Old 04-07-2007, 12:36 AM   #5746
MLCG4s's Avatar
Gansei just relax , race and finish , Fear o doubt is the worst enemy , stand among them and face them equaly , sharp the blade of your sword(G4s )
and attack
wish you good luck
MLCG4s is offline   Reply With Quote
Old 04-07-2007, 01:48 AM   #5747
asil's Avatar
Send a message via MSN to asil
sunday will be the very first practice with G4S.. at the end of April, Turkey Championship begins
K factory brake lever, pads and disc arrived yesterday, waiting to be put on.
Orion CRF2007 is to be with me in couple of hours.
X5 II starter box battery is topped up.
1000mAh Rx battery is topped up, spare is also..
Ispirto Power fuel is ready.. (It's a special blend of fuel produced in turkey )
2700 mAh AA's are ready for M11
Will start with very basic set-up, then adjust according to track.
Protoform Mazda6 bodies will be painted by my WIFE tonight
I think everything is ready.. Only thing left is to drive 200 km's to track on sunday..
Will post you about comments after practice guys..
Later.
Asil
asil is offline   Reply With Quote
Old 04-07-2007, 02:30 AM   #5748
razzor's Avatar
Good practicing Asil ,the saying goes "practice makes perfect"
I got a few tanks threw my car yesterday afternoon and was very happy with setup.Need a few tweeks and get a good tune on the Axial12RR.
PR12 is flying.
Today will be going to practice again and do some tweeking on the rear to stop it bouncing on the bumps.Car has great steering and balance at the moment.
Running 60wt shock oil with 1.3mm pistons all round
Turquoise front springs .pink rear ,might go blue in front as the pink rears are fairly soft.
maybe softer shock oil on rear.
Mugen sway bar is so much better too ,a definate mod to consider
Ill post a setup sheet shortly.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-07-2007, 02:54 AM   #5749
shano's Avatar
Send a message via MSN to shano
Default Hey guys
FINALLY AFTER HAVING A MONTH OF I Had a practise run yesterday here in SA.Went really well and i was impressed with my setup.Car was bit slippery in rear till track warmed up after that it was fine, had good top speed and once again all i can say is that i was pleased with it.Oh well have to wait another 2 weeks for racing.But i have just ordered the kfactory 4mm chassi with carbon stiffners through my lhs.Cant wait
shano is offline   Reply With Quote
Old 04-07-2007, 03:12 AM   #5750
shano's Avatar
Default Engine bearing behind flywheel
Hey quick question im getting a small leak from behind my flywheel.Could this be comming from my bearings behind my flywheel if so where can i get a new bearing from?
Old 04-07-2007, 03:43 AM   #5751
asw7576's Avatar
Buy new front bearing for your particular engine..... I just did it today. BTW, you need somebody who has the right tool to open front bearing.
Old 04-07-2007, 03:46 AM   #5752
shano's Avatar
Cheers for that mate what tool do you need to open front bearing up and where can i get the tool and bearings
Old 04-07-2007, 03:53 AM   #5753
razzor's Avatar
Shano how old is motor ?
Have experienced this with newer engines and is usually too rich bottom.
You can expect some leakage on most engines.
Here is my current setup a promised.
TRACK : EVENT : CAR : WEATHER :28c
Southway Raceway Practice TRAP Nats G4S DATE : 6/4/2007
Fr TYRE(L/R)/SIZE(L/R) 59mm
G Fr TYRE WEAR(L/R)TIME
E Rr TYRE(L/R)/SIZE(L/R) 61mm
N Rr TYRE WEAR(L/R)TIME
E 1ST GEAR 15/46
R 2ND GEAR 21/52
A Clutch gap 0.5mm
L Clutch spring 1.8mm black
Tension/pre load 1mm
ENGINE Palmaris PR12
Glow Plug Nosram 6T
Pipe Skyline VR12+
Spring 1.6mm Turquoise
Oil 60wt GS
Piston 1.3mm
CAMBER L/R 2
F CASTER behind wishbone 3mm
R RIDE HEIGHT 4mm
O DROOP 2mm
N ROLL BAR 90deg
T SHOCK POSN Top 3 from outside
SHOCK POSN bottom outside
DIFF 50k GS
TOE 1 out
STEERING/HUB inner
Wheelbase 198mm
Spring 1.4mm Pink
Oil 60
Pistons 1.3mm
CAMBER L/R 3
R RIDE HEIGHT 5
E DROOP 1mm
A ROLL BAR Mugen 2.2mm
R SHOCK POSN Top 3 from outside
DIFF 30k GS
TOE 2.5
TOP LINK hub Flash Pit hub 2 shims
TOP LINK bulkhead upper hole
WHEELBASE 200mm
BODY Blitz Mazda6
Wing position 3rd hole from back.
