Old 03-28-2007, 02:17 AM   #5536
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Hey SeprentD - products arrive from PILOT today - nice one champ!!! ill get the cash to you very soon bud!!!
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 03-28-2007, 02:39 AM   #5537
Originally Posted by GBagRacing
Hey man, thanks for the reply I'll check that one way more thoroughly tomorrow & see. Been racking my brain on this one. The only other thing I can possibly think of is that perhaps I swapped an 18T & 19T in it.(std tranny) That would certainly make it do strange things.
this i too have thought about aswell:
try this:
1. back to basics stripp the transmission
2. check the rear diff
3. check front diff
4. make sure all ya drive pins on ya wheel hubs and pulleys are all in secure
5. check wheel base that is even to the centre line on both sides
6. adjust radio settings to make car drive in straight line "basically a wheel allighnment to drive straight
7. make sure you have same shore of tires in the rear and front, "try new allround
8. if this dont work, then use a hammer just kidding
9. head down to LHS and ask a local experience driver or expert
10. best of luck champ!!
hope this can help some way
Regards
Frankie
Old 03-28-2007, 07:12 AM   #5538
dawgmeat's Avatar
Originally Posted by asw7576
Clutch post = clutch weights ??
If that so, You need to add the weight on the clutch. ( Some says using only 1 weight on the left side works better than using 2 weight altogether ----> no strange engine bogging after 15 minutes of racing ).
For me I follow the manual, using 2 weights / clutch shoe.
thanks
dawgmeat is offline   Reply With Quote
Old 03-28-2007, 07:39 AM   #5539
Default Front Diff
Is there a front Diff for the G4S and if it does what is the part #
jelayne is offline   Reply With Quote
Old 03-28-2007, 10:39 AM   #5540
try this:
3. check front diff
Regards
Frankie
Hey Frankie, Help indeed. Thanks m8! I think it's the rear diff. Standing at the back of the car I held the diff & tried turning the right wheel. It turned & had a proper diff feel to it. Moving to the left side wheel it is solid locked & wont turn unless the diff turns. I'll have to pull it to see what's up but this would certainly explain why the tail end of the car was kicking out while driving in a straight line on throttle. Only thing I can think of is that the gear that attaches to the drive cup is sitting on the pin rather than have the pin in it's proper drive groove. This would mean the Gear is 3-4mm closer to the center of the diff and causing a locked diff effect. I'll keep ya posted.
TM, Murnan, RB, Morgan, Nomadio, GQ, Integy, GP, Duratrax, Protoform, Cruisin, Raceday, Wolf
GBagRacing is offline   Reply With Quote
Old 03-28-2007, 10:49 AM   #5541
razzor's Avatar
From your explanation it sounds like the diff outdrive is locked.
Unscrew the 4 diff screws and take the diff gear of then turn the outdrive to get the bevel gears to seat and reinstall diff gear and screws.
This happens when you assemble the diff ,i usually turn the outdrives after putting screws on with a few thread and then tighten up slowly checking teh outdrives are turning OK.Hope this helps.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-28-2007, 10:49 AM   #5542
I can help ya here m8 as I just ordered these yesterday from Sam @ raceday. You need 502115, 502116, and 502117. This will give you a complete diff with a spare diff case and should cost under $25 US not incl shipping.
Old 03-28-2007, 12:36 PM   #5543
Thank you for the Diff info
Old 03-28-2007, 05:16 PM   #5544
Default Rossi engine ?
Which Rossi model should i get + exhaust. i want good power, smooth power band + easy tuning.
thanks for your suggestions
speed6 is offline   Reply With Quote
Old 03-28-2007, 11:47 PM   #5545
asil's Avatar
Send a message via MSN to asil
Plus 353 special edition.. Box includes plus 353 race engine and a training engine!
Asil
asil is offline   Reply With Quote
Old 03-29-2007, 12:26 AM   #5546
British Menace's Avatar
Muppet Racing............
I was told (WE) were told that, ".......the guys in Europe" are testing TM's new rear sway bar out at the moment?
I assumed they meant you chaps in England.
Darren.....have you had any problems with the small bearings wearing out the two speed housing over there? It's a problem I've heard some are having over here although I haven't had any problems myself.
Good luck with the testing and with Tibshelf this weekend!
One of your favourite tracks to start out with should be a good omen !!
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 03-29-2007, 05:30 AM   #5547
Hi to all on this forum, i am a new member and will love any advice you guys can give. Just bought my first kit G4S. Put it together in two days, i loved how all the parts fit together and the instructions were easy to follow. Race in Trinidad & Tobago in a club called TTRCC (Trinidad & Tobago Radio Control Club). It's a touring car club.
I am the first member in the club to race with the G4S, and man this car moves . My first car was/is a Nitro TC3 fully modified with LRP Spec 2 engine. This car works really good but somehow the power from the engine is not distributed well with the shaft, However with The G4S using the same LRP Spec 2 Engine the belts on this cars distributes the power well and this car handels sweet. Just love it.
Still Trying to find the right set up for our track in Trinidad which is a short track with a lot of turns, medium traction and a bit on the bumpy side.
Anyone with a set-up for this type of track please send to me.
Guys do you think i should use a front diff. instead of the solid axel for this type of track???????
msteeple is offline   Reply With Quote
Old 03-29-2007, 05:37 AM   #5548
vc05hdt's Avatar
Asil
Do you know internet shop who sells this Novarossi package??
vc05hdt is offline   Reply With Quote
Old 03-29-2007, 06:21 AM   #5549
razzor's Avatar
Bud take your time to go through earlier posts on this thread ,there is a wealth of info that will help you.
Also check out the build tips on 3hobby.net and Kodacks blog
links:
http://kodakhodak.blogspot.com/
http://www.3hobby.net/modules.php?na...viewforum&f=20
Casterracing ZX1.5R
Old 03-29-2007, 06:25 AM   #5550
itchy b's Avatar
Hey Msteeple, How did you find the time to Build your G4S and run it with the World Cup going on at home?
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
