Team Magic G4
Old 03-06-2007, 05:47 AM
  #4966
Kodak Hodak's Avatar
Originally Posted by Serpentd
Dude, thank you for pics. Is your car all happy again and ready to run with your new mods?? Looks ready for Saturday my friend.
man dude killa what a night - gee i thought i had a headache and a half, but bro its sorted now i think, still gotta get a setup on the car, just had to work at this prob man!!!
slowly but surley prac day saturday will be interesting!! and then Sunday Race!!
Kodak Hodak is offline
Old 03-06-2007, 05:59 AM
  #4967
Serpentd's Avatar
Dude, all these little issuse that we face are fixed easier with experience. Nothing more. The more you learn your car, you will be able to pin point a problem without even looking at the car. You will eventually know what is wrong by feeling it on the track. However we always run into a wierd situation as you just faced. This in the long run helps you to learn your car very well though. And this in return will help you out at the track when facing wierd problems. Your just getting experience here is all. We all have to go through what you are now facing. You got it fixed and all ready to rumble my friend. You did a great job! Good work my friend!
Serpentd is offline
Old 03-06-2007, 06:16 AM
  #4968
question guys, since this is a 4mm chasis, can i not use the front sway bar?
Old 03-06-2007, 06:34 AM
  #4969
gansei's Avatar
Dude, that is sweet bro. I have been trying to find some sort of reamer like that myself. Is that a regular drill bit or is it a special bit for reaming? Where can I find that reamer you have? Thanks bro. By the way, sweet vid!!! Later.
kyosho (KYYKW001) STRAIGHT REAMER(3.05)
Attached Thumbnails Team Magic G4-sany0001.jpg   Team Magic G4-sany0002.jpg   Team Magic G4-sany0003.jpg   Team Magic G4-sany0005.jpg
gansei is offline
Old 03-06-2007, 06:35 AM
  #4970
Originally Posted by gansei
no.. you can use front sway bar in 4mm chasis..
i am using it now..
guys with the sway bar in, i still get the front right wheel lifting again - i have totally backed off the sway bar, but still it gives me grief!!!
soon as i take the sway bar off its all good again!!!
anyone have this problem?
Old 03-06-2007, 06:36 AM
  #4971
gansei's Avatar
i am using it now..
gansei is offline
Old 03-06-2007, 06:44 AM
  #4972
Also Gansei can you please post pics of your front end, and if possible can you see if your front right wheel as you press the left rear suspension down that the front right wheel does not lift off the ground!!!
i am stumped why its doing, i even changed the postiion of the shock tower hole form B4 bottom hole, now at the 2nd from bottom hole!
tried a softer spring and still that dread wheel lifts when the sway bars in the front is installed!!
i should take a video of it to showcase it or pictures mmh - me scatches head
its late, i need sleep and will attack tomorrow
if you any guys out there got ideas then pics, info is a pot of gold!!! cheers
Old 03-06-2007, 06:47 AM
  #4973
Wayne1one's Avatar
did you say you put mugen upper front arms, that might be your problem
install the old arms and see if thats the problem.
Wayne1one is offline
Old 03-06-2007, 07:07 AM
  #4974
Serpentd's Avatar
Dude, thank you VERY much my friend. I really appreciate your reply my friend. Thaks!!
Serpentd is offline
Old 03-06-2007, 07:10 AM
  #4975
asil's Avatar
guys.. OS Speed Tuned Spec II.. I can't catch the development speed of new engines you may see magazine ad here;
http://www.rctech.net/forum/showthre...75#post3091775
Later..
asil is offline
Old 03-06-2007, 07:13 AM
  #4976
Serpentd's Avatar
Dude, I think all he installed was the Mugen ball ends on the end of the shocks and steering turnbuckles I think. All the places that the regular TM ball cups are located. I don't think that he put on Mugen arms. This would just be a big no no IMO. I might be wrong, but not too sure what is up with his car. I do think he needs to take that Mugen crap off for starters and try the original equipment. This would be a good starting point.
Serpentd is offline
Old 03-06-2007, 07:33 AM
  #4977
gansei's Avatar
my pic..
gansei is offline
Old 03-06-2007, 07:36 AM
  #4978
asil's Avatar
gansei, your front center body post is a good mod..
Asil
asil is offline
Old 03-06-2007, 07:56 AM
  #4979
revo523's Avatar
kodak hodak i had a similar problem and all i did was run the car and it went alway try that and see if it helps..good luck!
revo523 is offline
Old 03-06-2007, 08:17 AM
  #4980
dnitro's Avatar
Kodak,
I had a similar problem but with the old chasis. I ultimately found the problem to be the sway bars. They may have gotten misaligned during a crash. I put in a new set and the problem went away.
Are the hinge pins still straight?
dnitro is offline
