Team Magic G4
#6031
Originally Posted by vc05hdt
SerpentD, where do you get the liquid mask from that you use? What brand
#6032
Shock stuff.
Hey Nitrobeast, Dude, that vaccuum thing I have might be discontinued, but not too sure. I have had it for at least 8 years. It's awesome. It's made by the company RIDE. So you might have to do a search for it. Maybe like RC Mushroom or something. RIDE is a Japanese company I think??
Also, with the green slime, If your shock is built then just put a thin layer on the shaft, not too much though. If your shocks are not built and the shaft is OUT, then I put a small amount on the end of the threads of the shock shaft to prevent scratching or scoreing the rubber O rings on the bottom of the shock body. After I am done building the shocks, I then put that thin coat of Green slime on the Shafts all the way around the shaft. Hope this helps bro!!!
By the way, Kick ass on your flying dude!!! I'm jelous as I have had NO time to mess with my planes. As far as a grass field, maybe some larger Diameter tires will help on take off. If you can land, then you can take off bro. You almost there dude. Great job my friend!!!!
Everyone can ignore this post if they want, I needed to talk to Nitrobeast real quick is all guys. Thanks everyone. Later.
#6033
shoe trouble
i found clutch shoe unbalanced wear out trouble.
it was shoe plate problem.
shoe plate meet with clutch bell by big crash in saturday exercise race.
so shoe plate wear out in one side.
and clutch shoe did not fit on plate.
so clutch shoe was put on plate in shape of tweak.
finally, shoe meet bell in one side, then shoe wear out unbalance
#6034
Originally Posted by Pattojnr
Gansei, that looks like there is something wrong with your fly weights or flywheel. to see that sloped wear, it looks like only one side of the shoe has been contacting the clutch bell. so either the weights are stuck in the flywheel on one side or the shoe is stuck on the pin of the flywheel. you need to check this out Gansei. the side that has had less wear and contact patch is the side it has stuck on the pin or the weigths not flying out.
Had a similar hassle a while back.
The shoe doesnt sit flat on teh plate so had to file the edge so shoe could sit flush to plate.
Also check the holes on the shoe is moving free on the pins.
#6035
SerpentD all of the best for the big race
and most importantly drive safely
Will be rooting for you
look forward to posts if you have the time.
#6036
Serpentd, have a good race my friend.. we're waiting for your race report..
Asil
Asil
#6037
New G4S RTR
Well I just got my G4S RTR in the mail last week. After looking at it I would have to say this is one good looking car. I can tell it is very well made. I just hope that I haven't gotten in over my head. Being that I am new to nitro powered RC cars I feel a little overwhelmed. I know someone had said this is the best RTR on the market and I do believe that. It's just that there is very little documentation to go with it, and what is with it seems to be in broken english. I ordered a book on nitro engines and how to tune them and I'm sure I can figure that out as I am somewhat mechanically inclined. One thing I'm not sure about though, is how you adjust the shift points on the the two speed tranny. If anyone could offer some info.(maybe with a picture) I would certainly appreciate it.
#6038
Ideally the shifting point is where the engine is very close to maximum rpm. You can hear the engine is screaming at 1st gear. However, there is possibility to shift gear earlier if the long straight is not long enough or the shifting point is too close to next corner or sweeper.
So, while you build the car, give the 2nd speed clutch shoe almost full spring tension at first, and then start releasing the tension by 10 to 15 minutes ( quarter turns increments ) until you notice the gear is shifting. Keep releasing the tension until you find the sweet spot.
#6039
Originally Posted by Serpentd
I use Bob Dively's Masking. Make sure you put on 3 GOOD coats with like a 1" painters brush. I usually just get it at Hobby Town, but you can get the larger bottles at like Tower Hobbies, This is where Hobby Town gets it from (Horizon Hobbies) in Ill. Good luck dude!! I think the 16oz. bottle is about $15 bucks, but will do quite a few bodies.
#6040
i spray mine on with my air brush...uncut....no diluteing...
#6042
If you have read the post by asw that will help. If you nead any more explanation then please ask. Remember to adjust the two screws the same amount each. It pays, if you have the time to dissmantle the two speed and colour one of the adj' screw head. This will help when you make your adjustments. It may also help to get, buy, beg borrow......whatever. A G4s manual. It will help in knowing the mechanical make up.
Good luck
Menace
#6043
Well fellas in the next month there's going to be a onroad track around my house and i want to start racing there but i don't know what i need for me to start racing.
#6044
Originally Posted by rcrevolution
how do u get that stuff through the spray gun, its so thick!
#6045
that is so cool
