Old 02-26-2007, 05:56 AM   #4531
razzor's Avatar
Originally Posted by shano
hey guys pulled my car apart after sundays race events and all cool no broken bits except in my rear shock the diaphram was sitting in the shocker and didnt look too healthy.Now questions
1.How can i stop this happening again?
2.Can i use another one of another car as long as its the same size or will i get different performance out of it?
But besides that all good
all i can say is BRING ON NEXT MEET
Shano get the Kfactory Blue shock bladders this will sort out your problem.
Also superglue the plastic cap to the threaded ally cap.
I havent tried drilling a hole in the ally cap but that is another tip the guys have given.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-26-2007, 06:10 AM   #4532
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Originally Posted by Kodak Hodak
hang ON everyone - whoa go back to what i said i had Rust on my hinge pins this was buggin me, some how its in the front and rear!!!
So this is why i have polished this - - - - has anyone had this drama and what can w all do to prevent?
cheers for the comments keep them coming
this was a bit rude, sorry if if sounded wrong!!!
silly me just stressing over rust
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 02-26-2007, 06:30 AM   #4533
razzor's Avatar
Dont stress Kodak but polish them with a good metal polish and they will be sorted
Casterracing ZX1.5R
Old 02-26-2007, 06:33 AM   #4534
razzor's Avatar
Gansei that is unusual wear for the clutch shoe make sure the clutch is not slipping too much as thats the only thing that can make the shoe wear so much.
Casterracing ZX1.5R
Old 02-26-2007, 07:58 AM   #4535
gansei's Avatar
the circuit of my practice run is very high grip.
ground resistance is very high.. engine was very toilsome.
so my the clutch setting must be some hard.
so.. G4S black shoe wear out very soon.
i tested serpent yellow shoe just now in holding car up in the air (no burden)
meet feel is very good.. and 2-speed timing is faster than black shoe.
the attached picture is Dario(Euro Champ)'s G4S.
pls take a detail look at the clutch.
shoe color is yellow.
i quess that Dario already had used serpernt yellow shoe!!
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 02-26-2007, 08:07 AM   #4536
afm
afm's Avatar
Dario used the K Factory red shoe and flyweights.
Have you tried them???
AFM
afm is offline   Reply With Quote
Old 02-26-2007, 08:18 AM   #4537
gansei's Avatar
AFM
i used red shoe..
but meet feel is not good. maybe much slip.
and red shoe gnaw on clutch bell inside.
the Dario picture's shoe color is not red but yellow.
But the setup sheet of Dario was described by using black shoe.
the falsehood setup sheet? --;;
MY SPONSORS:
Old 02-26-2007, 08:21 AM   #4538
dnitro's Avatar
After 3 heats, I was glad to qualify 5th in the A-main amateur at our local club race, out of 14 MTX4 and RRR. The car seems to get faster and faster after everyheat. I finished all 3 heats without any mishap.
In the main, I had completed two laps, and all of a sudden, my steering started to bind, without me hitting anything, and no one hit me. It wouldn't turn left of right. I thought it was the steering servo (Fut 9550) so I disconnected the link to it and found it was working fine. Upon further inspection, it was the steering rack/servo saver that was binding with the top brace. What I don't understand it how it start to bind if it is suppose to connect to the top brace. If the top brace is out, the steering is free, once I put it back on, the binding comes back. I didn't have time to fix it because the main was only 15 minutes.
I will rebuild the servo saver and see what happens. I'll let you know my findings.
Anyone else have the same experience?
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 02-26-2007, 08:47 AM   #4539
asil's Avatar
Send a message via MSN to asil
dnitro, I did not experience it but it may be due to bend chassis?? I hope it's not the case
asil is offline   Reply With Quote
Old 02-26-2007, 09:07 AM   #4540
dnitro's Avatar
I checked out the chasis but it was perfectly flat.
TM G4S
IDM Evo3
Old 02-26-2007, 11:57 AM   #4541
razzor's Avatar
Gansei ,looks like you had the answer all along
Guess I will have to strip my serpent to give it a try at the next national seeing its a very high bite surface.
Thanks for that info
Casterracing ZX1.5R
Old 02-26-2007, 12:19 PM   #4542
razzor's Avatar
Thats a unusual problem the only thing that comes to mind is chassis is bent or check servo saver is not loose.
Try shimming with a 3mm clutch shim.
Casterracing ZX1.5R
Old 02-26-2007, 12:42 PM   #4543
Serpentd's Avatar
i used red shoe..
I'm not familliar with the TM black shoe, but I can tell you that the Serpent yellow shoe has always seemed to be the clutch shoe of choice. I am guessing that the yellow hardness is in between the TM black and red. I have ran the yellow material in both 10th and 1:8th scale with great success on all track types. It is meant to slip a little, but I have never seen one of mine wear prematurely.
Gansie, thanks for bringing this up, I think you have pointed out something important here. I am very certain that you will solve your problem with this shoe. Good luck bro and keep us posted with your results.
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 02-26-2007, 12:52 PM   #4544
Serpentd's Avatar
findings.
Dude, that is a trip! I would imagine that just your servo saver became loose or something. Does yours have the bearings in the top and bottom of the servo saver? I think that after you rebuild that servo saver you will be fine. I haven't messed with this enough to get a mental picture of the servo saver and all. Dude, by all means keep us posted on your findings. We are all curious to why and how this could happen. Especially because of it just popping it's ugly head up in the middle of no where. Good luck bro, if you need a hand let us know and we'll start the search! Later.
Blessed are the SIC
Old 02-26-2007, 02:43 PM   #4545
dnitro's Avatar
Ok guys, I found the problem on the servo saver.
The metal ring that locks down the spring has slowly come loose, and during the main, it came loose enough that it was actually rubbing against the chasis. That is why when I put the top brace back, the steering rack binds due to the pressure from the metal ring against the chasis. It didn't have to do anything with the top rack. I retightened it according to the manual and added a little extra blue lock tight. Tighten it enough so that there is 1mm thread showing.
This surely was one thing I overlooked cuz I never thought it would happen.
So boys, this might be another thing to put on your checklist.
Thanks for the help guys.
TM G4S
IDM Evo3
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 03:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 07:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
