Old 06-10-2007, 08:16 AM   #7051
dnitro's Avatar
Originally Posted by johnhsp View Post
today already try it,wowo really good,i using serpent 16T steel pinion gear,really harded then TM pinion gear,clutch shoe also harded,good now this time don't waste money to buy TM ED pinion gear
Can you explain how you modified you clutch/pinion bell set-up to fit G4s. What parts were used?
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 06-10-2007, 10:16 AM   #7052
gansei's Avatar
Originally Posted by vc05hdt View Post
Hi Gansei and asw 7576,
I missed out on seeing both of you at the FEMCA race. Was this race a one off thing for Jakarta or again next year same place? Was it memorable and did you both catch up for nightlife after? Kuta and Denpasar very good holiday with large group of family and friends. Many "benchong" in Jakarta?
Good to see the F430 back on your avatar asw. On holiday I found a 2 sq metre shop off Poppies Lane ( off Legian ) with a used G4S for sale with other bits and pieces.
Regards,Mark
the FEMCA 2008 will not be opened in jakarta.
it is high possibility that FEMCA 2008 will be opened in malaysia
(it is my quess ^^)
and.. i did not see asw 7576's F430.. and he did not ride F430 me!!!
we had not nightlife time... i was very busy for RC maintenance ^^
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 06-10-2007, 11:14 AM   #7053
mtveten's Avatar
Trader Rating: 27 (100%+)
Originally Posted by razzor View Post
Im interested to see what is the update/improvement on the UFO clutch ???
See there is a UFO2 upgrade kit that will be available too K14137-1
From the photo it looks to just be an update to an ED clutch bell and their yellow spring.
With the UFO already being the best clutch on the market I wouldn't expect a significant change.
Mark
mtveten is offline   Reply With Quote
Old 06-10-2007, 11:14 AM   #7054
casimirsa's Avatar
I know this i not a thread for Spektrum RX/TX, but as this affect my G4S's future and I feel that the knowledge is here so I hope you guys don't mind!!
Has any body used the SR3500 DSM 3 Channel Mirco Racing RX in there cars?
If yes are you still using it?
If you are not using it any more, why not?
casimirsa is offline   Reply With Quote
Old 06-10-2007, 12:18 PM   #7055
rmdhawaii's Avatar
Originally Posted by gansei View Post
korea Kyosho Cup Will be opened in Kirina Circuit(Kawahara cup opened) in next weekend
i did exercise my G4S...
But the weather is too hot!!
ground temperature is about 55C-56C.
G4S activity is not good..
i changed shock spring, shock position, width, toe-in, camber.. etc on..
But car activity was not changed.
maybe.. too hot ground temperature disregard the car setting.
so i changed tire degree and test it.. (unbalanced setting)
then.. my g4s go well...
i record my best lap in that circuit.. 16.874 sec.
i record number one best lap among korean RC Driver in today.
the 2nd best lap driver is NT1(Mr Goo) 16.965 sec.
(he is winner the recent korea serpent cup. i did not join the race for FEMCA sequela ^^;;
http://www.teamxray.com/teamxray/new...bd6b0a23b93354)
Very good gansei.
By "tire degree" do you mean "tire shore"?? If so, what tire shore did you start off with and what tire shore did you change to??
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-10-2007, 12:21 PM   #7056
mtveten's Avatar
I used the spektrum micro and found it be much more reliable than the std pro receiver. I have since switched to Futaba FASST due to module failures but never had a problem with the micro receiver.
Mark
Old 06-10-2007, 01:31 PM   #7057
razzor's Avatar
Mark
I am using the Pro recivers as i was warned against using the grey coloured ones and also not to try the micr reciever by a lot of off road guys.They swear the pro reciever is more reliable.
Being that i ru stick i have only teh Spektrum option at the moment untill i can get my hands on the new Sanway system for my Super EXZES stick radio.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-10-2007, 04:50 PM   #7058
johnhsp's Avatar
Trader Rating: 18 (95%+)
Send a message via MSN to johnhsp Send a message via Yahoo to johnhsp Send a message via Skype™ to johnhsp
serpent clutch shoe does not fit on G4S FlyWheel. (3 shaft)
did you make a hole on serpent clutch shoe?
i did it.. But failed.. --;;
yap,i make a hole on serpent clutch shoe,only a little enought,yesterday already try it good,
johnhsp is offline   Reply With Quote
Old 06-10-2007, 04:53 PM   #7059
johnhsp's Avatar
just using serpent clutch shoe/pinion/bell,all fit to g4s,only clutch shoe u need make a hole,just a little hole enought,here is spernet part number
803193,802512,802502,802521
Old 06-10-2007, 08:52 PM   #7060
gansei's Avatar
Originally Posted by rmdhawaii View Post
Very good gansei.
yes tire shore!!
i started front 40, rear 40.. and tested front 37, rear 37..
But my G4S had much understeer in cornering.
i changed many setup to lose rear grip(Traction)
But rear grip did not lose..
when i turn max steering and full Thorttle..
My G4S did not spin turn........... --;;;
so i changed front 37 rear 40.... then.. understeer was solved.
i learn tire setup is very important and tire effect is big!!!
MY SPONSORS:
Old 06-10-2007, 09:02 PM   #7061
gansei's Avatar
i made a hole on serpent hole.. and tested it..
But serpent clutch shoe weared unbalanced..
(maybe i made a hole wrong)
UFO G4S clutch had problem in shoe..
the shoe was very thin against serpent,mugen one.
so G4S shoe's life is too short (about 2-3 weeks.. of course my standard)
i know as UFO2 solved the shoe problem.
But it did not released yet..
so i will test Knack Clutch System(MTX-4) in this weekend.
MY SPONSORS:
Old 06-10-2007, 09:22 PM   #7062
johnhsp's Avatar
now i try is ok,but reallyneed more time to test it,after finish test it i will let both of you thank
Old 06-10-2007, 10:28 PM   #7063
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
ok, keep us posted on your mod john. keke...
uniquexme is offline   Reply With Quote
Old 06-11-2007, 12:08 AM   #7064
rmdhawaii's Avatar
Old 06-11-2007, 12:19 AM   #7065
British Menace's Avatar
Yes I use the SR3500 Receiver.
I use it along with the Pro module.
I do still use the 'Pro' receiver too in the spare car. Funnily enough I'm putting the pro receiver in the race car as I've had some........"confidence" issues with the SR3500.
What I mean is, occasionally when you turn on the SR3500, ie the car. It does not communicate? Other times it takes maybe 10 seconds to link up with the transmitter before I have control?
Although once the SR3500 is in communication with the transmitter, I don't have any problems!!?
It's only when I first switch the car on (power up the receiver) that I see this. It's strange. I have tried re-binding the SR3500, but does not seam to make a difference.
What probs' have you had?
By the way. This SR3500 was one SPEKTRUM sent me to replace the one I bought which would not communicate over 300mm (Yes, 300mm !!) away from the car?
So now I have the Pro receiver in my race car and the SR3500 in the spare car. More confidence than anything else.
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
