Old 05-01-2007, 03:15 AM   #6301
shano's Avatar
Send a message via MSN to shano
Default New Conrod
Hey guys just ordered new conrod for my LL3 is there anything I should be weary of or need to do when changing it and also will I need to run it in again.
shano is offline   Reply With Quote
Old 05-01-2007, 08:52 AM   #6302
razzor's Avatar
Shano you can run it it in a bit but nothing as dramatic as a new engine.
Just get it started and idling a bit and then hit teh track at ok pace for a good few laps or tank at most and it should be good to go.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 05-01-2007, 09:04 AM   #6303
gansei's Avatar
Originally Posted by razzor
Thats correct max carb size is 5.2/5.4mm.
that max carb size is 5.5mm
you can see detail rule in www.ifmar.org
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 05-01-2007, 06:25 PM   #6304
When shortening the wheelbase at the front (2mm) I have noticed that the swaybars then require a spacer to allow them to clear the bulkhead which means it isn't all that strong. Is this the way that you guys have done it or I am missing something?
www.rcgear.com.au
www.novarossi.it/
www.teammagic.com.tw/
www.jacoracing.net
Danjr is offline   Reply With Quote
Old 05-01-2007, 06:54 PM   #6305
British Menace's Avatar
To shorten the wheelbase of the car. The material is taken from the rear wishbones/ A arms. The front of these you shave off between 2 and 3mm.
You then add shims/spacers at the rear of the hinge pin between the a arms and the rear baulkhead cross brace.
Ensure the a arms still move smooth and free without your shocks connected but with very little fore and aft movement.
Hope this helps.
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 05-01-2007, 07:43 PM   #6306
Hope this helps.
Menace
Thanks,
I have done this also, but I was looking for 4mm so did the front also.
Cheers
www.rcgear.com.au
www.novarossi.it/
www.jacoracing.net
Old 05-01-2007, 07:47 PM   #6307
rmdhawaii's Avatar
Danjr ~ If you don't mind me asking, why are you shortening the wheel base? Is this a common practice on the G4S? Thanks!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-01-2007, 07:57 PM   #6308
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
In some cases it adds steering and grip. This is a pretty common thing to do on the MRX4R.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-01-2007, 08:35 PM   #6309
Thanks,
Cheers
If you have also taken material from the front A arms, yes this will give you the option of shortening the wheelbase down by 4mm (which is alot!)
But remember, if you run with the car shortened at the front, this will effect your castor setting.
You will nead to adjust your castor clips accordingly.
The shortening of the G4s wheelbase is quite common as it really helps in getting the car to rotate better in the corners.
Menace
Old 05-01-2007, 08:39 PM   #6310
Ooooh......looks whats available!
Just got mine today!!
Ouch
Old 05-01-2007, 08:49 PM   #6311
rmdhawaii's Avatar
Scott/Menace ~ Thanks for the responses.
If the mod is that common, does anyone know if TM is going to come out with the option parts to shorten the wheelbase or update the kit itself? Is there any reason why someone would not want to do the mod?
Old 05-01-2007, 08:51 PM   #6312
As the others have said the G4S has a relatively long wheelbase and I have noticed my car is not turning in the way I would like so I have shortened it in search of some better turning. THis will obviously effect the straight line but will see how it goes.
www.rcgear.com.au
www.novarossi.it/
www.jacoracing.net
Old 05-01-2007, 08:55 PM   #6313
Straight line stability will decrease I think.THere are no parts to my knowledge.
www.rcgear.com.au
www.novarossi.it/
www.jacoracing.net
Old 05-01-2007, 08:59 PM   #6314
rmdhawaii's Avatar
Ouch
Thanks for making us all jealeous.
So what matching pipe(s) did you get? 2607 or 2617? What is the difference between them?
Old 05-01-2007, 09:37 PM   #6315
Team Magic are aware we like to do this and they are on the case. Option parts for this mod are in the pipeline as are others we nead
Yes.......straight line instability may result but if you run good toe in at the rear and maybe 1 to 2 degrees out at the front. It should be fine
Menace
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
