Team Magic G4
#6316
Originally Posted by British Menace
Ooooh......looks whats available!
Just got mine today!!
Ouch
Ouch
I got a question for you guys. I have the JLR red dot and the IDM evo3. Are they the same motor? The JLR states 1.6 hp and 41,000 rpm and the IDM states 1.4 and 40,000 rpm. The IDM has a shorter head though. I'm just too lazy to open up the motor.
#6317
Ouch
Ouch
Mine just cleared customs. Should be here tomorrow or Thursday!!
#6318
guys, i just want to check when ur tires get smaller, are u still able to set the ride height to where u 1st install the new tires? i did mine for 5mm front and 6mm rear, but then its like when the tire gets smaller, i can only make it to 3mm front, and 4.5mm rear, no matter how tight u screw down the shock.
i have tried to lengthen the shock length, its ok now for front, but not for rear, so can i check the shock length? and another question is doubt is the shock refilling oil process, normally i filled it to the max, then pump the air out, then i replace the shock cap, but mostly, i can't get perfect similar shock bouncing tension. and some of the oil will overflow out when u replace the cap. hope someone can share some info on this. thanks.
#6319
Originally Posted by Neesh
lol! I just got mine in today too!
By the looks of the crank work done too. I'm expecting a prity powerful top end too.
For those who run on low grip tracks. I ran the car on a tight, bumpy track last Sunday and although I had slightly too much off power push for my liking still at the end. It had great on-power steering and a solid rear.
Track: Tight/ Bumpy
Body: Mazda 6
Front:
Speedshot Front: Stock setting.
Spring: 1.5mm TM
Damping: 50WT Losi
Piston Holes: 2/ 1.4mm
Damper Position: Top: 2nd out: Bottom: outer
Toe: +0.5 Degrees
Tires: K Factory 38S @ 64mm
Ride hight: 5mm
Droop Setting: +2mm
Diff: Gear 100,000WT Mugen
Role bar: None
Track 199mm
Rear:
Spring: 1.4mm TM
Damping: 50WT Losi
Damper Position: Top: 3rd out: Bottom: Outer
Toe: -2 Degrees
Tires: K Factory 40S @ 66mm (Brand new)
Ride hight: 6.5mm
Droop Setting: +5mm
Diff: Gear 20,000WT Ofna
Role Bar: None.
Track: 199mm
Top Link: NO shims (Flash point rear)
Wheelbase: 2mm shorter
Clutch:
Red shoes, Red pressure plate.
No weights
Mugen Silver 'Super Hard' clutch spring.
Tension: 0.3mm
Gap: 0.5mm
End play: Minimal. (0.05 - 0.1mm)
Gearing: (ED)
15/20 Pinion
51/47 Spur
I started the day with a very similar set-up but at 7.5mm rear ride hight and 4mm rear droop. With also 2 shims in the rear top link and 0 front droop setting.
This gave a car which was a little loose at the rear on power and which wanted to push just a little, again on power. I don't know about you guys, but I like the rear of the car planted when on power. Gives you more confidence I think.....
Anyway. I changed to the set-up above and the rear was very nice and with excelent on power steering like I said. I think the 100,000WT front diff helped with that too.
If I had a little more time, I was going to come down a spring at the front to try to gain a little off power steering. But I was very happy with the car like this.
Sorry for the long post. Got carried away.........lol
Regards All.
Menace.
Ps. Thanks Sam at Raceday Hobbies for helping me out with that two speed stuff and the advice over the phone. Anybody would think he's not very busy???!!...lol
And YES....he does this for everyone. (As most of you probably know by now.)
#6320
Try backing the droop screws all the way out, then adjust ride height, the re-adjust the droop.
#6321
Originally Posted by Danjr
Straight line stability will decrease I think.THere are no parts to my knowledge.
By the way, my G4S arrived on my birthday yesterday and thanks to Sam @ Raceday Hobbies and Patto for assistance. I opened up kit today and cannot believe the high standard Team Magic have achieved; not only in packaging but with manual. Thanks TEAM MAGIC!!!!!
#6322
As the others have said the G4S has a relatively long wheelbase and I have noticed my car is not turning in the way I would like so I have shortened it in search of some better turning. THis will obviously effect the straight line but will see how it goes.
#6323
#6324
Hey All.
Thanks to Patto I can now post pix of things on here instead of having to try and right a thousand words explaining stuff........
One of the things I noticed on the car was the throttle linkage/servo horn. The one on the top deck. It would always seam to wabble when you apply throttle and brake.Even though it was housed in a bearing.
I found if you put a second bearing under the flanged one supplied. This seats in the top deck nicely and stops this wobble. The horn then actuates nice and smooth and stable.
Try it....
Sorry about the photo not being too in focus...........hey I'm learning...lol
I think you can still make out what I'm on about.
Try it....
#6325
Ouch
Ouch
the crank work i noticed stright away. bit more agressive than the EVo2. i think most of the power of this engine will come from the crank work Danielle has done. EVO2/EVO3 not really much sleeve work. so maybe a little more imporovement can be made in the future
weather permitting on sunday, i hope to try the motor wiht the Nova 2601/6 fin manifold, and the IDM pipe. so ill let you know how i find it .
#6326
Another....
The two speed housing I felt could be improved. As you can see in this photo, some extra material has been milled out and one large bearing instead of the two was also fitted.
This new bearing is 5mm wide so there neads to be a shim between the bearing and the drive pin that locates into the two speed cam. I felt the speed the two speed shaft runs at, (17,000 rpm with stock gearing, 13,000rpm with ED) it's very hard on those small bearings.
Menace
Menace
#6327
Originally Posted by Pattojnr
Hey Menace, i got mine yesterday and after tonight, i have run 4 tanks through it
I'm very envious. I haven't been able to run mine yet. I'm doing 12hr shifts at work (AT NIGHT TOO !! ....Not fun !!!)
I did manage to get the clutch on it though!
I'm planning on the 2601 Pipe too. Let us know how the IDM pipe goes.
Menace
#6328
Hey All.
Try it....
Try it....
now i have heard it all.
a picture that is toooooo infocus.
at least where the battery sits is in focus.
now you have the program to resize your pics. some practice in taking them.
just a bit of fun. try taking the pic further back, and use some ZOOM
sorry, i have had a long day, is it a KODAK camera ? ill stop it now
seriously, take the pic from a further distance, use some zoom if you have it in the camera. as the flash wont affect things as much. and the whole pic will be infocus.
and MEnace, ill get you some measurement on the TM setup station for you.
#6329
Hey All.
Try it....
Try it....
#6330
Well it has been a while since pottery and camera class at school...........lol
I have to go and build a trampoline for the youngster now.......
One of the jobs I have to do before I go away this weekend for the Big race in Cincinatti.
Rather work on the car as it's in a million pieces at the moment
Still, family does have to come first.................only by a neck, but still first.
Menace
Menace
