Old 02-20-2006, 05:44 PM   #646
4F1Racing's Avatar
Al could you send it that way to me also at racedayhobbies.com..
Sam
4F1Racing is offline   Reply With Quote
Old 02-20-2006, 06:07 PM   #647
al
Send a message via AIM to al
ygm
al is offline   Reply With Quote
Old 02-20-2006, 06:39 PM   #648
4F1Racing's Avatar
Thanks Al. I have your setup posted on my setup page along with Darren Johnson's setup. This should help all of us get some base setup ideas and then tune for track from these points.
Sam
Old 02-21-2006, 01:03 AM   #649
MLCG4s's Avatar
Default G4S Running Time
Hi to all,
How much running time are you getting out of the G4S battery pack that was included in the KIT.
I'm running KO digital servos and the pack didnt last even 30min.
MLCG4s is offline   Reply With Quote
Old 02-21-2006, 03:50 AM   #650
NiMo's Avatar
Originally Posted by MLCG4s
Hi to all,
Dunno about run time but the first charge only took 10 minutes, 2nd charge took 25, third and fourth charges took 40.
First charge as for set up day (Saturday) with the 2nd charge after 20 minutes of radio use. Third charge on race day for 4 rounds qualifying (5 mins + warm up) and fourth ready for the finals.
NiMo is offline   Reply With Quote
Old 02-21-2006, 06:56 AM   #651
XTREMERCHOBBIES's Avatar
Good showing guys! Our set up is almost similar to Al's set up - we are using 1.6 in front and 1.7 in the rear (we will try al's set up tom). Our time in our track is .3 sec slower than the mugen mtx 4 - we are slowly getting faster just having a hard time adjusting to the g4s because it is totally different from the g4evo.
What is the difference between the new rear belt tensioner compared to the old one? I went back to the old tensioner because it seems to be more stable on on-power steering than the new one. Also, I changed the new bevel shaft in the gear diff with the old one because the new one seems to make the diff harder with 10K diff oil.
Any suggestions and comments?
Thanks!
XTREMERCHOBBIES is offline   Reply With Quote
Old 02-21-2006, 09:10 AM   #652
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Big things are happening for G4S in 2006.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 02-21-2006, 10:04 AM   #653
MLC
we found the battery needs to be cycled a few times to bring it up.
Motorman2 is offline   Reply With Quote
Old 02-21-2006, 02:58 PM   #654
Trader Rating: 44 (100%+)
Does the G4S use the same steering knuckles as the G4evo?
Or are they the hardened composite K-racing ones?
Ditto the A arms.
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 02-23-2006, 01:04 AM   #655
Sow&Steady's Avatar
Part 2 of the build review is now online at 3hobby.net.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 02-23-2006, 07:17 AM   #656
MLCG4s's Avatar
how many amps is good for the battery to charge it , couse i have the ko propo BX-213mh charger
Old 02-23-2006, 07:32 AM   #657
one half amp. no more than 1. one half amp will provide the longest run time.
wylo3
arms and knuckles are same as evo.
Old 02-23-2006, 08:33 AM   #658
MLCG4s's Avatar
exactly you meen 0.5 amps 1.5 amp couse the battery when i built the kit i where charging it with 0.5 and in the race i just run for 12 mins and then i discharge it an chgarge it again in 1.0 amp and lasted longer
Old 02-23-2006, 10:21 AM   #659
we found the battery needs 6 good cycles or so to attain full runtime. full charge, full drain
Old 02-23-2006, 02:01 PM   #660
fastrcracer's Avatar
Just want to say, good job to all the guys that went to Ft. Myers and ran the new car with Dennis. After only having the car in hand for a couple of weeks, you all did very well.
Associated FT SC10
Futaba 3PK
AKA Tires
Maxamps Batteries
SRI Raceway, Louisville KY
fastrcracer is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
