Old 04-30-2007, 09:48 AM   #6286
vc05hdt's Avatar
Originally Posted by msteeple
Hi guys hope you all can give some advice here. Ran some race on my local track and after doing about 10 laps noticed that there was no second gear change, bought car in and second gear was stripped down. Changed gear ran again and same happened. On third try both first and second gear was stripped down. Checked to see engine/gear mesh was not aligned but was aligned perfectly. Any suggestions ???????
If you have time, go back I think about 50 pages as there was some dramas reported in thread about gear stripping with correct mesh (???)
vc05hdt is offline   Reply With Quote
Old 04-30-2007, 10:04 AM   #6287
vc05hdt's Avatar
msteeple go to page 170 and read and see photos on one of Pattjnr post. The previous posts and Patto's might assist you to sort problem
Old 04-30-2007, 10:18 AM   #6288
ALG
Also check if the sencond gear housing is fitted correctly with the 2 bearing, because you get alot of play after a while of using it the aluminum gets worn out and the 2nd gear start to wobble. You can do two things change to a new housing OR try to install a diferent size bearing (same inner size but larger outter dim. The bearing must be PRESS FIT to the 2nd gear housing.
ALG is offline   Reply With Quote
Old 04-30-2007, 11:22 AM   #6289
gansei's Avatar
Default GR modified OS 12TZ 3port engine
this GR modified OS 12TZ 3port engine will be my Femca Main Engine.
the second engine is Rex 3port engine.
this GR 12TZ show awesome high speed.
http://pds39.cafe.daum.net/image/47/...2449d9ed4&.JPG
http://pds39.cafe.daum.net/image/17/...244a0b215&.JPG
http://pds39.cafe.daum.net/image/17/...244a32abb&.JPG
http://pds39.cafe.daum.net/image/25/...244a5b6ea&.JPG
http://pds39.cafe.daum.net/image/32/...244a81852&.JPG
http://pds39.cafe.daum.net/image/40/...244ab57f5&.JPG
http://pds39.cafe.daum.net/image/3/c...244ae7c73&.JPG
http://pds39.cafe.daum.net/image/29/...244b22fd3&.JPG
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 04-30-2007, 11:38 AM   #6290
razzor's Avatar
that looks sweet Gansei.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-30-2007, 11:47 AM   #6291
asw7576's Avatar
Is this IFMAR / EFRA legal engine ? You better check it first..... especially the crankshaft part.
Old 04-30-2007, 11:52 AM   #6292
gansei's Avatar
i know that IFMAR / EFRA legal has some restriction about shaft.
But the restriction was disappeared as i know in recent days...
MY SPONSORS:
Old 04-30-2007, 01:06 PM   #6293
razzor's Avatar
for 2007 i think the crank rules have been scrapped.
only real limitation is .12 capacity and 3 ports as well as 5mm or is it 5.2mm stinger on pipe.There used to be a ruling about Ceramic bearings but i think that is also in the past.
Casterracing ZX1.5R
Old 04-30-2007, 01:31 PM   #6294
Sow&Steady's Avatar
Wow, that is a scary looking engine !
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 04-30-2007, 05:34 PM   #6295
British Menace's Avatar
Something I nead to tell you guys about.............
Becareful when applying thread lock to the ED system "end-of-shaft" pulley screws!
I had a problem this last Sunday.
When using the ED two speed shaft and the Stainless Steel two speed cam. (The K Factory one) The tolerence between these two parts is sufficient, but still small. It is actually a nice fit, but............
When you have finnished assembling the two speed and you go to put thread lock on the screw, it can get between the two speed cam and the ED two speed shaft.(It even got as far as the two speed bearings?! )
And I didn't put that much on either!!!
I'm thinking, the heat generated from the two speed and maybe the brakes, was enough to soften it enough for the fluid to get that far down!
Anyway, the result was that the two speed shoe's and K Factory cam would not come out!! It was that fast in there I actually thought that the drive pin at the back of the cam had brocken and somehow wedged itself in the cam, locking it onto the shaft.
But, alas, it was just the thread lock.
So, be careful using that stuff near your two speed. It was a messy job pulling the car apart without being able to part the two speed and the brakes from the rear baulkhead, just for the sake of a little thread lock.
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 04-30-2007, 09:44 PM   #6296
Piyo Piyo's Avatar
Looks very promising.
Hope our two cars can meet at the FEMCA track then .
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 05-01-2007, 01:32 AM   #6297
razzor's Avatar
Menace
BM i had a similar problem with teh 2speed clutch refusing to come out.Guys said i must have dropped the shaft and i should file it to let the cam slide out ok.
Before i went that extreme I unscrewed the shoes and released them leaving the cam inside.Turns out that the slot on the cam had somehow been pinched narrower and it wouldnt budge from the pin on the shaft.
Eventually levered it of and filed it a bit and reassembled the 2 speed and all was OK.
Casterracing ZX1.5R
Old 05-01-2007, 01:43 AM   #6298
Ok. Thanks Razzor I'll check the cam and see if it's pinching the pin as you had found.
That would figure if that was the case.
Although now I have them all apart. The cam slides on the shaft and onto the pin nicely again. But I'll check anyway.
Thanks again.
Menace
Old 05-01-2007, 01:46 AM   #6299
I think, If I'm not mistaken, there is still the rule on venturi size (diameter) on the carb air intake.
I think this needs to be below 5.4mm.
Menace
Old 05-01-2007, 01:51 AM   #6300
razzor's Avatar
Menace
Thats correct max carb size is 5.2/5.4mm.
Casterracing ZX1.5R
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
