Old 04-01-2007, 12:28 AM   #5596
MaDaGAS CAR's Avatar
Send a message via MSN to MaDaGAS CAR
not bad paul not bad at all
MaDaGAS CAR is offline   Reply With Quote
Old 04-01-2007, 03:27 AM   #5597
razzor's Avatar
Originally Posted by fenix
but that batts donīt have the plastic thing to attach to the radio plate..
How do you install it ?
I assume that the old battery holder from the exploded pack is damaged then ,if not then you can use it with new pack.
or you could use some silicone to hold it in place as the radio tray also prevents it from moving much.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-01-2007, 03:27 AM   #5598
Z00M's Avatar
Trader Rating: 15 (100%+)
Well, round 4 of the championship at our track was run today. I was a bit pressed for time early, and missed getting my car right for most of the day. Managed to take the TQ in the last round of qualifying (only by a couple of tenths) but in the final, I forgot to reset the ride height among other things so the car was a dog every time it hit a bump and I only managed 5th. So not the best of days for me.
I ran a diff up front for the first time today and it worked reasonably well. I think there is some more to come when I get the setup sorted out for it.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 04-01-2007, 03:35 AM   #5599
Gascar 24's Avatar
hey zoom
im testing with a diff friday
what oils did u run ???
paul
3 Racing f113
Savox, Thunderpower ,Speedpasion,Turnigy,DX3R
www.rcformula.com.au what a site for all your F1 needs
Gascar 24 is offline   Reply With Quote
Old 04-01-2007, 03:42 AM   #5600
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Yes round 4 today. My day started like last round, and didnt think i was going to run at all due to not having a reliable motor. run first heat and seemed the front bearing on the LS3 was leaking fuel badly. so i got a motor off someone and run that for the rest of the day. big thanks to Brent. second heat i missed. and 3rd heat i stripped 2nd gear. whilst trying to replace it, i found my K factory 2 speed shoe holder had fused to the 2 speed shaft. i had to destroy a set of brand new 2 speed shoes and 2nd spur holder to get it off. i then replaced the parts, and tuned the 2 speed and engine during a lunch break. 4th heat was the best i had done for a while doing 18 laps in 5 mins. that got me 4th for the final. the final had its small problems but was fast paced, and finished the day in 3rd and most laps ive done in 10 mins so far. so i had a great ending to the day, and was very pleased. i have to say thanks to Brent for the motor again , and Mark (vc05hdt) for pitting for me in the final
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-01-2007, 04:38 AM   #5601
RC-ProSpeed's Avatar
Default Front Diff
Do you guys recommend the use of the front diff on a smooth open track with high traction, this track is most like for 1/8 scale, and most of the turns are fast, or the front diff works better on small tracks?
any tips would be apreciated.
Thank You
RC-ProSpeed is offline   Reply With Quote
Old 04-01-2007, 05:07 AM   #5602
Z00M's Avatar
Originally Posted by Gascar 24
hey zoom
paul
I ran 50K front and 20K rear.
XRAY XB4
Old 04-01-2007, 05:11 AM   #5603
Gascar 24's Avatar
cheers man im starting with 50k 30k
see how we go
3 Racing f113
Old 04-01-2007, 06:39 AM   #5604
Serpentd's Avatar
I'm off to the track guys, wish me luck. I plan on raging today now that I know the car better. Will post result when I get back tonight! Later guys!
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 04-01-2007, 06:40 AM   #5605
Pattojnr's Avatar
Good Luck man, and have fun .
Serpent - Walter RC
Old 04-01-2007, 07:08 AM   #5606
vc05hdt's Avatar
Were you running a front diff today Paul? Didn't get chance for close look.
vc05hdt is offline   Reply With Quote
Old 04-01-2007, 07:37 AM   #5607
Pattojnr's Avatar
no, ran the oneway. the diff is sitting in my parts box, eager to make its way into the car , thanks for the help today .
Serpent - Walter RC
Old 04-01-2007, 09:09 AM   #5608
lil-bump's Avatar
Trader Rating: 83 (100%+)
Default team magic setup system
Does anyone know the difference between the Tm set-up sytem(pt#116056) and the Hard setup system (Pt# H7101) why the big price difference?
Any info would be appreciated
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-01-2007, 11:28 AM   #5609
razzor's Avatar
Thank You
If the track is a fairly flowing one then the one way or spool should work great.
If track has a technical infield then diff is preferred option with spool a possibility.
On a flowing track my preference is the spool.
Casterracing ZX1.5R
Old 04-01-2007, 11:34 AM   #5610
gansei's Avatar
Default the 2nd kawahara cup in korea.
i participated the 2nd kawahara cup in korea on today
the ground grip is too bad, Because it comes heavy rain in yesterday .. and yellow sand come from china on today.
But i am strong in bad grip, I got TQ position in Heat. ^^
the picture of my G4S sbows that yellow sand was terrible!(after first exercise race)
in A-main Final.. i take a top position until first fuel time.
after first fuel time, my G4S flamed out. --;;
so my ranking fall to 4th.
But i get top postion again after several minute.
in late A-main final, my G4S chassis drags the ground because of too low height setup.
so i had a critical moment. But my pitman help me very fastly.
so i can win the race dangerously.
i changed to 3mm chassis from 4mm chassis to give more roll.
and changed diff oil 1 step more soft.
you can see A-main Final Movie in this site
"http://tvpot.daum.net/clip/ClipViewB...&scrapable=yes"
the third kawahara cup will be held after 2 weeks in korea.
the Kawahara japan driver "Yuruki, Hukuwara" etc on.. about 10 japan racer will participate.
of course, i will race with japan driver. ^^
Team Magic G4-thumbnail0.jpg   Team Magic G4-thumbnail1.jpg   Team Magic G4-thumbnail2.jpg   Team Magic G4-thumbnail3.jpg   Team Magic G4-thumbnail.jpg
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
