Old 04-08-2007, 02:25 PM   #5776
Default EFRA GP, Spain
Team Magic win EFRA GP.
http://www.redrc.net/2007/04/darren-...anish-efra-gp/
jonrg is offline   Reply With Quote
Old 04-08-2007, 04:17 PM   #5777
rcrevolution's Avatar
Send a message via AIM to rcrevolution
Here you go!
My baby is all done, just waiting on warmer weather.....
rcrevolution is offline   Reply With Quote
Old 04-08-2007, 05:14 PM   #5778
EViLSouL's Avatar
Send a message via AIM to EViLSouL
Originally Posted by Z00M
Always good to see another kit in the mix. Welcome.
Just squeeze the ball cups a little with some pliers while they are attached to the balls. This will free them up. Only do it a little at a time though as it is easy to go overboard.
Thanks will try it tonight. Is this a common issue with the kits? I was going to switch to captured ball cups i.e. xray style ones.
schreff16 (7:28:40 PM): i just masterfully destroyed the shitter
EViLSouL is offline   Reply With Quote
Old 04-08-2007, 06:39 PM   #5779
Hey SerpentD I have a question, when you are doing a fade, how do you coat the fade area?
Like lets say silver to white, you do silver fade the middle and go to white
when u do a second coat would u just do everything all white or silver? or do u have to repeat that fade at the same spot for the duration of the coats?
Old 04-08-2007, 07:07 PM   #5780
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Hello All,
Well after a month off racing, i ended up racing for a friend as he is a member in our club and thought id help him out on the leader board to gain more championship points.
The weekend was Esater Sunday, and very small field of 1/10th Tourers "ONLY 5"
So my plan was to finish the day on a high note.
This weekend i tested NEW k-Factory tires: 38 Fronts & 38 Rears.
I can vouch the tires work very well, and hold reliablity on side wall much better than some prevouisly used such as SPEED brand.
In the Heats i finished in the following:
1st Heat - 3rd, 2 laps behind leader
2nd Heat - 3rd, 2 laps behind leader
3rd Heat - 2nd only 5 seconds from leader - this was a great race.
Keep in mind, the top driver of the day had very bad luck with 2nd Gear engament and if he was reliable then i could have been placed 4th all day.
but as race day happens anything can happen, and with some luck it can go your way if the GODS are nice
Ok A-Main FINAL 20min RACE:
4 x MTX4 Mugens & 1 X G4S MEEEEE!
4 Starters as 1 Mugen had broken parts so DNF
i personally TQ 3rd on the day so it was a good grid position thou 20mins race never done before i was more aiming to finish the race to my best.
So all on the grid, ready steady gooooooo! All mugens got in front of me at the start and i was postion in 4th at the first 5 min mark, to me this was a long race ao i just stayed behind and kept it clean. After first pit stop i was behind 10 seconds from 3rd and then my pit main gaind 10 seconds to put me in 3rd "thanks to my brother awesome pit man"
So there i was in 3rd and not too far behind second maybe half lap until he had a problem his belt broke and i was now in 2nd place for the rest of the race.
After 2nd pitstop i had to "BLINK" lol i swear it was hard to concentrate as i knew i had another 10 mins to race and 1 more pitstop was due.
Around 13mins into the race i had a glow plug burnout onme, lucky enough postion 3 drive had 2nd gear strip and i had i 13laps on him and was 2 laps behind leader.
So pit man raced car back into the pits where i had spare glow plug, we did have small issue where another pit man tried to help my brother, thou he made it even worse as he had no idea what he was doing RRRRrrrrrr - the nerve of some people, even my brother was pissed, anyways we got the plug in started it up and relaised the leader was 11 laps now in front LOL and 3rd man was on track gain on the 13 laps i had on him EEEEEK.
Once back on track, i saw 3rd man again strip gear so pressure was off, lucky enough i had planty of laps o n 3rd man to secure a nice wiin, even thou two cars left...
