Team Magic G4
Old 05-31-2007, 04:52 AM
  #6826
Joe Tanto's Avatar
Default gearing
hi what's the best gearing to start with on the TM, cos the stock gearing seems not good, I am using an STS D3R engine on it?
Joe F
Joe Tanto is offline
Old 05-31-2007, 04:57 AM
  #6827
British Menace's Avatar
Joe F
If you have the stock gearing I would try and get the new ED transmission system.
The car accelerates alot better and is faster too.
Are you racing on a small track?
Menace
British Menace is offline
Old 05-31-2007, 04:58 AM
  #6828
gansei's Avatar
Originally Posted by British Menace
Gansei,
Did you have to put the inserts in the front uprights?
Menace
BTW: Congratulations on your international debut at FEMCA 2007. Very well done.
of course!! i put inserts!!
thanks~~
gansei is offline
Old 05-31-2007, 05:01 AM
  #6829
thanks~~
The new uprights comming out (on the G4+) do not have the inserts. They are made for stock axles (or universals)
Menace
Old 05-31-2007, 05:31 AM
  #6830
razzor's Avatar
Menace
Thats incorrect Menace.
From what i have picked up it looks like the G4+ will have the quick release system as std and will also have the inserts if wanting to use std universals.
You can also change the bearings to suite with out using the inserts.
In the G4+ thread ive posted the contents of the G4+ kit.
The + has a lot of new parts and includes 1100mah rx pack too.
razzor is offline
Old 05-31-2007, 05:32 AM
  #6831
razzor's Avatar
Joe F
Can you give us some more info ?
what is teh car doing at the moment ?
razzor is offline
Old 05-31-2007, 05:33 AM
  #6832
Joe Tanto's Avatar
Menace
Hi yes it is a small track with technical corners aswell
Joe
Old 05-31-2007, 05:45 AM
  #6833
razzor's Avatar
Bud id suggest getting a 18t 1st gear pinion and 52 spur to start with.
After which id suggest the harder clutch spring or adding a bit more tension to get engine winding up when clutch engages.
Clutch is the key to performance out of corners.
Try that first.
razzor is offline
Old 05-31-2007, 06:13 AM
  #6834
charlesd's Avatar
Just wondering how many of you are using the stock brake pulley? My aluminum one is now dead ( the pins keep popping out ) and i can't remember why i changed it - bling factor, problem with stock pulley, ??? I have a race on the 9th so i still have time to order from raceday.
Anyone having problems with the stock brake pulley?
charlesd is offline
Old 05-31-2007, 06:46 AM
  #6835
s10dude's Avatar
no...other than getting rock in and stripping gear...never had problem...
s10dude is offline
  #6836
razzor's Avatar
Bud you can relocate the pins to new holes on the pulley.Just press fit them with some good loctite.Ive done it for some guys.
razzor is offline
Old 05-31-2007, 09:38 AM
  #6837
gansei's Avatar
Default rear bound problem in high traction.
i had trouble rear bound problem in cornering at high traction in FEMCA 2007.
especially.. it was appeared in rapid cornering. (end of backstraight in front of pilot seat)
sadikin(NT1 Indonnesia Driver who had 3rd position in FEMCA 2007)
said that front diff system had a rear bound problem in JITC...
so he changed front diff to oneway system, then solved that problem.
i heard sadikin's that talk after FEMCA 2007 end.
But i could not understand why front diff had rear bound problem in JITC (especially high traction)
do you know the reason?
gansei is offline
Old 05-31-2007, 12:21 PM
  #6838
Hey gansei, I have a question for you...Where do you get the knack shocks and differential stuff?
diesel001 is offline
Old 05-31-2007, 12:23 PM
  #6839
Hey charles, you need a stock brake pulley? Hit me back, I am sure I have a few of them lying around.
Old 05-31-2007, 12:24 PM
  #6840
rcrevolution's Avatar
sigh, absolutely no one has the hudy gauges in stock, guess im ordering the TM ones tonight.
rcrevolution is offline
