Old 06-17-2007, 08:17 AM   #7156
gansei's Avatar
Default - korea kyosho cup -
i joined the korea kyosho cup in today.
i used BOSS Plug(NinJa) on my OS 12TZ.
the kirina circuit's ground temperature was about 55C-60C
and ground was very dry (no humidity)
so it was very difficult to find setup.
speak briefly.. 'The Worst Traction'
i finished 3rd position in the Heat.
i changed my car setup.. and clutch setup also changed.
and.. my G4S go well than Heat in the final warming up race
But.. i made a absurd mistake in the final warming up race
my finger was slide seperated from transmitter trigger in the backstraight
ends in full braking time
my G4S go straight the wall.. and crashed..
front sus arm was broken and wheel got bent.
so i could not start in A-main Final.
i repaired my G4S and i could join A-main Final after 8-9minutes
i got the best lap number one.
there are no cars that pass me.
But for 8-9 minutes loss.. i finished 7th position. --;;
i attached sandpaper in my transmitter trigger for protection finger sliding.
and i wonder how to do good setup in high temperature and dry ground...
Team Magic G4-sany0001.jpg   Team Magic G4-sany0018.jpg   Team Magic G4-sany0019.jpg   Team Magic G4-sany0017.jpg
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 06-17-2007, 12:39 PM   #7157
dnitro's Avatar
Gansei,
It is clear if you didn't have your misfortune, should have a podium finish, since you had the fastest laps.
Did you wash your hands in oil? Is that why is slipped?
Next time buddy...next time...
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 06-17-2007, 01:33 PM   #7158
casimirsa's Avatar
Well done on your recovery!
I slipped a piece of fuel tubing over the front of my trigger! My finger therefor fits snug in the trigger!
I cannot help noticing that your front A-arm has been cut a fair amount shorter! (the section where the pivot ball screws in)
What is the reason for that! I cannot remember seeing any post regarding this in the posts!
casimirsa is offline   Reply With Quote
Old 06-17-2007, 03:49 PM   #7159
Sow&Steady's Avatar
I do the same on my 3PK but the old M8 fits snugly on my trigger finger.
The cut on the arm is probably for the short-wheel-base mod.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-17-2007, 04:00 PM   #7160
casimirsa's Avatar
I meant the section where the pivot ball screws in. I looks as if it has been cut down about 1.0mm
Old 06-17-2007, 04:15 PM   #7161
razzor's Avatar
Daz/muppet mentioned they did that when using the quick release hubs.
The q/r hubs havea slightly wider off set so by doing that you can make the front track narrower.I think you would have to shorten the threaded end on the ball as well.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-17-2007, 06:57 PM   #7162
gansei's Avatar
i also put something(shrinking cable) in trigger to reduce trigger gap.
But it is some slippery ^^
A-arm has been cut a fair amount -> to reduce front width (196 ~197mm)
MY SPONSORS:
Old 06-18-2007, 04:01 AM   #7163
TM Edith's Avatar
How are you all?
Really hope everything is alright.
G4+ Kit 999/001 and 999/999 are currently opening for bidding on EBay and will be last for 7 days.
This offers a great opportunity for customers to get a G4+ with good value.
Please go and bid for the number you like.
Have fun and Happy Racing.
Team Magic Edith
TM Edith is offline   Reply With Quote
Old 06-18-2007, 05:50 AM   #7164
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
OS speed was much reduced due to slipping clucth, lucky i finished 20min final in 2nd - looks like this clucth is stuffed, now from the pics should i just buy th shoe, or get a whole new assembly?
regards
Frankie
Team Magic G4-digital-001.jpg   Team Magic G4-digital-002.jpg   Team Magic G4-digital-003.jpg   Team Magic G4-digital-004.jpg
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 06-18-2007, 06:01 AM   #7165
Also why is my side belt stripping teeth all of a sudden? maybe the locked diff i thinks, i did run a 2mm split always with ED trans and ran a 52T 1st and 46 2nd
Old 06-18-2007, 06:15 AM   #7166
razzor's Avatar
You would need just the shoe Kodak and if you wanted you couls trim the lip on the shoe base like mentioned before by Gansei.
Casterracing ZX1.5R
Old 06-18-2007, 06:19 AM   #7167
razzor's Avatar
check maybe too much slack on the belt.
Casterracing ZX1.5R
Old 06-18-2007, 06:19 AM   #7168
gansei's Avatar
the urethane Belt(TM) is easily stripped teeth with ED Trans(aluminium pully)
recommendation rubber belt!!
MY SPONSORS:
Old 06-18-2007, 06:39 AM   #7169
razzor's Avatar
Thats interesting to note Gansei but i havent had any hassles with stripping belts or spurs for that matter.
Last damaged belt a had wasa front one from a bad accident i had at the last national meet.
Casterracing ZX1.5R
Old 06-18-2007, 06:41 AM   #7170
Gansei where can i buy? this rubber belt?
Razzo, yeah i checked that seems fine!
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
