Old 03-13-2007, 02:11 AM   #5236
Serpentd's Avatar
Originally Posted by EagleOne2006
I know what you mean about long winters, They kill me too.
So I do electric racing too. "Indoors". what a thrill, but Nitro is my prefered
type of racing.
Yeah dude, at least you can get your fix in and keep your skills up with indoor electric. It can be a very intense 5 minutes of racing, that's for sure.
Too much winter this year for sure. It just sucks for us 4 season climate people.
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 03-13-2007, 04:28 AM   #5237
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Serpentd
Dude, I feel your pain bro! It's been finally getting nice here in Colorado. About mid 50's today. A heat wave.
As far as that track, if it's left untreated then I will agree with Frankie. However if it's treated, then it will be HIGH grip without a doubt. 42's all the way around. Are you racing there this year?
Heat wave? hehe, i am also getting one. Going into the 60's today and then back into the 40's. Oh well at least its closer to warmer days then December was.
Yeah thats the track i'll be racing on this year. Cant wait.
nitrobeast is offline   Reply With Quote
Old 03-13-2007, 04:32 AM   #5238
nitrobeast's Avatar
type of racing.
Lol, i tried 1/18 carpet racing this year in the winter but just couldnt get with it. Something about hearing a engine at 30000+ rpms get me going.lololol
Old 03-13-2007, 06:54 AM   #5239
gansei's Avatar
Default shock reboud test movie
shock rebound test movie..
huhahahahaha iya~~
http://tvpot.daum.net/clip/ClipViewB...&scrapable=yes
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 03-13-2007, 07:01 AM   #5240
Serpentd's Avatar
huhahahahaha iya~~
Dude, Love your vids BRO!!! I had to replay it about 10 times in a loop to get my full dance thing going though. Keep them coming Bro. IYA! Late!
Blessed are the SIC
Old 03-13-2007, 07:27 AM   #5241
revo523's Avatar
It makes sense but its just crazy too me that it does it with too different motors. It makes me think that its some think on the car making the rev to stay high after letting the throttle off. but i'm going to give it a try thanks dude and let me know about the airbrush i order a mazda 6 body and i want to try this airbrush thing....
Dude, as far as your engine, it sounds like it might be running rich on the bottom. You might be having too much fuel trying to burn off at idle and this is why it's reving high. You want to actually keep it reving high and lower your idle. Give that a try. Lean it out a little at a time (low end). After the revs stays high then lower your idle. Make sence?
As far as the cheap airbrush, I did notice that Wal Mart has changed companies for there pinting stuff. I think it's all House of Color stuff now. Which is awesome stuff, but what you want to look for is the Aztec single action airbrush. I posted a picture right above your post there with the red bodies. That's what it looks like. That is like a $25 dollar air brush that works Killer! I'll look around for the one I am talking about. Later bro
revo523 is offline   Reply With Quote
Old 03-13-2007, 08:05 AM   #5242
nitrobeast's Avatar
I too had the same problem. What plug are u using temp wise? Try something cooler. Also play with the fuel pressure line. Make it longer and try it then smaller and try it. Give it a shot and lmk how it goes.
Old 03-13-2007, 08:07 AM   #5243
nitrobeast's Avatar
huhahahahaha iya~~
Is that as far in that your shocks go? Bottom out?
Old 03-13-2007, 08:35 AM   #5244
razzor's Avatar
No problem dude! what airbrush are you talking about? Do you have a picture or something? i went to walmart today and all i saw was the one that comes with the air compressor. I have a question when i hold the throttle and my second gear kicks in and i let off the throttle my idle stays high like if my low end needle is too lean but i know its not that because i already try to richen it but with no effect. i even changed motors and it still does the same thing is this normal or do i have a problem?
Ive had this before and it could be one of two things that come to mind.
1 like Serpentd said it might be too rich on the bottom.If it was lean you would get a erratic high idle if its rich it will be a long steady high idle.
Try leaning out teh bottom a 1/4 turn and richen up the top a bit too
if the idle stays high then turn down the idle screw ,the carb might be open a tad too much.
what % nitro are you using and what plug ?
2 maybe the clutch is not backing off when it returns to idle ,check shoes etc.. although i doubt this.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-13-2007, 08:37 AM   #5245
razzor's Avatar
gansei that exactly how i check mine.
oh and love the music.
Casterracing ZX1.5R
Old 03-13-2007, 09:20 AM   #5246
Serpentd's Avatar
I hear ya bro with both engines. It might be they are both out of tune the same. Do one at a time. Also, make sure that your fuel tank cap is pushed all the way down and sealed. Don't want any air leaks. Also as Nitrobeast said, your fuel pressure line that goes to your exhaust, I always run it 12 inches long. I sort of coil it around a bit and zip tie it or use those fuel tubing holders. I know 12" sounds long, but trust me. A least give that a try, you can always go back to shorter. I wouldn't go less then 9" though. This helps to keep a consistant fuel pressure. Especially when you are letting off the throttle. Just try one thing at a time, though if your pressure line is kind of short, do this no matter what. Keep us posted, and don't forget to double check your tank lid for a good seal.
Dude, I will keep you posted on the airbrush. I know right off that if you have a Hobby Town in your area, give them a call and ask if they carry the Aztec series air brushes. They should and ask them how much for the cheapest one. I want to say it's like $25 bucks or so. This like I said is all the airbrush you need. But regardless, I'll follow up with you bro! Good luck on engines! Later!
Blessed are the SIC
Old 03-13-2007, 09:24 AM   #5247
rcrevolution's Avatar
Send a message via AIM to rcrevolution
goldish?
I thought CF was silver and black
rcrevolution is offline   Reply With Quote
Old 03-13-2007, 09:28 AM   #5248
Serpentd's Avatar
Originally Posted by rcrevolution
goldish?
On your radio tray or transponder holder....Look closer.
Blessed are the SIC
Old 03-13-2007, 10:40 AM   #5249
razzor's Avatar
Some CF has Kevlar is it that gives a bit of a yellow/gold tinge in teh black/graphite of the weave.
Im actually a big fan of kevlar just love the look of it.
Casterracing ZX1.5R
Old 03-13-2007, 11:02 AM   #5250
im gonna do my mazda 6 body all orange with white and blue flames on the side and a Cf hood and spoiler.
what do you thing?
also the Walmart airbrushes, they are single action, arent dual action brushes better? cause they let you control how much comes through?
and when you buy paint for airbrushes what do u mix them with? as you can see I have never used an airbrush and I wanan try it but dont wanna mess up compltely.
and buying 5 cans of paint to get this car looking perfect is gonna be expensive.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
