Old 03-07-2007, 07:43 AM   #5026
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Originally Posted by asil
what's going on here ?????
Asil, i think someones having a laugh being me,
anywasy i think its sorted via PM, sorry to dissupt the forum
Back on topics of G4
"Tips on the Bulk Head" EXPOXY GLUE what part is best to tape up?
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 03-07-2007, 10:02 AM   #5027
rcrevolution's Avatar
Send a message via AIM to rcrevolution
Well guys and girls, today at aprox. 11:30am I became the proud daddy of a new G4S!!!!!
I am now one of you drawn to the dark side
http://img337.imageshack.us/my.php?i...ture005oj7.jpg
http://img140.imageshack.us/my.php?i...ture007ef4.jpg
http://img140.imageshack.us/my.php?i...ture012qw2.jpg
http://img337.imageshack.us/my.php?i...ture014xo3.jpg
http://img48.imageshack.us/my.php?im...ture017kd7.jpg
rcrevolution is offline   Reply With Quote
Old 03-07-2007, 11:13 AM   #5028
Rawz's Avatar
guys, I'm on just edge of an important decision willing to buy crf 2007 engine.. did you use crf on G4S? ZOOM or AFM.. I'm not sure but I think you use this engine.. Can I use ufo clutch with this engine or I have to buy crf v6 clutch set or upgrade set.. Any ideas??
Asil
Hello. I think it's Zoom that uses the engine. I just got one, but could not test yet, I lost the clutch nut while doing the exchange ... (Don't ask how, I don't know also!!!! *@#[email protected]#* ...)
Well, you should go to the Orion CRF threat here in RCTEch, we talked a lot about the G4S there too.
Rawz is offline   Reply With Quote
Old 03-07-2007, 02:28 PM   #5029
asil's Avatar
Send a message via MSN to asil
rcevolution, welcome to the magic world rawz, thank you for your advice..
Asil
asil is offline   Reply With Quote
Old 03-07-2007, 04:03 PM   #5030
Originally Posted by rcrevolution
Welcome in open arms, lay questions here and we all best to help you out!
Have fun building an awesome kit, any ideas on motor exhaust combo?
Old 03-07-2007, 04:06 PM   #5031
royfan33's Avatar
Welcome! What is it about the G4S that makes grown men, me included, so exciteable?
royfan33 is offline   Reply With Quote
Old 03-07-2007, 04:32 PM   #5032
omg i got ripped off, my kit is missing foams .....
lol
thanks I sorta was part of the community since I had a Mongoose, but now I have a new car.
umm what foams are good? I was looking at the kfactory tires since raceday has them for fairly cheap, are they any good?
also as for the engine and pipe, its prob gonna be a JLR "Red-Dot" and Skyline VR12 Plus pipe.
and the body I don't know I really like the madza 6 but already have one, and the stratus which is prob the best looking body I don't really like, but i might end up going with the Stratus.
I have 2 questions, does the G4S have the little hole on the clutch bell for tuning without removing the clutch bell? and do the pivot balls have the little nylon washers for smother operation?
Old 03-07-2007, 05:19 PM   #5033
Originally Posted by gansei
checkpoint.
1. is sus arm activity smooth? (in removing shock)
-> this is my sus relation lecture movie.
http://flvs.daum.net/flvPlayer.swf?vid=1VLjZWBODcw$
But it maden by korean language. you couln't understand.
But just see sus arm activity.
2. shock length of left and right is same?
(also check rear shock length.. this will affect front shock)
Thank you for an interesting viewing, fully understand the principal of the suspension in free easy flow movement!!!
Thank you once again
Old 03-07-2007, 06:35 PM   #5034
revo523's Avatar
this is the clutch that i have, which part do i need to change to make my clutch work properly.
revo523 is offline   Reply With Quote
Old 03-07-2007, 06:36 PM   #5035
afm
afm's Avatar
lol
K factory foams are good.
JLR "red Dot" with skyline pipe is a killer combo. I have it in my G4S and it is faster than my OS TZ modified like an Os Speed....you can't go wrong with it....now if you wan't an extra edge you can get at Raceday the IDM Picco Modified with IDM pipe...it's like the "red dot" but more modded...can't go wrong with it either.
Best body for the G4S is the Stratus 3.1...it is the most balanced..the Mazda 6 can have to much steering in certain conditions.
No, the std. UFO clutch bell has no hole for regulation. The one that comes with the ED does.
Yes pivot balls come with nylon inserts. Didn't you assemble the car allready?? You must've seen them.
AFM
afm is offline   Reply With Quote
Old 03-07-2007, 07:24 PM   #5036
my car is sitting in the box until i get the tools i also ordered to build it.
question though how much does the ED tranny go for, and what does it improve noticably?
Old 03-07-2007, 07:32 PM   #5037
afm
afm's Avatar
The theory behind the ED Transmission System is to slow the speed of the transmission components and main shaft down. If you use the stock system, the Final Drive Ratio is 2.526. If you use the ED System, the Final Drive Ratio is 2.190, and because we are slowing the main shaft and all of the transmission components down, we have to gear the engine lower.
The transmission is the heaviest rotating part of the car and it takes the most power to spin it up and down between gears, and so it eats power (Inertia is the enemy). If we don't spin it up as high between gears, itís all free power that is not wasted spinning up excess rotating inertia.
The difference between 2.526 and 2.190 FDR is several thousand less rpm on the main shaft between each acceleration and deceleration of the transmission. Top end improves, but sharpness also improves out of corners.
Also the clutch bell & pinions are very light & very small (Standard kit pinions & bell weight about 13g, the new ED weight only 6g).
Raceday has them for $125.00
AFM
Old 03-07-2007, 07:36 PM   #5038
anyone know what the price for the IDM / IDM pipe from raceday's is? all they have is a $ there
Old 03-07-2007, 07:46 PM   #5039
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
but 1 thing bad about ED is that its pinion is so easily damaged, compared to stock. i guess maybe its teeth is lesser, thereby easily to strip. i ran for 2 weeks, and the 1st pinion is almost gone. so now, i dun use the ED, cause the 2nd pinion is expensive.
i found that non ED system is much more powerful. m using 18/52, 23/47, with 18T brake pulley, 18T rear side belt pulley & 27T front side belt pulley.
1st speed ratio : 7.7037, 2nd speed ratio : 5.4492, 1st/2nd : 1.4137, ODR : 1.0
uniquexme is offline   Reply With Quote
Old 03-07-2007, 07:54 PM   #5040
royfan33's Avatar
If I remeber right, the engine alone is $350 or so. I may be off though its been a month or so.
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
