Old 06-13-2007, 08:24 PM   #7111
rcrevolution's Avatar
Send a message via AIM to rcrevolution
toe front +1
camber front -2
toe rear -2.5
camber rear -4
ride height front/rear 5mm/5.5mm
too bad weather has been crap here and I cant test how well the car grips up.
I also added a new futuba S9451 digital/coreless since last time I drove it so lets see how this handles.
rcrevolution is offline   Reply With Quote
Old 06-13-2007, 09:33 PM   #7112
gansei's Avatar
Originally Posted by rcrevolution View Post
toe front +1
camber front -2
toe rear -2.5
camber rear -4
korea weather is too hot in recent days
so rear grip(traction) is very high..
i tried this setup
toe front +2
camber front -3.5
toe rear -1.5
camber rear -3
and i record new best lap..
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 06-13-2007, 09:39 PM   #7113
gansei's Avatar
Default my new clutch setup
my new clutch setup
Clearance(gap): 0.3mm
end play: 0.3mm
black shoe
weight shim: 2
spring: mugen super hard(silver)
spring lock:
lock the spring max until not turn.
and unlock 1 turn ~ 3/4 turn.
this is a Kitade Clutch setup Style.
MY SPONSORS:
Old 06-14-2007, 12:42 AM   #7114
Sow&Steady's Avatar
Originally Posted by gansei View Post
my new clutch setup
end play: 0.3mm
black shoe
weight shim: 2
spring lock:
It looks radical, very different. My instincts tell me its not right but I've never tried it so it'll be interesting to see your report when you use it for your next race.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-14-2007, 02:36 AM   #7115
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
guys, since some of G4+ parts are already available now, (such as duro spurs, fly arm), may i know wats the main difference between these duro spurs and the one we are all using? coz i noticed that there are 3 holes on the spur gears. think shall grab those fly arm for spares!!!
uniquexme is offline   Reply With Quote
Old 06-14-2007, 02:53 AM   #7116
rmdhawaii's Avatar
i cut shoe plate wall from 1.7mm to 1.2mm.
i expect long shoe life.
thanks Daz for this tip..
I don't understand. Where did you cut?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-14-2007, 03:52 AM   #7117
British Menace's Avatar
Hi rmd'
There is a small 'flange' that the pressure plate/ clutch pad sits in.
It is this flange, the thickness of the plate that Gansei and Daz are talking about. Stock, they are around 1.7mm thick. If you cut this down to 1.2 it will increase the amount of wear the pad will take before replacement.
The new U.F.O 2 clutch on the G4+ comes with this mod already done
Hope I've explained this right.
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is online now   Reply With Quote
Old 06-14-2007, 03:59 AM   #7118
rmdhawaii's Avatar
Thanks Menace. Now I got it. You explained it right.
Old 06-14-2007, 04:13 AM   #7119
Old 06-14-2007, 04:14 AM   #7120
razzor's Avatar
my new clutch setup
end play: 0.3mm
black shoe
weight shim: 2
spring lock:
Interesting setup Gansei ,let us know how it works.
Only ???!!! i have with it is that you using so much end play .3mm.
I usually shim under the inner bearing till bell binds a little bit and then remove a .1mm shim and then check it spins freely.Too much end play damages the thrust bearing from what ive been told and to date that has never happened to me.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-14-2007, 04:33 AM   #7121
Gascar 24's Avatar
Trader Rating: 15 (100%+)
hi guys
had to share this news
have scored myself a JP S3 black for $250 aussie
it has only been run in what a bargin
anyone got any tune tips for this rocket
i reckon is going to be to quick for me maybe
paul
Gascar 24 is offline   Reply With Quote
Old 06-14-2007, 04:48 AM   #7122
rmdhawaii's Avatar
hehe ... I think he has been listening to those Mugen guys.
Old 06-14-2007, 05:08 AM   #7123
razzor's Avatar
Thats what i was thinking but lets see what Gansei thinks.
I also think it makes the gear engagement a bit harsher.
Casterracing ZX1.5R
Old 06-14-2007, 05:47 AM   #7124
gansei's Avatar
"Too much end play damages the thrust bearing "
=> never.. it is a only formulas theory.
i already tested the clutch setup before 1 month.
But there are no the thrust bearing DIE!!!!
my Best lap was 16.92x in Kirina circuit
But after change clutch setup.. i recorded new best lap '16.8xx'
of course, i can't say the reason clutch setup was great!
But i feel more driving force after changing clutch setup.
i will test it more...
and.. i heard from japanese Driver in recent days.
that japanese driver favor to setup clutch to meet early like my setup ^^
MY SPONSORS:
Old 06-14-2007, 08:16 AM   #7125
gansei's Avatar
Default NEW TIP
i changed ED Brake system By M1B Brake Disk.
ED Brake Holder easily be dig(damaged) by hard Braking.
(i already changed new two Brake holder!)
But M1B Brake Disk reached area is wider than G4S's one.
※ if you try it, you must cut brake pad holder (left one, near to brake pully)
because brake pad hoder little touched with brake disk.
MY SPONSORS:
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