It wasnt the best last 10mins race for me, but hell its a race, its a postion and its more valueable points for my friends championship. LOL.
Overal it was a relaiable day besides 1 thing really:
K-FACTORY "low friction belts are POOOOO" i felt they just give way too easy on the teeth and did not last long enough.
Before main i changed the side and front belt just to keep the reliablity up.
The only main change i added tot his meet was:
New 52T second gear - very fast out of corners and start
New k-factory tires - 38 all day - Yes i kept the split in each race 62 front 64 Rear END of the race split 59 Front 62 rear
oh yeah i gave the engine a bit more grunt this time leaned the sucker to 235 and ran sweet all day.
Also second hand SAGE exhaust ran a dream, i think even better than NOVA as its seen better days.
Overal, was good to have a go and race, even if it was a small field.
So there ya have it, not bad for a Rookie with some luck
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 04-08-2007, 07:22 PM   #5781
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Well done Gansei and Frankie. Gansei, better luck next week but you must be happy to be so close to the top driver
Frankie ? you said you werent racing but anything can happen right well done onthe result. seems strange how you guys can race under some ones name and get them points ?
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-08-2007, 07:36 PM   #5782
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
yer kodak and toy000 bit shifty i reckon
MaDaGAS CAR is offline   Reply With Quote
Old 04-08-2007, 08:56 PM   #5783
Gascar 24's Avatar
Trader Rating: 15 (100%+)
well done frankie
but u should of kept the points for yourself
u might have need them at the end of season
be careful as there maybe penltys if the the club found out dude
paul
3 Racing f113
Savox, Thunderpower ,Speedpasion,Turnigy,DX3R
www.rcformula.com.au what a site for all your F1 needs
Gascar 24 is offline   Reply With Quote
Old 04-08-2007, 09:19 PM   #5784
Wayne1one's Avatar
Originally Posted by rcrevolution
Here you go!
Hey can u post some more pics of your picco JL red dot I am very interested in that motor
Wayne1one is offline   Reply With Quote
Old 04-08-2007, 09:23 PM   #5785
spork01's Avatar
Ive been hearing very good things about that motor especially for the price I think its gonna be my backup.
spork01 is offline   Reply With Quote
Old 04-08-2007, 09:48 PM   #5786
Pattojnr's Avatar
i just run in a IDM evo2 on the weekend, same engine as a JL red dot but has been modified. all i can say is WOW. see if you can get the IDM rather than the Red Dot, you wont be dissapointed thats for sure
Serpent - Walter RC
Old 04-08-2007, 10:55 PM   #5787
bjames's Avatar
Trader Rating: 24 (100%+)
Default hate to ask
I know its in this forum somewhere but there are almost 200 pages to sort through......Glitching problems, everyone at my track runs mugens and kyoshos and they all blame it on where my reciever is but I know there is a solution. I have a jr synth radio with a novakk synth reciever. Any advice would be much appreciated. I was thinking about switching to specktrum but $ is a bit tight right now. Thanks
-Brian James-
bjames is offline   Reply With Quote
Old 04-08-2007, 11:16 PM   #5788
looks nice patto, let us know how ya go with this next week...
Old 04-08-2007, 11:52 PM   #5789
Pattojnr's Avatar
i use JR XS3 synth radio, but i use the JR reciever with it as well. i havent had glitching problems at all. i do however fit te reciever in to 2 balloons before its sat in the car , this protects from fuel spillage. maybe the reciever has had some fuel in it at one point and is maybe damaged. you can try all the usual suspects, like run some fuel tube or heat shrink where the hole is on the radio tray and enlarge the hole, make sure there is insulation to where the wire enters the antenna holder, and mount the reciever to the top section of the radio tray not the cradle at the bottom. hope this helps
Serpent - Walter RC
Old 04-08-2007, 11:53 PM   #5790
Pattojnr's Avatar
unfortunately i wont be running it as its Marks motor, i am eagerly awaiting the EVO 3 maybe Mark will be a nice guy and let me run it
Serpent - Walter RC
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
