Old 06-21-2007, 01:36 PM   #7261
rcrevolution's Avatar
Send a message via AIM to rcrevolution
well guys, I have finally finsihed my g4s completely.
the engine is broken in but not tuned, but the car is fully dialed in via TM setup gauges and HUdy ride and height gauges, and a futuba S9451 (?) its a digital coreless servo, 120oz, .10sec.
the car also has its own body now, a stratus 3.1mm, I am testing this car out on sunday and hopefully ti will hook up well and I can laid down some laps.
wish me luck!
rcrevolution is offline   Reply With Quote
Old 06-21-2007, 02:14 PM   #7262
rmdhawaii's Avatar
wish me luck!
That's great! What type of front axle are you going to be running and what weight oil did you put in the diff(s)?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-21-2007, 03:34 PM   #7263
one way in the front
and stock wt which I believe is 30wt for the shocks
Old 06-21-2007, 03:39 PM   #7264
rmdhawaii's Avatar
Some quick questions:
1. Anybody besides gansei running the 4mm chassis? How has it changed the handling of the car?
2. How much run time do you get out of the 800mAh receiver pack?
Thanks!
Old 06-21-2007, 03:41 PM   #7265
rmdhawaii's Avatar
Are you going to be running on a sweeping track or on a track with a lot of sharp and/or 180 turns where you will need to use your brakes a lot?
Old 06-21-2007, 05:47 PM   #7266
Z00M's Avatar
Trader Rating: 15 (100%+)
Thanks!
I found the 4mm chassis took away a little steering initially since it is much stiffer than the standard chassis. This was easily overcome with a spring change.
When my RX pack was new, I could run practive, 4 x 5min qualifiers and a 10min a-main without recharging. When it got a bit older I just recharged it before the a-main. Also remember these batteries (like any battery really) need a few cycles to start delivering their best.
I've now got the TM 1100Mah pack so I'll report back on how that goes.
Cheers,
Mike.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 06-21-2007, 05:56 PM   #7267
afm
afm's Avatar
Thanks!
Rainer
I run 1 hour mains with my 800mah stock pack, with one digital Ko Propo servo on steering (2143) and one analog in throttle-brake (2173), they both deliver 8.0kg torque 0.08 /0.09 sec /60 speed.
Had no problems so far, but will be upgrading to 1,100mah to be able to use both digitals servos, because as you know digitals suck more amps.
AFM
afm is offline   Reply With Quote
Old 06-21-2007, 07:33 PM   #7268
gansei's Avatar
Thanks!
-> car turn activity was some mild in 4mm
so i used 3mm chassis in technical track
and i used 4mm chassis in high speed,mild track
-> i am using sanyo eneloop 800mA.
i did not test total run time. But it is sufficient to complete A-main Final(30-45minutes)
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 06-21-2007, 08:37 PM   #7269
Originally Posted by g4smalta View Post
Hi all,
Here in Malta we have a very bumpy track. When I set up the car in the origional springs and 60w oil in certain parts of the track the car is bouncing. I have also all the extra pack of springs (8 if I remember). Can any one tell me spring rates of each - including the standard ones. Also what shock oil do you suggest with each spring?
Thanks for your help.
Ray
There are a few more important things to consider... How many holes are you using in your shock pistons??? What are your droop settings front and rear??? What are your roll-center settings??? Who set your car up for you and what tools were used??? There's alot more that could be asked, just know that your shock springs are just one of many things that need to be looked at/consider while trying to set your car up for a bumpy track... You never said how the traction was as well... Help the G4 drivers here that post here by filling in the blanks and I'm sure someone can give you the useful tips and settings you're looking for... 02
RC_Alan
rc_alan is offline   Reply With Quote
Old 06-21-2007, 09:04 PM   #7270
its an open wide sweeping track, but this is just practice not a real race.
Old 06-21-2007, 09:08 PM   #7271
rmdhawaii's Avatar
Thanks for the info on the chassis and battery guys.
Old 06-21-2007, 10:26 PM   #7272
Many thanks to all who supplied the help.
I will keep you informed of how things are going.
Ray
g4smalta is offline   Reply With Quote
Old 06-21-2007, 10:28 PM   #7273
gansei's Avatar
Default please open your Face!!
hi G4S Users!!!
i had discussion with you about several months
and i think G4S users had much earnestness on RC.
But i don't know your face (except SerpentD, asw7576)
how about upload your face in this thread?
if it disturb you privacy.. don't upload...
i want to see G4S Friends's Photo.. if possible.. with your machine
MY SPONSORS:
Old 06-21-2007, 11:05 PM   #7274
asil's Avatar
Send a message via MSN to asil
ZOOM, did you check your 1100mAh rx pack if tabs are loose or not?
BTW Gansei, here's me
asil is offline   Reply With Quote
Old 06-21-2007, 11:09 PM   #7275
gansei's Avatar
oh!! you are a good-looking guy!!
thanks!
MY SPONSORS:
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
