Old 05-29-2007, 11:11 AM   #6781
asw7576's Avatar
Is Gansei back yet ??
Old 05-29-2007, 11:36 AM   #6782
Where can I pick up a front differential kit? Or what do I all need to order?
TM G4S with custom upgrades
Sanwa M11 Prestige with Spektrum Pro
Titan Tools
Hard Tools
Blitz Mazda 3
Blitz Saab 93
JP Engines
Tornado Fuel
www.racedayhobbies.com
diesel001 is offline   Reply With Quote
Old 05-29-2007, 12:09 PM   #6783
razzor's Avatar
Bud just mail or call Sam at Raceday and hell hook u up with everything needed.
Im sure Gansei would be back home by now.
Hope he pops in soon.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-29-2007, 12:14 PM   #6784
Ok, thanks, I will just talk to Sam over the next few days, once he gets the new goodies in!!!
Titan Tools
Hard Tools
Blitz Mazda 3
Blitz Saab 93
JP Engines
Tornado Fuel
Old 05-29-2007, 12:16 PM   #6785
razzor's Avatar
yeah the new goodies
Im waiting for that too.
Casterracing ZX1.5R
Old 05-29-2007, 12:16 PM   #6786
Yeah I cant wait to get the new rear sway bar setup
Titan Tools
Hard Tools
Blitz Mazda 3
Blitz Saab 93
JP Engines
Tornado Fuel
Old 05-29-2007, 12:50 PM   #6787
rcrevolution's Avatar
Send a message via AIM to rcrevolution
I have a few questions.
1) does the team magic setup gauges clear the middle body post on the G4S? the Hudy one oes quite clear it.
2) what parts have you broken on the car? I went to the track yesterday for pratice and after 4 hours left with no broken parts, my thrust bearing did come off on the track but I was able to find everything.
3) any news on a crash kit by Sam? I haven't been on here for a while so I don't knowif he mentioned anything.
4) Is the regular touring bag by TM big or is it not worth the $90? I know someone who has the 1/8th but I don't feel like spending $200 on a bag nor carrying around something that huge.
5) Finally, what weight are you running on the rear diff and in the shocks. I am running what came with the kit, is that a decent setup?
rcrevolution is offline   Reply With Quote
Old 05-29-2007, 01:20 PM   #6788
razzor's Avatar
TM setup works like a charm no hassles with it and the 5th body post doesnt get in teh way
Provided you dont have bad accidents the car is very robust.
Usual spares needed is a-arms ,hubs and belts.rest is what u think you would need.
Not sure but give Sam a call.
The Touring bag is very good only downside is the cardboard draws.
It does carry all teh necessary spares and equipment with out any hassles.
The std setup out of themanual is ok but depends on what type track you run on.TM site has some setups from last year of Brian Berry and Dennis Richey might be an idea to check them out.
general idea on shocks is thicker oil like 50wt/60wt with 1.2mm holes in pistons.As for diff id suggest 30k rear oil.
Casterracing ZX1.5R
Old 05-29-2007, 01:22 PM   #6789
Rear upper links strip out pretty easy(seems like a weak point in the car), control arms are always good to have spares of although I havent needed hardly any at all, belts are also a good thing to have spares of. You should get a spring kit or two so you can work on fine tuning your suspension. The oils that come in the kit are a good staring point and will get you going. I have the 1/8th bag and it is huge, I havent seen the 10th bag but I am sure for me it isnt big enough, I am thinking about a second 1/8th bag. I too would also like to know if the TM setup kit clears the 5th post or not.
Also, you should always have a spare bearing kit in your box as well.
Titan Tools
Hard Tools
Blitz Mazda 3
Blitz Saab 93
JP Engines
Tornado Fuel
Old 05-29-2007, 01:34 PM   #6790
ALG
Originally Posted by asil
track is resurfaced.. it's asphalt and there was no need to treat it
my set-up;
FRONT
width : 199 mm.
camber : 2 deg.
toe : 1 deg
caster : 2mm.
front gear diff: 30.000 wt
roll bar : 90 deg.
ride height : 5.5 mm.
shock oil : 50 wt.
piston : std. holes drilled to 1.2mm
spring : 1.6 mm (Team Magic)
tyre : left 42 shore 61mm, right 40 shore 61mm.
REAR
width : 200 mm.
camber : 3 deg.
toe : 2 deg
rear gear diff : 10.000 wt
roll bar : 45 deg.
ride height : 6 mm.
shock oil : 50 wt.
spring : 1.5 mm (Team Magic)
1st pinion: 18 spur:51
2nd pinion: 24 spur:46
Engine: CRF 2007
Clutch: 1 weight, std shoe, red spring, nut showing 1 tooth, 0.7mm clutch gap with minimal end play
here are photos;
ASIL try going harder on the dampers!! maybe a 60 or 70 (trinity or AE), and if you are looking for more initial turn in. 197mm front track play araound with the setting, I like my car with 37 front and 40 rear ( i can go like this when the track is very clean)
Have fun
ALG is offline   Reply With Quote
Old 05-29-2007, 01:39 PM   #6791
ALG
Originally Posted by Serpentd
Thanks Dude!! That is way too cool of you and everyone else to inquire about me. You guys a killer group of dudes and cyber friends that's for sure!
