Old 06-14-2007, 09:37 AM   #7126
MLCG4s's Avatar
i allready made the mod , and i also use the M1-B brake pads (TM560166)and it works fine
MLCG4s is offline   Reply With Quote
Old 06-14-2007, 09:59 AM   #7127
razzor's Avatar
Thats interesting ,i was actually thinking of that when i built my M1-B but just brushed the idea aside.
Cool Gansei
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-14-2007, 12:44 PM   #7128
Originally Posted by gansei View Post
i changed ED Brake system By M1B Brake Disk.
ED Brake Holder easily be dig(damaged) by hard Braking.
(i already changed new two Brake holder!)
But M1B Brake Disk reached area is wider than G4S's one.
※ if you try it, you must cut brake pad holder (left one, near to brake pully)
because brake pad hoder little touched with brake disk.
I see you have done some kinde of brake pad mod.
What kind of brake pads do you use?
For me, it seems, original brake pads somehow lose performance and brake trimer needs to be adjusted every this and than
JanisK is offline   Reply With Quote
Old 06-14-2007, 01:50 PM   #7129
gansei's Avatar
it's a mugen MTX-4 tefron pad.
it help very smooth braking and constant braking... But a little changed (braking strength)
and i will try M1B Pad.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 06-14-2007, 02:49 PM   #7130
dnitro's Avatar
JanisK,
You are correct. The current brake set-up does fade over the course of a race and you have to continually increase the brake trim for the brake to bite. When the pads heat it, it looses grip. I have the Kfactory brake disk, and I still have brake fade. Next step is to get the Kfactory brake pads.
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 06-14-2007, 04:40 PM   #7131
ALG
Originally Posted by dnitro View Post
JanisK,
"REAL BRAKE PADS" for Kfac, are very good but tricky to use. You must play with the trim during racing and needs some heat for good brake power.
I tried mugen teflon pad, but I don`t like te feeling of it.
Have fun
ALG is offline   Reply With Quote
Old 06-14-2007, 05:19 PM   #7132
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Anyone tried a 2way front diff and 30W dif oil in the rear?
What are the characteristics of this change?
Thinking of trying it this weekend
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 06-14-2007, 06:25 PM   #7133
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
i have been using front diff 30W, and Rear diff 10W. awesome!!! u can try, m sure u will love it.
uniquexme is offline   Reply With Quote
Old 06-14-2007, 06:40 PM   #7134
uniquexme's Avatar
does anyone know which brand or part no. for the brake cam, by the part no. of 502197, the round cam attached to the brake lever, which is used for locking up the brake pads? i think mine is worn out, coz currently my brake lever need to go a larger distance before brake will have effect? thus the cup fall off now and then. i remember Razzor told me that he changed his to a longer one. coz i just fitted my KF Real brake pads, but braking is still not very strong. any help would be highly appreciated.
Old 06-14-2007, 06:42 PM   #7135
uniquexme's Avatar
Duro 2 spur gears, housing, clutch shoe... guys, what are the difference of these with our stock ones??
Old 06-14-2007, 08:09 PM   #7136
gansei's Avatar
1. PLS minimize the interval between 2 brake pad
2. paint bearing oil to brake cam shaft whole
and then.. no wear out... it will be shining
MY SPONSORS:
Old 06-14-2007, 09:26 PM   #7137
rcrevolution's Avatar
Send a message via AIM to rcrevolution
duro spurs?
is that some sort of super durable spur gear?
and are we trying to figure out if they work on our stock g4s?
also whats the price tag on them?
rcrevolution is offline   Reply With Quote
Old 06-14-2007, 09:37 PM   #7138
Hello All,
Stupid question but where can i purchase bulk Turbo Glow Plugs at a good price for an OS TZ engine?
and what other plugs can suit?
Old 06-14-2007, 09:45 PM   #7139
gansei's Avatar
Hello All,
i used novarossi #7 Plug on OS TZ.
there are no problem..
and i will test Ninja #7 Plug on TZ
MY SPONSORS:
Old 06-14-2007, 11:06 PM   #7140
G4S'er's Avatar
The Duro 2nd spur gears are a thicker heavier nylon gears. We have had cases of the 2nd spur gears stripping. This thicker gear should help solved this problem. Because the gear is thicker the hole where the housing fits is smaller. So we have a smaller housing and smaller shoes to make this system work. Everything on the 1st spur gear will remain the same with the gears and the one way.
I think their may be an added value to these gears as well. With the 2nd gear housing being smaller and thus smaller shoes, we have made these items lighter and these are rotating mass items as well. I haven't had a chance to weigh the combination of the 2nd spur gear, housing and shoes against each other, however when I recieve all the parts I will do that and let everyone know.
G4S'er is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
