job. Maybe some kits came with too long screws ? I ran the same 2 speed all last season, its very good and very consistent.
Good Luck.
muppet racing is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