I will keep you all posted on my paint schemes. Ready to do a insane concourse soon. But that won't be for a few weeks with everything going on and all.
As far as the 3 new 1/8 scales, I will let you know where I address my posts for sure man!! I have only drove the Serpent '07 960 once since the build. That was last week at our local club race. I raced it bone stock right out of the box, defaust setup and that thing was already about 95 dialed. In fact it was so dialed that I wasn't sure what I could change to go faster. But I have some goodies for it just waiting to be put on. And they are some of the more serious upgrades like the smaller diameter ceramic bearings and stuff to lighten up the car a bit. As far as the Slide, well I'm missing like 3 very important parts for the newer rear end and swaybar set up. So I won't take it out till it's 100%. And my newest baby...the MOTONICA!!! I haven't really started the build yet because I am still cleaning out the grease from the bearings so I can oil them properly. But getting there. My guess with the Motonica is that there is less then 15 in the US. So I will be on my own with this puppy. But that's not an issue as I have already had about 4 dudes from all over the World already help out with my build and I haven't even asked anyone yet. They just keep tabs on who has one and offer the help. It's too killer man.
After I get all these 1/8th scales squared away, I need to go through my G4S as she is feeling neglected lately. Poor thing. But I NEED some of those parts that they use on the G4+...like the rear swaybar! Oh that is exactly what I wanted them to make...it looks like the shit man!!! These are the BEST type of sway bars IMO. Serpent has used them for years and you can dial in your car so much faster and easier with this little beasts.
Sweet guys!!! Well I need to try and paint some or something. Talk soon my KILLER G4S crew!!!!
SerpentD
I also have a 960 07 and the car is sweet, Im also fixing my G4S to transform it to a G4S+/- (not quite the complet+ but sort of it)
We have great cars!!!! have fun an the new CENTRAL body is sweet!!! LETS WAIT FOR THE NEW SHADOW
Old 05-29-2007, 02:22 PM   #6792
casimirsa's Avatar
Originally Posted by razzor
Generally chunking is from excursions off the race line or mixing it with fellow competitors
I run 64mm tyres and buy those stickers for the side wall or put some super glue/contact glue.
Might not be the right thing to do but haven't had anyone correct me.
razzor is right! use some contact adhesive and put about 2 layers on (let dry between 1st and 2nd application)
superglue ends up to be a bit hard and can cause issues going through corners!
Bottom line is, like Razzor said, stay on the racing line and away from other drivers and most of you problems will be solved!
"Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
TM G4S (ED), TM G4S,SERPENT M2+835+960FD, MUGEN SEIKI MRX4-X, MUGEN SEIKI MRX4 (WORLDS CHASSIS), MUGEN SEIKI MTX4, MUGEN SEIKI MBX5T, HPI PRO4, TAMIYA, PALMARIS, RB C5+C5 RODY+V12 RODY, NOVAROSSI, JP, AXE ROSSI, MEGA, NOVAMEGA KHM, KO PROPO, HITEC, GRP, UFRA, ROBITRONICS, SJ, LRP
casimirsa is offline   Reply With Quote
Old 05-29-2007, 04:02 PM   #6793
dnitro's Avatar
Congrats Pattojnr.. this weekend 2nd round of Turkey Championship is held in Ankara.. Track is resurfaced and layout has changed and it's a tyre eating one ....with 42 shores in 10 mins tyre wear was 1.5 mm ! Seedings was not good because it was the first time for us to race there.. there was no time to practice. with some small tweaks like sway bars and tire shores MY G4S came alive
after quals we made C-final and in semi-finals we jumped to A-final! It was my first A-final experience and wow what an excitement!!! It was an 1-hour final and had to change tyres at 30 mins. My CRF 2007 was screaming and had no troubles with it..
Asil
Good job Asil on going from C main to A-main. That is an achievment in itself. I can just imagine racing in the A main for 1 hour with the big dogs. Must have been nerve wracking. Anyway, how did you place?
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 05-29-2007, 07:51 PM   #6794
gansei's Avatar
i arrived korea in yesterday at 6:30 AM.
But i was very busy for delayed my works.
and.. very tired... ^^
thanks for your favor in Jakarta.
i will write my report soon.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 05-29-2007, 08:40 PM   #6795
can anyone list all the bearing sizes the TM uses?
like the most important oones in the bearings and possibly the others, i don't think I would lose the car ones as much as the cltch ones.
also anyone know where I can prob get a cheap full bearing set.
when I say cheap i mean in price not quality, but i also don't want ceramic bearings or something that will be expensive.
deff rubber sealed tho
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
