Old 06-22-2007, 08:12 PM   #7306
Default Front Diff
Hey Guys,
I have just got my parts for a front diff - 502115, K14125 and the internals. My question is do I need a front diff pulley (K14122-9) or does the front spool come to bits somehow?
I run the ED trans.
Cheers
www.rcgear.com.au
www.novarossi.it/
www.teammagic.com.tw/
www.jacoracing.net
Danjr is offline   Reply With Quote
Old 06-22-2007, 08:32 PM   #7307
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
Originally Posted by Danjr View Post
Hey Guys,
I run the ED trans.
Cheers
yes, u will need to buy seperately the k14122-9 30T pulley for your front diff. it doesn't come with the diff kit.
uniquexme is offline   Reply With Quote
Old 06-23-2007, 01:31 AM   #7308
muppet racing's Avatar
Hi gansei,
I think the G4 New Back Bracket, is like the back bracket in part no.502196. But it allows to use the 2 positions for the lower hinge pin.
With the new position you may get a more stable rear, but I have never had a car with this adjustment, and I havent tested it yet !!
If you want a nice easy to drive fast car, please try the set up posted on the raceday team forum, but you need to do the whole set up, not different springs or shock towers !! If you are struggling, sometimes its good to go back to basics, and a car you know
Good luck.
muppet racing is offline   Reply With Quote
Old 06-23-2007, 02:23 AM   #7309
Sow&Steady's Avatar
Originally Posted by gansei View Post
my plug was not loose...
if engine's compression is high and bearing status is very good,
then.. piston high-down activity will continue long by soft finger turning.
it's only my quess
You mean the piston just goes up and with the compression high, it does not complete one whole revolution but instead just comes back down and then up the other way? So you're checking that if the bearings are very good, engine clean inside and with just your finger it should do that for long i.e. many times on its own?
What you clean the parts with when you take it apart?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-23-2007, 05:19 AM   #7310
TonysScrews's Avatar
When customers ask me what tools I recommend I always reply with:
Hudy (most expensive)
Mugen (they make a great complete tool set Part # B0529)
Thunder Tiger (best bang for the buck)
All three have replacable tips. I suggest getting a standard tip set (1.5, 2.0, 2.5 and 3.0mm), then a 2.5mm ball-tip driver for teh motor mount screws and then a 5.5mm nut driver for 3mm nuts.
I also HIGHLY recommend getting a Lithium cordless screwdriver. The small Skil IXO (about $35) works great but is single speed and doesn't have an adjustable clutch. The new Hitachi (about $80) has two speeds, adjustable clutch and comes with two batteries. For tips, I use the Mugen 2.0mm and 2.5mm tips (Part # B0530 and B0531). Ofna also makes a set of tips but I'm not sure of the part number. But once you use a cordless screwdriver you'll kick yourself for not getting one sooner....LOL
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
TonysScrews is offline   Reply With Quote
Old 06-23-2007, 07:09 AM   #7311
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Originally Posted by muppet racing View Post
Hi gansei,
Good luck.
where is this Setup DAZZ? been trying to find and no such luck Link Please!
cheers
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 06-23-2007, 07:16 AM   #7312
asil's Avatar
Send a message via MSN to asil
+1.. couldn't find it
Asil
asil is offline   Reply With Quote
Old 06-23-2007, 08:14 AM   #7313
Z00M's Avatar
Trader Rating: 15 (100%+)
If he's talking about the efra GP setup with the solid front it is this link:
Daz - EFRA GP Setup sheet
This is from post #25 of the raceday thread.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 06-23-2007, 08:30 AM   #7314
British Menace's Avatar
Default Chassis protection
Hi All
For those lucky people who are getting or thinking of getting the G4+ and are worried about that unique chassis.
TM do a chassis protector,
K1431-1 Chassis Protector.
Might ease your worries some. Just an idea.
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 06-23-2007, 08:45 AM   #7315
razzor's Avatar
how does the chassis protector work ???
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-23-2007, 08:45 AM   #7316
gansei's Avatar
many times on its own -> i did not count it..
What you clean the parts with when you take it apart? -> novarossi afterrun oil
my piston was side cut modified for lightweight piston.
the area touched piston and sleeve is smaller than normal piston/sleeve set
so up and down activity's load was little.
it's my trick for good engine pressure
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 06-23-2007, 08:55 AM   #7317
gansei's Avatar
Hi gansei,
Good luck.
thanks for your advice..
i want to convert my G4S to G4+ quickly.
G4+ spare part will be import in next week.
i take your advice to heart!!!
thanks!!!
MY SPONSORS:
Old 06-23-2007, 09:23 AM   #7318
gansei's Avatar
Default test report
i tested Knack Solid Shock and new Clutch setup on today.
my G4S can run more aggressive with Knack Solid Shock.
and new clutch setup was very nice.
But i did setup front solid.. my G4S's rear traction is some unstable.
so i changed to diff system again.
and my G4S go very nice.
i recorded best lap 17.022 sec.
i could enter 16.xxx sec.. But My OS TZ's Crankshaft was broken
so my race was stopped and returned home.
another A-main Level driver's Best lap time was 17.3xx
and rest of other drivers recorded pass over 17.5xx sec.
i very satisfied that i could make some large best lap gap with my rival racer.
i tested 3 setup.
1. Knack Solid Shock
2. Front SpeedShot Bulk roll center change
(normal position is the best!!!)
3. clutch setup (1 weight shim.. i always used 2 weight shim)
MY SPONSORS:
Old 06-23-2007, 11:47 AM   #7319
rmdhawaii's Avatar
cheers
Checkout the new "setup" section in the KB.
More to follow...
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-23-2007, 03:59 PM   #7320
Hey I don't want to sound lost but what is a Knack Solid Shock?
ynmech is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
