Old 03-15-2007, 07:27 AM   #5296
revo523's Avatar
Thanks fellas well i guess i have to get the one for the moongose thanks again for the help kodak i forgot about your blog what a idiot!!!!
revo523 is offline   Reply With Quote
Old 03-15-2007, 07:31 AM   #5297
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Originally Posted by Pattojnr
Guys there is a reason why the tensioner is on the bottom
this is the slack side of the belt, and the tensioner on the bottom allows for less overall tention allowing less friction. hope i explained it right
the mongoose has the tensioner on top on the brake bracket, as it is alot bigger than the G4S one. yes easier to tension and adjust brake screws, but tensioning the wrong side of the belt, plus there is the weight issue, as low as it can go
and i thought i knew what i was talking about, LOL slaps himself silly well done patto, know wonder why i ask you for my super tips!!!
keep it up bro
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 03-15-2007, 09:44 AM   #5298
gansei's Avatar
Default rescue sleeve tool
this is rescue sleeve tool. (not sold product. it was maden by special my order.)
it will revive leaked pressure sleeve.
iya~~~
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 03-15-2007, 09:45 AM   #5299
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Default Shock question
Hey guys
I noticed that my shocks did not rebound the way they did when i replaced the oil in them. The funny thing is that a didnt drive the car at all. The shocks just sat over night and the next morning they didnt rebound the same.
I replaced the black part on top and the nut, and o-ring. Still didnt help. I then replaced the bottom part. blue o-ring, nylon washer and clip and still the same.
I guess my question is, is this normal? Should they rebound the way they did when i first put the oil in them?
Any suggestions when it comes to building shocks?
thanks
nitrobeast is offline   Reply With Quote
Old 03-15-2007, 09:51 AM   #5300
gansei's Avatar
Originally Posted by nitrobeast
Hey guys
thanks
if shock shaft is rough by scratch or bended in detailed,
it will not rebound well.
then change shock shaft to new one.
and i used teflon oil in O-ring and shock shaft.
it will make shock very smooth and rebound good
MY SPONSORS:
Old 03-15-2007, 10:04 AM   #5301
Serpentd's Avatar
iya~~~
Yo Gansei master! Dude, I am surprized to see you with that. Very sweet dude. I have a few myself. I got one for every engine I own. If you ever need detailed instructions on that, let me know. But I'm sure you know what's up since you have the thing. Later bro!
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 03-15-2007, 10:12 AM   #5302
asil's Avatar
Send a message via MSN to asil
guys you rock!! this is the first time that I see that kind of tool.. does it work? what's your opinion?
Asil
asil is offline   Reply With Quote
Old 03-15-2007, 10:29 AM   #5303
nitrobeast's Avatar
I understand about the bent shaft but that doesnt make sense in my case. If that was the case it wouldnt rebound good when i first assemble them. Would it?
Old 03-15-2007, 10:33 AM   #5304
Serpentd's Avatar
Hey guys
thanks
A few things bro. Follow what Gansei said for starter. Also, remove the "o" ring, It does nothing. Your shock seals at the bladder, not the O ring. I don't even know why they put it on there honestly. Also, let you shocks sit longer when you bleed them. Also bleed them like 2 or 3 times to make sure ALL air is out. I included a picture of an air bleeder I use, and I still need to bleed them like 3 times to get out all air. Also, I included a pic of this stuff called "Green Slime". If you put this or something equivalent on your shock shaft, then it will give it a better seal. Just like Gansei mentioned. Also, if you haven't already done so, replace the original bladders with the stiffer Blue ones. They won't colapse on you as the "Orange" ones do. Your rebound is probably changing due to air if they only sat over night. Good luck and be patient.
Team Magic G4-shock-stuff-002.jpg   Team Magic G4-shock-stuff-003.jpg   Team Magic G4-shocks-003.jpg   Team Magic G4-shocks-006.jpg
Blessed are the SIC
Old 03-15-2007, 10:40 AM   #5305
nitrobeast's Avatar
4got to mention i also changed the bladders. When you compress your shocks should you hear any air sound? I do..maybe i am just not bleeding them correct. Where can i get some green slime?
Old 03-15-2007, 10:47 AM   #5306
Serpentd's Avatar
Asil
Yes! They absolutely work. It will bring new life into a tired motor in about 5 minutes. You just need to make sure that your engine isn't in "Bad" shape throughout. Because a new squeeze can't help a damaged engine. Only a worn out Piston and sleeve. You also need to be careful to not OVER squeeze as this will put undo stress on the rod. But overall, yes these obtain great results when done properly. You want to make sure you break in the engine again as well.
Blessed are the SIC
Old 03-15-2007, 10:49 AM   #5307
gansei's Avatar
=> no.. never.. shock air remover will help to remove air in shock oil.
shock slime purchase site.
http://rc-mushroom.com/product_info....oducts_id=4432
http://rc-mushroom.com/product_info....oducts_id=9891
MY SPONSORS:
Old 03-15-2007, 10:52 AM   #5308
Serpentd's Avatar
Dude, if you hear air, that is a big no no. You might not be putting in enough oil, or your not bleeding them well. I assume your bleeding them as the manual instructs? The green slime is an Associated product. You should be able to find at LHS. The part number is #1105. You might need to have them order it, or you can find it online somewhere like Tower Hobbies or such. It's only at the most like 5 bucks and will last a looooong time. Hope this helps. Let us know.
Blessed are the SIC
Old 03-15-2007, 10:54 AM   #5309
Serpentd's Avatar
Thanks Gansei. We must be typing at the same time.
Blessed are the SIC
Old 03-15-2007, 11:20 AM   #5310
nitrobeast's Avatar
I think im putting in enough oil but not bleeding them well. Yes i am following the manual.
Can you take a pic of your oil level? I just want 2 make sure i am doing it correct.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
