Old 06-22-2007, 08:40 AM   #7291
Pattojnr's Avatar
Trader Rating: 19 (100%+)
yes they do , but they are awkward to work with , and a set of hex drivers are easier and quicker to work with.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-22-2007, 08:45 AM   #7292
Trader Rating: 70 (100%+)
Default g4s
are you suggesting that when building the g4s i switch to hex screws?
Krafcik is offline   Reply With Quote
Old 06-22-2007, 08:47 AM   #7293
va_connoisseur's Avatar
Send a message via Yahoo to va_connoisseur
Should have a combination of hex and phillip heads in the kit. That's why they include the basic small hex drivers.
va_connoisseur is offline   Reply With Quote
Old 06-22-2007, 08:58 AM   #7294
Pattojnr's Avatar
Originally Posted by va_connoisseur View Post
True. The MTX-4R comes with simple hex tools. Does the G4S not? Just curious.
Good call on the setup station, droop and ride height gauges.
Speaking on these tools, what do most of you guys use:
Integy or Hudy? I have yet to purchase either but it is next on the list
im using the Ofna hex drivers, they were cheap at the time. lol
TM setup station , is very nice.
i have a snap on spanner for the steering rods and camber links. it has a 5mm offset open end and a straight 4mm open end. and small.
Serpent - Walter RC
Old 06-22-2007, 09:20 AM   #7295
rcrevolution's Avatar
Send a message via AIM to rcrevolution
yes pick up a set of hex drivers even if they are cheap ones , you wont regret it, I paid $20 for mine and they reach any screw and it doesnt take you 50min and a red hand to unscrew something.
on a second not, anyone know the easiest way to adjust front toe? its such a tight fit in there need nose pliers dont fit and I dont have any tool small enough for right there
rcrevolution is offline   Reply With Quote
Old 06-22-2007, 09:41 AM   #7296
Pattojnr's Avatar
yep, i use a snap on spanner, ill see if i can get a pic of it for you. does both front and rear adjustments.
snap on part number DSM45 http://www.paddockclub.co.kr/snap/In...S/51/S5119.htm
Serpent - Walter RC
Old 06-22-2007, 10:46 AM   #7297
razzor's Avatar
Originally Posted by rmdhawaii View Post
Some quick questions:
1. Anybody besides gansei running the 4mm chassis? How has it changed the handling of the car?
2. How much run time do you get out of the 800mAh receiver pack?
Thanks!
on the battery the guys at my track get easily through the heats and then repeak for the main or just keep the pack topped up.
Well we dont run 45 min mains but its ample for the 1/2 hour mains.
My personal car i have made up a 1000mah pack with Sanyo cells.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-22-2007, 11:00 AM   #7298
gansei's Avatar
Default G4 New Back Bracket
G4 New Back Bracket -> US $ 4.35
http://www.teammagic.com.tw/en/profr...2290&pageNum=1#
G4 NEW BAck Bracket(black color) is maybe cast in plastic.
G4S default BAck Bracket was cast in aluminum.
so we can expect G4's rear's more roll and more traction.
is it right? Daz!!
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 06-22-2007, 11:07 AM   #7299
gansei's Avatar
Default engine health check movie
http://flvs.daum.net/flvPlayer.swf?vid=nlOaeV1v5Ks$
MY SPONSORS:
Old 06-22-2007, 12:06 PM   #7300
i found my old lunsford turnbuckle wrench and it fits! so problems solved.
now for a second question.
when the g4+ is out and many people have it, is it possible for who ever has it to post a little run down on what parts would be worth it for the g4s and if they fit and part number, im sure alot of people who are staying with the g4s would apreciate it.
like if a new part offers better performance or durablity.
Old 06-22-2007, 12:22 PM   #7301
I believe that is available on nitrokb.com. I will check for the link.
But to dovetail his question, since the chassis are stamped with the run number (1/999 or 10/999 etc) if I get frame number 325 and I wreak it, can I order a new frame with that number stamped? Probably not but no harm in asking.
Old 06-22-2007, 12:28 PM   #7302
well I have seen the list of parts that work and dont, but I wanted to have a list of parts that have been improved on and which are actually worth spending the extra $40 on that would be great if we had a list like that.
Old 06-22-2007, 01:21 PM   #7303
rmdhawaii's Avatar
Those files were removed. Buy razzors list is still there:
http://www.rctech.net/forum/showthre...00#post3354100
Nah! You're never going to be able to destroy that 4mm chassis.
You're going to have to ask TM directly on this one:
[email protected]
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-22-2007, 01:32 PM   #7304
Sow&Steady's Avatar
Originally Posted by gansei View Post
Jeez Gansei! I hope the plug was loose because if you could do that then your engine does not seem to have compression left!
By the way, what are you checking for when you do that?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-22-2007, 03:13 PM   #7305
gansei's Avatar
my plug was not loose...
if engine's compression is high and bearing status is very good,
then.. piston high-down activity will continue long by soft finger turning.
it's only my quess
MY SPONSORS:
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
