Old 06-23-2007, 05:04 PM   #7321
gansei's Avatar
Originally Posted by ynmech View Post
Hey I don't want to sound lost but what is a Knack Solid Shock?
http://www.rctech.net/forum/showpost...postcount=7254
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 06-23-2007, 09:44 PM   #7322
If a high torque engine is used on a track with many tight cornerings, is the stock gearing ratio of TM G4S appropriate? If not, what should the gearing be like? By the way, according to the manual, the receiver battery is rechargeable. Can i use a regular charger(AC) meant for 7.2v racing pack? If so, how do i go about with the plug connector?
fulcrum07 is offline   Reply With Quote
Old 06-24-2007, 12:39 AM   #7323
razzor's Avatar
id suggest running the car with the stock gearing and see how it runs.
setting the clutch is important though so take your time.
If needing more bottom acceleration you can change to 18t 1st gear pinion or/and a 1st gear 52 spur gear.
But before anything setp and practice so you can gauge what changes are beneficial.
With the charger question , no you cant use a 7.2v ac charger ,you would need a 6v charger and preferably a peak detection one.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-24-2007, 01:39 AM   #7324
British Menace's Avatar
I would go with exactly what Razzor has said. Set up your car and run it. Then you'll have a reference guide for the changes you'll make.
Do take special care setting the clutch. Get use to making the measurements needed for cltch gap, clutch spring tension and endplay.
You best to have a set of vernier guages to do this accurately.
With a high torque motor it will depend on the grip you have at the track as to how far you can "tune-up" your clutch. But for now, go with the stock, manual settings. Then you can go from there and play with settings.
Have fun.
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 06-24-2007, 08:50 AM   #7325
Razzor and British Menace thank you for your suggestion. I will go with the basic setup and see how things go. Good luck and happy racing.
Old 06-24-2007, 12:31 PM   #7326
razzor's Avatar
Tried the Spool setup today that Muppet suggested.
Very interesting setup that ran very well.
Only hassle i had was i started with 35w GS shock oil and have to go a little thicker to 40w or 45w due to the track being a little bit bumpy in sections.
The spool was actually very niced to drive with even with our track having 3 hairpin corners.
I ran with softer shocks other than that everything was setup as per the setup sheet.Car was very stabil and reacted well.The steering was more than ample.
I also was rather happy in that the morning session i had the car reasonably good on 42 shore tyres but after lunch the guys decided to sugar the track again and i had to go down to 40 shore all round although 40f/38r i think would have been perfect.
Track has been a bit difficult to find the right tyre combo since we resurfaced it a month back.
Possibly the extra sugar put on today has glased it and i hope for a little rain before Wednesday as the nats start on Thursday with open practice.
Id suggest guys keeping this setup as a base setup when running the spool.It realy is a good setup.
Casterracing ZX1.5R
Old 06-24-2007, 03:14 PM   #7327
Hi everyone, I just purchased a G4S RTR and I have to say I am impressed with the craftsmanship that went into this car. I am still waiting for my starter box to come in before I can begin the break-in. There is one thing that I am not sure of about this car, is the battery that it came with a NICD or NIMH battery. I am using a Piranha Digital Peak Charger. I have checked the manual and all the it says about the battery is that it is a 6V 650 Mah and there was no charger included.
tpowazka is offline   Reply With Quote
Old 06-24-2007, 03:27 PM   #7328
rmdhawaii's Avatar
Just fyi... I've completed the 2nd pass of the forum for the KB. I've updated the FAQ/Tips, setups and links sections. I'm done with the site for now. I'm only going to update it every so often. If you have anything you would like to see added or corrected, please send me a PM.
Thanks,
Rainer
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-24-2007, 04:15 PM   #7329
Thanks,
Rainer
Congrats. Thats a good piece of work ! Very helpful to all of us.
Menace
Old 06-24-2007, 04:19 PM   #7330
Hey tp,
Good to hear your one of a growing family. Welcome.
The battery that comes with the kit is a 800mAh re-chargable NiMh.
They do seam to take 4 or 5 cycles before they get to full capacity. So becareful in the early days.
British Menace
Old 06-24-2007, 04:20 PM   #7331
Sorry.....I meant 650 mAh battery.
Old 06-24-2007, 04:23 PM   #7332
Good Info' Razzor. Good to note. Thanks. Best of luck in the Nats.
Old 06-24-2007, 08:13 PM   #7333
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
guys, happen to see the new UFO 2. http://www.kfactoryracing.com/produc...e=G4&id=K14137
hmm, i think the only different is with the UFO centrifugal shoe mount and clutch shoe only. i guess better to wait for these parts to change. haha.
uniquexme is offline   Reply With Quote
Old 06-25-2007, 01:08 AM   #7334
gansei's Avatar
Darren Johnson's set up tips2007/06/20 Browser : 118
Home made tricks from Darren Johnson give racers very good suggestions in setting up the car.
Really hope that all of you enjoy racing!
Source: Darren Johnson, Tecrotec
BACK >>
what difference shortening front wishbone and rear wishbone?
i did front/rear all 2mm shorten.
MY SPONSORS:
Old 06-25-2007, 01:31 AM   #7335
Z00M's Avatar
Trader Rating: 15 (100%+)
Darren's article only spoke about shortening the front of the rear wishbone.
But if you do shorten the wheelbase, the following is true:
Move the rear wheels forward will place more static weight on the front wheels.
Moving the front wheels rearward will place more static weight on the rear wheels.
So in effect, you could counterbalance the weight change from the back to the front by shortening the rear of the front wishbones but all this would do is make the car shorter. This is a different effect to putting more weight on the front for more steering.
Hope this helps.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
