Old 05-05-2007, 03:24 AM   #6391
asil's Avatar
Send a message via MSN to asil
Frankie, some guys here use the same oil for after-run and airfilter.. I don't think it caused trouble with your motor.
Asil
asil is offline   Reply With Quote
Old 05-05-2007, 03:25 AM   #6392
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
lmao as funny as it was at the time and still is now his airfilter oil isnt a realli thick oil its very similar texture to after run oil very thin so i dont think it will do anything but in saying that i have never put any in there to test it out........
MaDaGAS CAR is offline   Reply With Quote
Old 05-05-2007, 03:37 AM   #6393
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
hahahaha - yes we both laughed
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 05-05-2007, 03:38 AM   #6394
Asil
cheers Asil
Old 05-05-2007, 03:38 AM   #6395
razzor's Avatar
Kodack there shouldnt be a problem with the oil.
and for info sake i am using a earosol performance airfilter oil for 1/1 cars.
Its by Kingdragon and similar to the K&N stuff.As for after run Mobil1/Castrol RS/Petronas Syntium 0w20/30 is perfect and hasnt given me any hassles at all.In fact my engines are cleaner than ever compared to afterrun oil and ATF.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-05-2007, 03:48 AM   #6396
coolness,
today i had well some lonely practise at my local track, had to meet a friend later in the arfternoon, thou it was good to try spring settings on the car!
tried a variety of sets:
TM spring set keep in mind...... from Raceday Hobbies "PLUG"
K-factory 38 SHORE ALL ROUND 19 degrees day very cool green track
1st runs: PINK front
MAROON Rear
Results: with setup - not too bad, good steering in taily out
2nd runs: Blue FRONT
PURPLE Rear
great fast turn in and more stable on high speed straight, come out of turns very loose if on gas too quick...!
I recon a 30K diff oil will get more rear drive ????? not sure shall try
Overal i was driving it hard - changed to MAX droop on front and REAR and ride heights around 7mm to 5mm differances on differant tanks
but yeah was driving it a lot hard for sure today pushin the edge on me solo own...!
Tip and NEWS for us Locals they have taken out a part of the MID sector of the track so no more PRO launch in the AIR - makes for more room to improve lap times...
i look forward to the next meet.......
Old 05-05-2007, 04:06 AM   #6397
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
will team magic be releasing a new kit anytime soon?
cHckbOY5 is offline   Reply With Quote
Old 05-05-2007, 08:00 AM   #6398
casimirsa's Avatar
Red face CLUTCH PROBLEMS - PLEASE HHHEEELLLPPP!!!!!
I am experiencing a very wierd problem! I keep on loosing clutch!
My spacing is .4mm with .01 endplay, Use TM black Shoe, 1.8mm black spring.
I have tried 1 and two weights.
last time I have removed brake arm to ensure it is not the brakes binding!
ED drive train, with standard pinions and 52 first and standard 2nd spur.
I have checked the bell has no sharp edges that can eat the shoe away!
6-7 tanks and the clutch shoe is warn down to the stage it does not engage any more!
PLEASE HELP!
"Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
TM G4S (ED), TM G4S,SERPENT M2+835+960FD, MUGEN SEIKI MRX4-X, MUGEN SEIKI MRX4 (WORLDS CHASSIS), MUGEN SEIKI MTX4, MUGEN SEIKI MBX5T, HPI PRO4, TAMIYA, PALMARIS, RB C5+C5 RODY+V12 RODY, NOVAROSSI, JP, AXE ROSSI, MEGA, NOVAMEGA KHM, KO PROPO, HITEC, GRP, UFRA, ROBITRONICS, SJ, LRP
casimirsa is offline   Reply With Quote
Old 05-05-2007, 08:33 AM   #6399
Pattojnr's Avatar
Trader Rating: 19 (100%+)
PLEASE HELP!
if your clutch shoe is wearing fast, then try backing the spring off. you may have too much slippage before it fully engages. what is your spring tension ?
and when you rclutch shoe wears like this, it also changes the clutch gap. so redo your 0.4 clutch gap and try again with the spring tension backed off. hope this helps..
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-05-2007, 08:36 AM   #6400
Pattojnr's Avatar
Originally Posted by Kodak Hodak
Question on Motors?
Also in regards the IDM - motors, one of our lads have bought one here but has no luck in getting Glow Plugs "calling PATTO where do you shop for glow plugs"?
cheers
Been speaking with Shano, trying to source some locally for him. but i will get some from Sam. i have tried an OS plug (too deep) and a nova Plug (too shallow). ill try a Ninja Plug tommorow and see if it is the same.
Serpent - Walter RC
Old 05-05-2007, 08:41 AM   #6401
so did shano get a idm awesome if he did cant wait to see the little sucker go
Old 05-05-2007, 08:47 AM   #6402
razzor's Avatar
Mega DSII plugs will/should work as they are also Picco based.
Casterracing ZX1.5R
Old 05-05-2007, 09:58 AM   #6403
vc05hdt's Avatar
Bedtime Patto, racing tommorow!
vc05hdt is offline   Reply With Quote
Old 05-05-2007, 10:00 AM   #6404
Pattojnr's Avatar
ha ha ha , now its after midnight, i can go to bed.
just waiting for stuff to finish charging, maybe 10 mins or so.
Serpent - Walter RC
Old 05-05-2007, 10:12 AM   #6405
casimirsa's Avatar
.Last shoe the spring was 0.2 mm and the spacing redone from scratch before running!
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
