Old 06-11-2007, 09:47 PM   #7096
British Menace's Avatar
Originally Posted by GBagRacing View Post
So....I finally got to race my G4 for the first time. What a great car!!! Using the box stock set up with only light changes to the droop I won all three qualifiers and finished 3rd in the A main. Sadly the A main was mine for the taking but with only 40 seconds to go & a 2 lap lead on the pack that wimpy little 800mah battery pack gave up the ghost and relegated me to 3rd. All in all I walked away very happy with my new ride.
The 800 pack will improve with cycling it a few times. Takes around 5 or 6 cycles to get the best from it.
Take Bucknuts advice and check your end points carefully especially if you run digital servo's!
Good to hear you did so well.
Look on Raceday hobbies site. They have a new 1100mAh battery out now!
Mines in the mail. Should take car of those hour long mains.
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 06-11-2007, 09:51 PM   #7097
gansei's Avatar
Originally Posted by muppet racing View Post
Hi gansei,
With the clutch, I think you need to chamfer the holes in your clutch bell a little more, so they are smooth and will not wear the shoe so much.
The ridge on the support plate can also be made smaller, I sand mine down to 1.2mm (from about 1.7mm I think) this will give you the option to run the clutch shoe for a lot longer.
I run the Red shoe, I dont know if this will last longer ?
My Clutch shoes will last at least 2 or 3 nationals, if you are using too many then something is not correct, maybe too much slip........
For me there is nothing wrong with the UFO, at our nationals, no car has a better clutch, and the Kyosho drivers are now using the UFO clutch too !
Also I dont have a problem with excessive wear on the pinions, if the mesh is correct they should last fine, the UFO is probably the smallest and lighest race clutch on the market, putting heavy steel pinions on it kind of defeats the design principle.
With my G4+, it came with a thicker clutch shoe, and the support plate ridge already smaller, so these should give you what you want. I have not tested the new shoes yet, but they may need slightly more weight behind them as they are quiet a bit thicker, hence heavier.
Good Luck.
hi daz..
i tested your several clutch setups from 3hobby,rctech,TeamMagic site.
But i did not like your clutch setup.
i feel clutch slip much.
i appealed shoe wear out problem.. But opposite to my opinion you did not appeal shoe wear out problem.
is it cause ground grip(resistance ) status different? (you and me)
korea circuit ground temperature is about 55-56C in lately
asw7576(Indonesian) also appealed shoe wear out problem
(Indonesia jakarta circuit groud temperature is over 60C)
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 06-11-2007, 09:57 PM   #7098
gansei's Avatar
Originally Posted by British Menace View Post
No. It means Gansei,
High traction track....front diff oil is lighter. Maybe 40 or 50,000WT and rear diff is heavy. Maybe 30 to 50,000WT.
Low traction conditions. Front diff is heavy. Maybe 100,000WT or solid spool.
Rear oil is light. Maybe 5 or 10,000WT oil.
I hope this makes sence.
Menace
i think that it is formulas rule... But exception alway exist...
2nd,3rd ranking car used front spool in last year JMRCA.
(in very high traction)
1st is Fukuda(MTX-4) But he used oneway..
lately... japanese driver like front spool..
hurukawa Ken Also start setup by front spool.
the fastest man in the world Bertin also show awesome driving in last year FEMCA 2006 by front spool
MY SPONSORS:
Old 06-11-2007, 09:59 PM   #7099
hi Gansei,
care to post some of his setup? i'll like to know & compare. got some diffulty entering some of the sites. Thanks.
sphere666 is offline   Reply With Quote
Old 06-11-2007, 10:20 PM   #7100
gansei's Avatar
Originally Posted by sphere666 View Post
hi Gansei,
i did not have his setup..
kitade(Knack Boss) also used front spool..
kitade got 4th ranking in JMRCA 2006
(But he used front oneway.. and he was ranked 2nd postion before 2 minutes race over.. But he was passed by two front spool driver in last 2 minutes)
kitade is also A-main Driver in 2003 1/8 IFMAR WORLDCHAMPIONSHIP
he made a shock for front spool..(with shock tower.. only MTX-4,RRR)
shock for front spool had smaller capacity than normal shock.
