Team Magic G4
#6136
i don't have any problem's w/mine sitting still..if it move's the clutch is set-up wrong or idle is too high....you got to be careful using parking lot's cause they have lot's of samll rock's that will get caught in the belt's and ruin belts/gear's...
#6137
Originally Posted by bcane98
Ya I googled the mongoose and found it to be the same looking... either way it's probably a rebagged G4 anyway...
So I got this bad boy out today!!! OMFG... This thing is fast as can be.. I was gonan race one of the guys that was bragging about is LD3 w/OS18CV... I think I could have easily taken him, but he put it away just after I got the motor up to temp...
I have one question though. I am used to the shaft diven RC's... Well to get to the point... do you find that belt driven are less likely to sit still while idling versus a shaft driven RC?
#6138
I think it might be in the clutch... I pretty sure about my idle cause any lower and it stalls... I started using 25% Nitro, so I did some low and high speed runs to give it a couple tanks of run in. A little fine tuning and I think I'll have this thing running right... My current running temps are in the 210-220 range...
I used to have a Traxxas 4Tec and the belts were fairly tight... the belts are kinda loose on the G4... not so loose they come off, but looser than the 4Tec... Does that sound right?
I apologize is these questions have been asked before... I need to DL the manual and give that a once over...
#6139
#6140
Cool rmdhawaii
let me know if we can help out with anything
#6141
Originally Posted by razzor
Cool rmdhawaii
#6142
Hi Guys, recently purchase a Falcon engine for my G4s. Just want to know if anyone here have experience using such engine, which can share.
Question: What difference can clutch hardness cause the car? Cheers!
#6143
Hey All,
Since all of us have been out of racing over the month, we all ended up racing this weekend just gone.... Overal the competition was tight and good racing.
I have taken a few pics to show the G4 crew on the day, i call us the LOCALS G4S....
As for my results:
Heat 1 4th - not overally happy on car handling (Changed the Springs)
Heat 2 6th - Glow plug failed last 3 2mins of race
Heat 3 3rd - Got the handling sussed and had a nice clean race (52T Spur Rocks)
TQ 2nd in Group B Final - Finished 3rd due to GLITCH (still getting that odd Glitch) damn it
Group A Final TQ10th - Finished 9th - i didnt have probs with the race, it was just everyone was on it and so close, so it was difficult to get up front as everyone drove well, i was coming 6th at one stage then a few little errors from me, and better driver got the best of me.
Lost a bit of power in Final due to climate change, but overall i finishd, nothing broken just gotta work out the Glitch
Cheers
Frankie
As for my results:
Cheers
Frankie
#6144
G4S MOVIE
i found some G4S racing Movie in YouTube.
http://www.youtube.com/watch?v=Mq99kgf428g
http://www.youtube.com/watch?v=fWnOFuDB0Ug
#6145
its not that bad
#6147
Originally Posted by rcrevolution
is you tube not loading videos for anyone else? or just my pc
#6148
#6149
Originally Posted by Kodak Hodak
Hey All,
As for my results:
Cheers
Frankie
As for my results:
Cheers
Frankie
#6150
Originally Posted by vc05hdt
What radio do you have Frankie?
I noticed that the antenna wire does not like sharp bends or kinks. If you have a kink in it replace the antenna wire.
Also make sure before the antenna goes through the deck it does not touch the aluminum parts under the deck.
Good luck
