Old 05-17-2007, 07:43 AM   #6616
I heard a rumour that the new sedan coming will be in fact a nitro car. I heard it from a friend who is in R & D for another RC company. He said we should see a new G4 version by next year. It is however just a rumour at this point so take it with a grain of salt and dont quote me on it. He has however been pretty well in the know as far as advancements with Team Magic go.
diesel001 is offline   Reply With Quote
Old 05-17-2007, 11:21 AM   #6617
asw7576's Avatar
Originally Posted by gansei
i will depart to Jakarta in tomorrow
i will do my best!! ^^
Have a nice flight !!!
See you in here !!! I'll take you for lunch on Saturday with G4S friends
Old 05-17-2007, 11:48 AM   #6618
afm
afm's Avatar
Originally Posted by rcrevolution
hehe whoops.
where do u find belts for like those, besides the TM replacements
Since gansei posted the numbers I've done some research and so far I could only find rear and front belts from these manufacturers
BANDO
synchronous timing belt 6mm wide 3mm pitch
70 T front P.N. 210-3M-6XP
OPTIBELT
70 T front P.N, 210-3M-HP6
64 t rear P.N. 192-3M-HP6
AFM
afm is offline   Reply With Quote
Old 05-17-2007, 12:10 PM   #6619
rcrevolution's Avatar
Send a message via AIM to rcrevolution
well keep doing some research, I found a place in the states that sells them but they are in inches and the closest i found was 4.7mm width same amount of teeth but a 5.11 inch length pitch! i dont think those will work.
is pitch the same thing as pitch length cause this place lists pitch then at the end pitch length. they have a 2.032mm pitch and a 5.12inch pitch length
here is the place.
https://sdp-si.com/eStore/
rcrevolution is offline   Reply With Quote
Old 05-17-2007, 01:13 PM   #6620
asw7576's Avatar
Originally Posted by Z00M
razzor, these are the numbers posted by gansei back on page 219.
Zoom: Why don't you come to FEMCA ? It's only 4 hours flight from Perth to Jakarta.
There are 4 seats STILL AVAILABLE for 1/10 class.
Australian can get Visa on Arrival. There is a booth with " Visa on Arrival " sign, you can see the sign before the immigration / passport control.
I'm just asking...........
Old 05-17-2007, 01:46 PM   #6621
mtveten's Avatar
Trader Rating: 27 (100%+)
stick with the std TM low friction belts, with proper belt tension they will last as long if not longer than conventional rubber belts.
Reinforced urethane belts like the TM ones have have less friction, better heat resistance and do not stretch nearly as much as rubber belts do. The only thing you need to watch for is teeth stripping off the belt. Aside from debris in the drive train tooth stripping only occurs under hard braking when the belt tension insufficient.
Rubber belts are naturally more forgiving in terms of belt tension but also heat up, stretch, and increase friction. The heat built up and stretching that loosen the belt can also result in thrown & snapped belts.
Mark
mtveten is offline   Reply With Quote
Old 05-17-2007, 03:39 PM   #6622
Send a message via ICQ to Forser Send a message via MSN to Forser
I bought a G4S RTR earlier this year and is about to roll it out on the track for the first time soon and i noticed one thing in the manual that comes with the car from TM.
It doesn't say anything about breaking in the engine, have they done something new with it or is it still recommended todo a break in even though the manual just say, start the car and race.
Best Regards
Marcus
Forser is offline   Reply With Quote
Old 05-17-2007, 03:44 PM   #6623
mtveten, but I found a place where they make urethane belts reinforced with kevlar or fiberglass for $2.80 a belt!
if I can find measurements that work wouldn't these be nice substitutes?
Old 05-17-2007, 04:16 PM   #6624
razzor's Avatar
Best Regards
Marcus
Bud make sure you run in teh engine or do at least a half dozen runs with a rich setting and gradually lean out the tune to race pace.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-17-2007, 04:18 PM   #6625
Yeah, i will do a break in of course, just wondering why TM seemed to ignore that info in there manual.
Wonder how many that follow there docs and runs it at full speed directly without breaking it in!
Thanks!
Old 05-17-2007, 05:58 PM   #6626
Z00M's Avatar
Trader Rating: 15 (100%+)
That would be marvellous! However, back here in reality, I can't afford such a trip. I am making preparations to go to the Australian Nationals in October in Victoria. That will be my first big away race. If I had sponsors, I could get them to fund my racing but that just isn't going to happen Nice thought though.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 05-17-2007, 07:42 PM   #6627
rmdhawaii's Avatar
Originally Posted by mtveten
Well I have the G4S and a buddy of mine bought the RRR and both cars are exremely competative.
Comparing the 2 the G4S is lower maintence, and comes with all the beefed up parts required that cost extra on the RRR WCE. Out of the box the Kyosho gearing is far better for most parking lot tracks but the magic can get where you need by changing the brake pulley, & pinions for about $50.-
I have noticed that the magic seems to have a perfomace advantage over the Kyosho on low grip & bumby tracks that seems teven out as conditions improve.
Mark
Mark ~ What brake pulley are pinions are you referring to in this post?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-17-2007, 08:02 PM   #6628
charlesd's Avatar
Quick question,
has anyone managed to fit a jr rs300 receiver in the g4s? And if so, how?
charlesd is offline   Reply With Quote
Old 05-17-2007, 08:51 PM   #6629
vc05hdt's Avatar
Aussie titles good Mike. I stuffed up my plans and now not competing in WA States and missing FEMCA as going to Bali 26 May
vc05hdt is offline   Reply With Quote
Old 05-17-2007, 09:13 PM   #6630
asw7576's Avatar
Because you are going to Bali ..... plz don't forget to beat up Alan Situmorang and send his head for grinder
Have a nice vacation !!!
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