BEST LAP/AV LAP
RUN TIME
TRACK TEMP
TRACK RATING smooth/meduim/low grip
COMMENTS
Casterracing ZX1.5R
Old 04-07-2007, 03:58 AM   #5754
shano's Avatar
Default HMMM
Hey guys I found this on a web site and wondering if this is correct.I have been checking my engine temp and it is roughly siting on 117degrees but i feel this my be a bit too hot for my LL3.I have been recommended running it around 110 degrees from other racers at my local track but they run the LS3.Im not saying that they are wrong im just curious and worried cause i dont want to cook my lovely engine.
"The LL3 will have a torquier feel than the LS3. The LS3 powerband comes on smoother than the LL3. THe LS3 is happier at high revs than the LL3. LL3 can be a little trickier to tune and seems to run slightly warmer than the LS3. Overall performance - I would say both are similar, just different power bands. Both are extremely fast."
Old 04-07-2007, 04:03 AM   #5755
shano's Avatar
[QUOTE=razzor]Shano how old is motor ?
motor is only bout 3 months old and only had 2 racedays and bout 4 practise days.I only have noticed the leak after i had burnt all fuel out of engine and put after run oil in it.It had sat there for 24 hours when i noticed a little puddle of after run oil bout the size of a 10cent piece on my new entertainment unit(misses wasnt happy)
Old 04-07-2007, 05:00 AM   #5756
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Originally Posted by razzor
Kodack any idea if those screw kits from Tony's screws will be titanium ?
Guys dont ever use stainless steel screws ,they have bling but break easy.
Besides using titanium screws i dont see the need to change the screws on the G4S as they are good quality.
There not Titanium thou:
Our screws are made of the highest quality black oxide alloy steel (grade 12.9 metric & grade 8 standard). Today's R/C vehicles demand the strongest materials on the market. Stainless steel screws look nice and resist rust, but they just can't withstand the abuse we are putting on them. No one wants a DNF (did not finish) because they broke a cheap screw. Nor do they want to replace their screws every time they take apart their car because the screw heads strip.
https://www.tonysscrews.com/splashPage.hg
I have to say SerpantD got me onto him and apparantly he is making the order or kit as we speak... best thing to do is email him for interest and see if he can hook us up LOCO STYLLES!!!
cheers
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 04-07-2007, 07:28 AM   #5757
SacWolf's Avatar
that's amazing!....here in california we run our motor's in the 220deg range and they scream.....with no problem's ...that includes Novarossi...
SacWolf is offline   Reply With Quote
Old 04-07-2007, 09:53 AM   #5758
spork01's Avatar
Originally Posted by RC-ProSpeed
April 27-29 RC PRO SERIES Northeast Division Race #1 (see rcprosites.com)
Practice Friday, 3 qualifiers Saturday, 1 Qualifier + Mains Sunday
Check the race schedule for upcoming races...
Hope to see some more G4s at this race...currently we are only 5 team magic cars at this track on a mugen world down here.
http://www.cwhits.com/video.html
I think Ill be down there. For that. I gotta see how my work schedule goes.
spork01 is offline   Reply With Quote
Old 04-07-2007, 10:29 AM   #5759
royfan33's Avatar
He's celcius vs. fahrenheit. 117C = approx 240F
royfan33 is offline   Reply With Quote
Old 04-07-2007, 10:46 AM   #5760
royfan33's Avatar
Razzor, thanks for posting your setup. What about the Speed Shot front end?
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