so it can help more quick, fast response..
pls take a look this picture.(right is shock for front spool)
you can get kidate setup sheet in http://www.knack-racing.com/
But it wrote by japan language.. so i can't understand.. ^^
MY SPONSORS:
Old 06-12-2007, 05:03 AM   #7101
gansei's Avatar
Default my NT1 driving Video
i drived my RC Friend's NT1 in last weekend
he wanted that i advice for setup his NT1 after race.
his NT1's 2-speed timing is too fast..
But all setup are fine.
i recorded best lap 17.2 by his NT1 in this movie
http://tvpot.daum.net/clip/ClipViewB...&scrapable=yes
But i recorded best lap 16.8 by my G4S in same day.
MY SPONSORS:
Old 06-12-2007, 12:22 PM   #7102
asw7576's Avatar
Very identical to MTX4 shock ( the left ) : shock body, top and bottom plastic connectors, silver ball connectors.
BTW, Anyone can make similar shocks ( like Gansei's ) with MTX4 spare parts and reuse G4S shock body and piston shaft :
H0867 : silver ball connectors with 3mm hex
H0555 : complete set for MTX4 suspension connectors ( top and bottom )
and Grub Screw : 3x12mm
( Don't have to copy ) : Mine is using Mugen parts for top section and Tamiya parts for bottom section. Why am I using Tamiya parts for bottom section ? Mugen plastic connectors usually hit the inside tyre.
( You can agree or disagree .... it's okay ) : Some of you said there is silicone leak and need to glue the membrane to bottom of top connectors. Some said if tighten too deep, the membrane will be displace. Why ? because the bottom of G4S's top connectors has very thin lip that can properly hold the membrane.
Please compare the bottom of top connector from G4S with Mugen, you will see the difference. Mugen's bottom top connectors have full lips that grip the membrane very well. G4S bottom's is just the opposite.
Team Magic G4-shock.jpg   Team Magic G4-shock-002.jpg   Team Magic G4-shock-mugen.jpg
Old 06-12-2007, 03:54 PM   #7103
casimirsa's Avatar
Somebody was looking for a manual the other day!
TM SAM has posted on RCVIEW.COM the following:
"Please contact Team Magic and we will send the manual via E-mail to you."
Hope you get what you wanted!
casimirsa is offline   Reply With Quote
Old 06-13-2007, 04:25 AM   #7104
dnitro's Avatar
Originally Posted by rmdhawaii View Post
What type of track are you running on? Smooth w/high traction? Any traction compounds?
The track was tight, high traction, smooth and clean. My best set-up was with 50K rear diff and spool in the front. 42 front and rear with even tire wear after 20 min main.
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 06-13-2007, 05:08 AM   #7105
gansei's Avatar
Default shoe plate modified
i cut shoe plate wall from 1.7mm to 1.2mm.
i expect long shoe life.
thanks Daz for this tip..
MY SPONSORS:
Old 06-13-2007, 08:36 AM   #7106
gansei's Avatar
Default open car concept
open car concept body... hahahaha~
Team Magic G4-sany0001.jpg   Team Magic G4-sany0002.jpg   Team Magic G4-sany0003.jpg   Team Magic G4-sany0004.jpg   Team Magic G4-sany0005.jpg
MY SPONSORS:
Old 06-13-2007, 10:41 AM   #7107
razzor's Avatar
Looks good Gansei
gives me and idea for a body for the nats at the end of the month.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-13-2007, 11:08 AM   #7108
gansei's Avatar
Originally Posted by razzor View Post
Looks good Gansei
it is a for FEMCA elegance body
But FEMCA did not open elegance event. --;;
MY SPONSORS:
Old 06-13-2007, 11:22 AM   #7109
razzor's Avatar
very nice ,especially the Kawahara body.
Casterracing ZX1.5R
Old 06-13-2007, 07:12 PM   #7110
s10dude's Avatar
nice work...............i really like the black one.........
s10dude is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
