Old 04-29-2007, 05:20 AM   #6256
shano's Avatar
Send a message via MSN to shano
Default Thrust bearings
Hey guys got a quick question for everyone or someone who can help.
I went down to my LHS to get thrust bearing grease and they gave me Tamiya Molyboenum Grease.The owner of the shop said this will be fine to use on my thrust bearings but am unsure cause the only flies and sells planes.
shano is offline   Reply With Quote
Old 04-29-2007, 05:24 AM   #6257
vc05hdt's Avatar
Originally Posted by Joe Tanto
Hi I just bought a G4 and it's with a one diff, the track I race on is a technical one so one way diff it's hard to use since you have to use alot of brake, which do you think it's the better option a spool diff or a normal diff?
What diff oils you use front and rear?
thanks
Joe F
Try normal gear diff and use between 50 to 100k diff oil
vc05hdt is offline   Reply With Quote
Old 04-29-2007, 06:00 AM   #6258
Z00M's Avatar
Trader Rating: 15 (100%+)
That's the same grease I use on mine. It works very well.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 04-29-2007, 06:03 AM   #6259
shano's Avatar
Cheers zoom just wanted to make sure before i used it cause i just bought ed trans and didnt want to screw anything up.Really appritiate it.
Old 04-29-2007, 06:25 AM   #6260
shano's Avatar
Default QUESTION NEEDS ANSWERING Speed Shot Front Bulkhead System
Hey guys just ordered Speed Shot Front Bulkhead System is there anything I need to do to this?I was told that the aluminum top brace has a weak spot and that it should be filled in.What Should I use, how do I do it neatly and where can I get it from?
Old 04-29-2007, 06:59 AM   #6261
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Hey Shano, roughen up the inside of the alloy and make sure its clean, if you have a bit of electrical tape, place underneath the 2 smaller holes to be filled.
any 2 part epoxy should be fine, i used a 2 part araldite. by using the tape underneath, you can easily fill to the top of the hole to make it level with the alloy. being clear (what i used) it has gone a yellowish color now. but i have done others with a 2 part epoxy , but in a metal paste. same strength, but it looks better. you can find this available at supa cheap autos. hope this helps
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-29-2007, 07:17 AM   #6262
Pattojnr's Avatar
thanks
Joe F
Hi Joe, on the spool i found that it was very hard on the front belts. once tires wore to same or rears smaller, the front belt wouldnt last very long.
so tire size is critical for a solid front axle. i did notice it was easier to drive , but lacked turn in . as i had to lock the front in one race only, i didnt run it for that long. a front geared diff will give better results, easier to drive, and most important for your question, 4 wheel braking. i know most guys are using 50K front diff oil, and 30K rear. best guys to ask would be Razzor or ZOOM. i know they run the front diff. i have one but its still sitting there waiting to get into the car. wont be long till i find out what works with the oils. untill then hope someone can help you out. surface and traction of the track you will be running on is a good thing to know as well.
Serpent - Walter RC
Old 04-29-2007, 09:00 AM   #6263
gansei's Avatar
Default FEMCA preparation.
i tested Mecamo 16% Fuel For 2007 Femca in today.
i used GR Modified OS 12TZ 3port engine.
i used head shim 0.1mm .
the GR modified TZ power is very good.
My RC friend Used Plus 2 engine in his NT1.
But my G4S (embeded GR OS TZ) faster than NT1 in high speed.
my second engine (GR modified rex 3port) For Femca will be tested
in next week.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 04-29-2007, 09:47 AM   #6264
British Menace's Avatar
Well put Patto. I agree entirely with what you say on the front diff' question.
Especially concerning the front spool.
Things I think to remember when deciding what front diff' to use........
Spool has very good 'power on' steering, but less turn in initially. Can be good on low, med' and high grip tracks!
Also, as patto has said it is critical on tire size.
Front gear diff' is probably the best choice but you do have to choose the right oil/greese to fill it with to make it work better then the other options.
Rule of thumb on these is the more traction you have at the track, the thinner the front oil can be.
IE: 100,000WT = low traction, 70,000WT medium, 50,000 med-high traction tracks. But it depends on how you like the car to feel. So personal preference here!
BIG plus on both these is you have four wheel braking!
Front one-way = you get very good turn in and very good 'power-on' steering.............but very little braking.
Another thing. If you choose a front gear diff, you will nead to play with different oils in the rear too.
Again, just a "rule-of-thumb" here............ the higher the traction you have, the thicker the rear oil in the rear. So......
Low = 10,000WT, Medium traction = 20,000WT and high 30,000 or even 40,000WT oil.
Just a guide line but I hope this helps.
As Patto has said, it does depend on the amount of traction at your track to guide you in what to use.
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 04-29-2007, 10:42 AM   #6265
gansei's Avatar
Default fuel efficiency
if fuel efficiency is bad..
what can i do to increase fuel efficiency?
1. carb ventury inside diameter size reduce.
2. head shim setup? (increase head shim.. and lock the main niddle?)
3. the other tip? (gear ratio change, 2 speed timing adjustment?)
pls give your tip!!!
MY SPONSORS:
Old 04-29-2007, 10:50 AM   #6266
Simpsons's Avatar
Default engine
HI ppl
Recently I bought a g4s rtr. It is a very good car in terms of handling but on the engine side I have some problems as it lacks in acceleration. Two guys at my local track have different opinions about my problem, one is saying that I have an air leak in the engine and the other one is saying that it can be something about clutch spring or the flywheel. Have you ever had this problem?
Simpsons is offline   Reply With Quote
Old 04-29-2007, 11:46 AM   #6267
asw7576's Avatar
Maybe you are still in break-in process. Wait until the engine is optimal and you can check again the fuel consumption.
My friends were having such trouble during Pre Femca Race, because they were using brand new engine, Novarossi Plus12 -3CT. They screw up during Qualifying, but in finals their engine made it to complete 17 laps in every 5 minutes for refueling.
How about using longer manifolds, like Novarossi manifold 7 fins and Novarossi EFRA 2630 pipe ?
I wouldn't touch no.1 & 2 like you suggested. Be patience and try again.
Old 04-29-2007, 01:33 PM   #6268
revo523's Avatar
Originally Posted by Simpsons
HI ppl
The tighter the clutch the more acceleration so play with your clutch adjustments.
revo523 is offline   Reply With Quote
Old 04-29-2007, 01:51 PM   #6269
Simpsons's Avatar
im a bit new in nitro cars what do you mean with tighter clutch? mine is the clasic type not the ufo one
Old 04-29-2007, 02:26 PM   #6270
Sow&Steady's Avatar
What pipe and manifold are you using for the Tz?
This plays a role and of course, other than that gear up and/or bigger tyre diameters.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
