Team Magic G4
Old 03-06-2007, 04:44 AM
  #4951
Serpentd's Avatar
Originally Posted by vc05hdt
Did you use an airbrush Mike? I am going to invest in one soon as some work out there is mindblowing. More practice and points for trying
Looks like a single action airbrush job to me. Even a 25 dollar aztec or something in the model department at Wal Mart or such will work great. You don't need a high dollar airbrush at all. Yes he had to use an air brush for the fade around his design. Good job by the way ZOOM. Choosing the right colors can be as difficult or confusing as doing the actual design. I know I have come up with some strange combos. It's all about trial and error. Anyway, I suggest to just get a cheapo airbrush vc05hdt. I have cheap to high dollar, and they can all perform the same for the type of painting we do. Good luck.
Serpentd is offline
  #4952
British Menace's Avatar
Originally Posted by Kodak Hodak
Hey Guys H E L P is required please,
Ok i have installed the new 4mm chasis,
New Speed Shot Front end,
New Carbo Bumper Support
New ED Trans
Also New Mugen steering cup ends and shock ends, pivot ball type,
Problem is this:
I had lossen both the sway bars right off rear and front, now when i push down on the left rear corner the front right lifts off the ground
took the front shocks off and something feels like its rubbing, but cant work it out, the only problem i think it might be is the new Mugen End Bits
WHAT else could it be?
cheers guys
Yes it could be them Frankie..............
Try taking one Mugen 'end bit' off at a time and see if you still have the problem.
I had a problem with the sway bar monts which caused a similar problem. It's not them is it? Although you've already ran the car somewhat so I'd be surprised if that was it.
Let us know when you find it.
Hope this helps mate.
Menace
British Menace is offline
Old 03-06-2007, 04:50 AM
  #4953
Serpentd's Avatar
New ED Trans
Problem is this:
cheers guys
I agree with Menace, take off one ball end at a time or check the free movement of one ball end at a time until you find the "bind". It's there somewhere. Just take your time and diagnose carefully. You'll find it bro. I can tell you that it's not any of your other upgrades. Make sure everything is pivoting smoothly. Good luck bro! Later.
Serpentd is offline
Old 03-06-2007, 05:07 AM
  #4954
razzor's Avatar
Kodak double check hinge pins as well ,had this happen to me a while back turned out hinge pin was bent slightly and binding the a-arm.
razzor is offline
Old 03-06-2007, 05:08 AM
  #4955
Kodak Hodak's Avatar
its the mugen parts, and more guys just got the front right arm off and stuff is binding
arrrrhhh the joys of new parts
Kodak Hodak is offline
Old 03-06-2007, 05:11 AM
  #4956
Gansei Master if you are out there, can ya tell me any issues that you might have had with 4mm chasis - like stiffness and wheels liffing of on one corner of the car when you push the rear left down, the right wheel lifts off ground!!
All shocks are equal lengths
and have checked with shocks out and it still does it
Old 03-06-2007, 05:19 AM
  #4957
Wayne1one's Avatar
This is very common and happened to me before (aka tweak), also check droop screws.
Wayne1one is offline
Old 03-06-2007, 05:22 AM
  #4958
Serpentd's Avatar
Dude, double check your droop setting and stuff after you get rid of binding. The chassis has nothing to do with you situation bro. Make sure you do a complete new alignment after you get you binding worked out. Relax and breathe dude, and don't forget to BLINK! Good luck my friend!
Serpentd is offline
Old 03-06-2007, 05:23 AM
  #4959
Serpentd's Avatar
You are dead on my friend! Listen here Frankie!!!
Serpentd is offline
Old 03-06-2007, 05:24 AM
  #4960
fixed it guys, ill show the pic of the part that we all must look out for!!!
Old 03-06-2007, 05:31 AM
  #4961
razzor's Avatar
if you place the chassis on a flat surface is it flush to surface ?
Try loosening all the screws and retighten them.
razzor is offline
Old 03-06-2007, 05:38 AM
  #4962
Serpentd's Avatar
Dude, where is your pic?? I know it NEVER takes youthis long to post a pic bro. I'm curious to your issue we have all been helping you on.
Serpentd is offline
Old 03-06-2007, 05:40 AM
  #4963
ok guys, after many hours trying to ork it out here and yes thanks again for support, i had to change the front right arm, must have had a knockty knock in my final race, when the exhaust got BIFFED
anyways, i took photos, plus did some drawing to shocase what made the car feel tweaked as hell!!!
Now she does what it supose to do that not lift the wheel off the ground when the rear corner is pushed!!
enjoy guys
Attached Thumbnails Team Magic G4-kfactory-040.jpg   Team Magic G4-kfactory-042.jpg   Team Magic G4-kfactory-044.jpg   Team Magic G4-kfactory-046.jpg   Team Magic G4-kfactory-047.jpg
Old 03-06-2007, 05:42 AM
  #4964
anoteher pic of the new look, oi patto PINK fule lines well very very neon Orange Pink
Old 03-06-2007, 05:46 AM
  #4965
Serpentd's Avatar
enjoy guys
Dude, thank you for pics. Is your car all happy again and ready to run with your new mods?? Looks ready for Saturday my friend.
Serpentd is offline
