Old 03-07-2007, 11:45 PM   #5056
British Menace's Avatar
Hey Paul,
The outdives from the one way wont fit. You nead to get the same as goes in the rear diff' ass'.
Better to get the lightened ones,
K14125
Or the stronger then stock, K14101
Either are a great upgrade.
Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 03-08-2007, 12:20 AM   #5057
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
hmm, i was wondering wat would happen if i dun replace the drive cup for now, would it cause damage to my universal shaft? ha, i have that 14125, think better get it changed, else later end up having to replace my universal (coz i just changed it).
uniquexme is offline   Reply With Quote
Old 03-08-2007, 12:30 AM   #5058
Coooooool.....
Old 03-08-2007, 12:54 AM   #5059
gansei's Avatar
Default ED pinion wear out pic
16,17,20,21T pinion pic.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 03-08-2007, 01:02 AM   #5060
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Thanks Gansei, i see the picture interesting Gallons? need to work out the conversion to Litres here in Australia!!!
Chenge of subject, is there a certain spot that you cut the hole in the front wind sheild of you bodyshell?
example:
To the side?
Dead Centre?
Half the Front ?
not sure as i am ready to cut but would like a good opinion on the balance of the car if cut wrong?
plus what diameter is best?
Regards
Frankie
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 03-08-2007, 01:15 AM   #5061
gansei's Avatar
example:
To the side?
Dead Centre?
Half the Front ?
Regards
Frankie
the diameter is about 50mm~60mm..
if the race tournament of rule is strict, i used 50mm
But others, i used 60mm for protection against heat.
attached pic is 60mm diameter.
and i always remove back window all for protection against heat. ^^
MY SPONSORS:
Old 03-08-2007, 01:45 AM   #5062
Wayne1one's Avatar
Originally Posted by Wayne1one
what color springs should I start out with for a track with medium-high bite. Also what weight shock oil?
any takers?
Wayne1one is offline   Reply With Quote
Old 03-08-2007, 01:46 AM   #5063
Z-Mann's Avatar
do the original pionions work with the ed transmission???
Z-Mann is offline   Reply With Quote
Old 03-08-2007, 01:57 AM   #5064
razzor's Avatar
any takers?
Id suggest starting with one of Darren Johnsons setups.
It will get you close and then you can play around the setup to get comfortable.Setup sheets are on TM website and 3hobby.net
Kodak maybe an idea to collect and place setup sheets on your blog ,one stop G4s resource
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-08-2007, 02:00 AM   #5065
razzor's Avatar
They would work but gearing would be a lot taller/longer.
Casterracing ZX1.5R
Old 03-08-2007, 02:12 AM   #5066
Pattojnr's Avatar
Trader Rating: 19 (100%+)
another ED pinion problem.
on sunday i had a good setup, happy with the gearing.
but while i had a chance,m i thaught i would get a start on some testing for the next sunday on a tighter track. so i put on my 15t pinion, one i had problems with before, as i stated. so i meshed same as i normally do, and on the out lap, the spur stripped. the heat started and i was changing my 1st spur to try once more. not even half a lap, again on the out lap, stripped 1st gear. so i look at the way the gears are cut, and definately more harsher cut and like a hack saw blade. now this is 4 spurs i have stripped with this pinion. so i will not use it and am tempted to throw it in the bin. i know some of you guys have used the 15t pinion, but seriously i havent been able to test the life of the pinion due to the short life of the spurs. maybe i have a faulty cut ? but not happy !
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-08-2007, 02:24 AM   #5067
Gascar 24's Avatar
Trader Rating: 15 (100%+)
Originally Posted by asil
hey paul, I'm thinking of putting alu. rings on drive cups to make them stronger.. I'll talk to my lathe shop if they can do it.. will post pictures if I can produce them..
Asil
cheers asil cant wait for pics
ill have to send u mine lol
3 Racing f113
Savox, Thunderpower ,Speedpasion,Turnigy,DX3R
www.rcformula.com.au what a site for all your F1 needs
Gascar 24 is offline   Reply With Quote
Old 03-08-2007, 02:47 AM   #5068
razzor's Avatar
I have been running the 15t ED pinion from day one with a 52t spur and have not had any hassles.In fact I stripped my first spur gear last weekend when I forgot to tighten my motor screws.
Have to aggree wear on the pinions is a issue but at least I am getting 4/5 meetings out of them.My std 19t pinion used to wear out faster believe it or not.
As Gansei has pics to show ,from that i can say that the wear is exagerated on the smaller pinions for both 1st and 2nd gear .
Casterracing ZX1.5R
Old 03-08-2007, 02:53 AM   #5069
Pattojnr's Avatar
i think you gave the same reply last time
i dont know what im doing wrong ?
Serpent - Walter RC
Old 03-08-2007, 03:15 AM   #5070
razzor's Avatar
Patto theres got to be a reason !
Maybe the batch that your spurs came from had a issue.
Or maybe there is play on the 2 speed and clutch bell.
Or maybe you need to mesh tighter.
could be anything.
ill have a look at my car and see if I can think of anything .
Thats what we here for
Casterracing ZX1.5R
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
